04-05-2013, 19:29 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | right clic on soft and select run as admin then generate ur certificate Br |
The Following User Says Thank You to The_Gorr For This Useful Post: |
04-10-2013, 02:52 | #4 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | Mr. The_Gorr I have tried to install as administrator and does not work and changed the direction of the facility and does not work and also installed on an external hard drive and does not work root it and installed on local disk not work any other solution since you know more than anything is a work tool would be a waste to have it there without working since now all the pc work in win 7 I beg you to help me Greetings tecceljjr |
04-18-2013, 08:38 | #6 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | yes, soon new update with this bug corrected Br |
04-18-2013, 09:05 | #7 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Till this bug will be fixed (we are preparing new update and installer) do this for fix your problem. Go to the path where certificate is stored (i put my path for example) You must change your username. C:\Users\wendigo\AppData\Roaming\3G-Key and now rename folder to : C:\Users\wendigo\AppData\Roaming\3G Key-Box After this, software will work. With best regards, |
The Following User Says Thank You to wendigo For This Useful Post: |
04-19-2013, 20:08 | #8 (permalink) |
Member: 1318721 Status: Offline Thanks Meter: 166 | bb box certificate solved tested Mr. wendigo I owe for having the trouble to answer and I owe widely its solution I have the pleasure to report that it was a success my bb-box to 10000% working in windows 7 64bit here I leave a small tuto so they can work thanks and regards kzafquiel (tecceljjr) español: señor wendigo le agradesco por tomarce la molestia en contestar y le agradesco ampliamente su solucion tengo el placer de informar que fue un exito mi bb -box trabajando al 10000% en windows 7 64bits aqui les dejo un pequeño tuto para que puedan trabajar gracias y saludos kzafquiel(tecceljjr) [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
08-16-2013, 21:41 | #10 (permalink) |
Crazy Poster Join Date: Mar 2005 Location: GHANA Age: 45
Member: 121913 Status: Offline Thanks Meter: 3 | Hello sir i just bought the 3g key dongle and after installation and everything software close as soon as it opens. Pls help me . I have formatted my pc but still the same |
