03-12-2013, 15:29 | #1 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 581508 Status: Offline Thanks Meter: 5 | Plz help I cant certifacte my box always time out [SOLVED] iam using last update but every time i try to certifacte my dongle i get always error time out iam using sat tool 1.4.2 and 3gkey 1.33 my serial is A00002ABC00 tyhanx in advance |
03-31-2013, 04:31 | #4 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | 10:29:35 PM Requesting certificates to server... A01 Check Connection cant seem to get the certificate to use this project box serial : A00001e7300 Help Needed Urgently Regards |
05-02-2013, 11:25 | #7 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Hi, so finally box is working or not ??? Are you using last 3g-key version ??? Download here : http://www.3g-key.com/downloads/3GKe...Setup_v134.zip Last edited by wendigo; 05-02-2013 at 14:18. |
06-22-2013, 02:10 | #10 (permalink) |
Junior Member Join Date: Sep 2008 Location: puerto vallarta
Member: 861422 Status: Offline Thanks Meter: 0 | socket error did not work i installed new version .. which i already had .. deleted and reinstalled it does it on all my computers...saids unregistered or not configured.. socket error connection refused |
06-22-2013, 17:52 | #12 (permalink) |
Member: 861422 Status: Offline Thanks Meter: 0 | my box does the same on all three computers socket error 10061 my firewall is turned off and antivirus can you check my serial numero please a00002dd000 |
06-22-2013, 18:16 | #13 (permalink) | |
Member: 861422 Status: Offline Thanks Meter: 0 | Quote:
12:14:30 p.m. -- System scan for drivers -- Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0003" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "0" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0006" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0023" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0004" UpperFilters: "" LowerFilters: "" Driver: USB Token Device Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "USB Token Device" Hardware ID: "USB\VID_096E&PID_0005&REV_0260" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0013" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0019" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0033" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0005" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0029" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0000" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0001" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0005" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0015" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0004" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0011" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0003" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0028" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0001" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0026" UpperFilters: "" LowerFilters: "" Driver: PolarBox Ftdi Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "PolarBox Ftdi" Hardware ID: "USB\VID_0999&PID_6028&REV_0400" GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}" Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0002" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0027" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0018" UpperFilters: "" LowerFilters: "" Driver: e-gate Smart Card Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "0" Config-Flags: "0" Name: "" Description: "e-gate Smart Card" Hardware ID: "USB\VID_0973&PID_0001&REV_0100" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0041" UpperFilters: "" LowerFilters: "" Driver: USB Token Device Disabled: "false" Install-Failed: "false" Removed: "false" InstallState: "Error" Config-Flags: "0" Name: "" Description: "USB Token Device" Hardware ID: "USB\VID_096E&PID_0005&REV_0260" GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}" Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0040" UpperFilters: "" LowerFilters: "" [3] 12:14:33 p.m. SmartCard Driver (OK) [4] 12:14:33 p.m. Certificates (OK) [5] 12:14:34 p.m. Box integrity (OK) [5] 12:14:55 p.m. Server account (ERR) | |
