Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > POLAR Team Products > 3GKey / BB-Box
Old 05-01-2011, 03:12   #1 (permalink)
Member: 1101802
Sonork: 1615049
Problem Unlock HTC Magic [SOLVED]
Searching android device...
Kernel Ver: 2.6.27-5b476e83
Platform: sapphire
Bootloader: 1.76.0010
Baseband: 6.35.10.14
Cid: BSTAR301
CPU: ARMv6-compatible processor rev 2 (v6l)
Checking root...
Rooted OK
Patched OK
Loader prepared OK
Loader accepted OK
Imei: 3529490XXXXXXXX
Contacting With Server...Wait...
ERROR...Unknow Error Code
Codes Not Readed...
Operation finished with Error
Rebooting phone (END)
Old 05-01-2011, 15:16   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
reset phone and try to read codes again
br
<= The_Gorr =>
Old 05-01-2011, 15:20   #3 (permalink)
Member: 1480323
Sonork: iaai
why server involve here?
i guess bb-box is a stand alone software?
please correct me.
Old 05-01-2011, 15:22   #4 (permalink)
The_Gorr's Avatar
Member: 145648
is not a question of guess, if a question of READ
blackberry and other calculation are standalone
htc need server
then is clear, connect ur computer to internet to get codes
br
<= The_Gorr =>
The Following 2 Users Say Thank You to The_Gorr For This Useful Post:
Old 05-01-2011, 19:15   #5 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
HTC Magic (aka Sapphire) is not officially supported and thats why is giving you error from server side, contact Wendigo in private so you can both work in a solution to the problem.
Luck!
The Following User Says Thank You to y3kt For This Useful Post:
Old 05-01-2011, 20:17   #6 (permalink)
Member: 1101802
Sonork: 1615049
br
<= The_Gorr =>
I tried on several occasions but does not read the code, I need credit to unlock that HTC model?
br
MASRSYSTEM
Old 05-01-2011, 20:18   #7 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Platform: sapphire
Cid: BSTAR301
Checking root...
Rooted OK
Patched OK
Loader prepared OK
Loader accepted OK
Codes Not Readed...
Please, do this test :
- Install last update v1.1.9
- Select HTC HERO
- Press READ CODES
Later put here complete log,
With best regards,
\W3nd|g0
The Following User Says Thank You to wendigo For This Useful Post:
Old 05-01-2011, 20:23   #8 (permalink)
Member: 1101802
Sonork: 1615049
Luck!
Thanks Friend y3kt, The Wendigo will contact friend to find a solution to this phone very commercialized in Spain and Latin America.
Old 05-01-2011, 20:44   #9 (permalink)
Member: 1101802
Sonork: 1615049
- Select HTC HERO
- Press READ CODES
With best regards,
\W3nd|g0
Platform: sapphire
Cid: BSTAR301
Checking root...
Rooted OK
Patched OK
Loader prepared OK
Loader accepted OK
ERROR...Check Connection
Codes Not Readed...
logs using version 1.19 and hero htc model.
Old 05-01-2011, 21:15   #10 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Platform: sapphire
Cid: BSTAR301
Checking root...
Rooted OK
Patched OK
Loader prepared OK
Loader accepted OK
Codes Not Readed...
This error means you not have internet connection.
Please check and verify it.
With best regards,
\W3nd|g0
Old 05-01-2011, 22:19   #11 (permalink)
Member: 1101802
Sonork: 1615049
With best regards,
\W3nd|g0
Platform: sapphire
Cid: BSTAR301
Checking root...
Rooted OK
Patched OK
Loader prepared OK
Loader accepted OK
ERROR...Device Not Locked
Codes Not Readed...
Old 05-01-2011, 22:25   #12 (permalink)
Member: 1101802
Sonork: 1615049
After That Logs Probe Team and How It Be Released But Not What I did with BB-Box, I'm safe because the team was blocked by Movilnet Venezuela.
What I did was to use the Model T-Mobile G2 I Read Info Touch Unlock Then I showed an error but apparently if you Unlock.
Old 05-02-2011, 02:46   #13 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
It is really hard to understand what you mean here, you better send a pm to wendigo in spanish so he can understand and help you, luck
Spanish: Está difiícil de entender lo que quieres decir, mejor mándale un mensaje privado a wendigo o contáctalo a través del sonork u otro messenger para ver si pueden solucionar el problema de los Magic, Saludos y suerte.
Old 05-02-2011, 09:56   #14 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
This device is not locked, did you tried to put a sim from other operator ?
Esta HTC no esta bloqueada, mete una tarjeta sim de otro operador y confirmame si funciona ...
Old 05-02-2011, 19:32   #15 (permalink)
Member: 1101802
Sonork: 1615049
If Works, Thanks Friend Wendigo
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.58575 seconds with 11 queries
