05-06-2011, 15:12 | #1 (permalink) |
Junior Member Join Date: Mar 2011 Location: MXKEY TOOL Age: 45
Member: 1535109 Status: Offline Sonork: MXKEY TOOL Thanks Meter: 11 | help mr Naman, uct my dead initially upgrade fw box SN 000000, Conjunction Box Error versi 3.01 SN BOX 0000000 UploadPic.org - Picture Viewer - uploadpic.org there is no solution to this master of his box UCT so the setup for its repair |
The Following User Says Thank You to .:::RIYANN:::.. For This Useful Post: |
05-06-2011, 16:56 | #3 (permalink) |
Junior Member Join Date: Feb 2007 Location: java-manado-ternate-biak
Member: 449549 Status: Offline Thanks Meter: 3 | 've tried to do it this way bro....????// Steps: 1. Remove the USB cable from your PC 2. Attach the front extension cord 3. black and red cable, connect the continued during the process 4. Connect the USB cable to your PC 5. Check "Exigency Upgrade 6. Do the "Upgrade-BOX hopefully help............ |
05-06-2011, 23:57 | #5 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Quote:
About your problem,,, you can repair yout box using the emmergency upgrade solution, if u dont know how to do it, then please read details for the same in the manual. * UCT Box Manual download Link: http://forum.gsmhosting.com/vbb/f596...hindi-1016170/ * UCT Box emmergecy upgrade solution with video guide: http://forum.gsmhosting.com/vbb/f596...t-box-1234834/ If you still cannot fix your problem, then send your box to your reseller for replacement. they will get it fixed for you. and if u still cannot do that, then send it to our (new Delhi) office, and i will get it done for you. Br. Naman | |
05-06-2011, 23:59 | #6 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Easy intructions on: How to Solve "Conjunction Box" error while UpGrading firmware of your UCT Box You may get "Conjunction Box" error while upgrading the firmware of your UCT Box. This can be due to many reasons. Can be due to incomplete upgrade of firmware, bad voltage spikes can corrupt the firmware inside UCT Box, can be due to some bugs too. But this can be solved easy with the UCT Box Fiwmare UpGrade Utility. To fix this. you need to fix the complete firmware by using "Emmergency UpGrade" feature.
All should be ok now. If still any problem, then try repeat it 2-3 times. If still not help, then your box have a hardware problem, please contact your reseller. Br. Naman |
05-07-2011, 00:45 | #7 (permalink) | |
Member: 1535109 Status: Offline Sonork: MXKEY TOOL Thanks Meter: 11 | Quote:
ok thank mr Naman ,, my problem now solved.. thnx very very much : http://forum.gsmhosting.com/vbb/f596...dy-ok-1262636/ Last edited by nonu_don; 05-12-2011 at 21:17. | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
