Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UCT (Universal China Tool) by ET
Old 04-27-2012, 07:39   #1 (permalink)
navin71's Avatar
Member: 101891
Help uct box is not working all light is glow only
Uct box is not working all light is glow only and no beep sound when connected to usb port
Old 05-12-2012, 12:36   #2 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Please try to repair the box by "emmergency update" method. if this not helps you then u can contact your box reseller for warranty. If your box is old enough and not in warranty, then u can contact our head office in delhi for replacement of PCB in nominal charges.
Repair UCT Box with conjunction error: http://forum.gsmhosting.com/vbb/f596...t-box-1234834/
Br.
Naman
Old 05-12-2012, 12:37   #3 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Easy intructions on: How to Solve "Conjunction Box" error while UpGrading firmware of your UCT Box
You may get "Conjunction Box" error while upgrading the firmware of your UCT Box. This can be due to many reasons. Can be due to incomplete upgrade of firmware, bad voltage spikes can corrupt the firmware inside UCT Box, can be due to some bugs too.
But this can be solved easy with the UCT Box Fiwmare UpGrade Utility.
To fix this. you need to fix the complete firmware by using "Emmergency UpGrade" feature.
  1. Disconnect UCT Box from USB, connect the main cable to UCT Box.
  2. Now short the "+" and "-" wires of the main cable
  3. Connect computer with USB to UCT Box.
  4. Open the latest Update software for UCT Box. Press "ScanPort", Select your UCT Box comm port number, tick the "Exigency UpGrade" and press "UpGrade-BOX"
All should be ok now.
If still any problem, then try repeat it 2-3 times.
If still not help, then your box have a hardware problem, please contact your reseller.
Br.
Naman
What is the problem (ANSWERED) jaleelkuttikkar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 05-02-2012 09:22
My hti device not showing in connection list (ANSWERED) somratjisan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 04-25-2012 14:15
mx-box 3.5rev 2.0 synchronize error (ANSWERED) Deepesh_Sharma MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 04-25-2012 14:09
Not supported flash chip, disable "Use New Protocol for RAP3GV3" in config (ANSWERED) deepaklal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-25-2012 09:04
Page generated in 2.84796 seconds with 11 queries
