10-13-2010, 14:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Age: 43
Member: 978268 Status: Offline Thanks Meter: 83 | Et-box problem TEAM IAM FACING A PROBLEM WITH ET-BOX FROM PAST FEW DAYS IT SAYS DEVICE VERIFY FAIL,AND THE POWER+VCC+ELECTRODE+RXD LED'S ARE ON SO I AM UNABLE TO CONNECT THE BOX PLS HELP NEEDED |
The Following User Says Thank You to rkinfo_khan For This Useful Post: |
12-17-2010, 19:32 | #9 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Quote:
This should solve all your problem. Br. Naman | |
12-17-2010, 19:34 | #10 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | UCT v1.07 : http://forum.gsmhosting.com/vbb/f596...-fixs-1163051/ UCT Firmware 1.46D Manual : http://forum.gsmhosting.com/vbb/f596...t-box-1164534/ Br. Naman |
03-17-2011, 19:57 | #12 (permalink) |
Member: 978268 Status: Offline Thanks Meter: 83 | after a month again i am facing the same problem DEVICE VERIFY FAIL, i have uninstall the drivers and restarted the PC and again i installed the latest ver 1.21. same problem ,when i tried to update the box it shows CONJUNTION BOX ERROR |
03-26-2011, 20:02 | #14 (permalink) | |
Please read here abot how to fix the "Conjuction Box" error while updating firmware of your UCT Box : Click Here Br. Naman | |
03-26-2011, 20:02 | #15 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Easy intructions on: How to Solve "Conjuction Box" error while UpGrading firmware of your UCT Box You may get "Conjuction Box" error while upgrading the firmware of your UCT Box. This can be due to many reasons. Can be due to incomplete upgrade of firmware, bad voltage spikes can corrupt the firmware inside UCT Box, can be due to some bugs too. But this can be solved easy with the UCT Box Fiwmare UpGrade Utility. To fix this. you need to fix the complete firmware by using "Emmergency UpGrade" feature.
All should be ok now. If still any problem, then try repeat it 2-3 times. If still not help, then your box have a hardware problem, please contact your reseller. Br. Naman |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
