06-09-2014, 09:55 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Use this method to repair your box : http://forum.gsmhosting.com/vbb/f596...t-box-1234834/ |
06-09-2014, 09:56 | #3 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Easy intructions on: How to Solve "Conjunction Box" error while UpGrading firmware of your UCT Box You may get "Conjunction Box" error while upgrading the firmware of your UCT Box. This can be due to many reasons. Can be due to incomplete upgrade of firmware, bad voltage spikes can corrupt the firmware inside UCT Box, can be due to some bugs too. But this can be solved easy with the UCT Box Fiwmare UpGrade Utility. To fix this. you need to fix the complete firmware by using "Emmergency UpGrade" feature.
All should be ok now. If still any problem, then try repeat it 2-3 times. If still not help, then your box have a hardware problem, please contact your reseller. Br. Naman |
