06-06-2011, 01:10 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Get Closer with Mobile Age: 44
Member: 228358 Status: Offline Thanks Meter: 32 | Strange U707 G Five Problem was abnormal Menu..... After formatting phone result same... Then I took one new phone and Read its file .... Then I copy of the complaint phone file also... Then I try to Write New phones file in complaint phone its stops in 99%.. Any solution??? see the log... Analysis the file... It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM62 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_EN71GL064B0 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... |
06-08-2011, 00:56 | #3 (permalink) |
Member: 228358 Status: Offline Thanks Meter: 32 | See dear did you try direct format in such phones for such problem and succeeded?? or please give any example ....log or screen shot I tried all these..... please post right solution , if somebody have else dont try to post just format ...just flash....like this.... with example and experience post right solution Any way thank you for reply Prajith mobile hut complete mobile shop pandalam |
06-10-2011, 11:54 | #4 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
please work on low baud rate Last edited by Momin_Telecom; 06-10-2011 at 12:00. | |
06-30-2011, 21:15 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Did u took backup of your old flash file? r u able to flash it 100%?? Also please try if full manual erasing of the handset works for you, means first erase full handset manuall and then flash it with new flash file. Details on how to erase full flash file manually; http://forum.gsmhosting.com/vbb/f596...ndset-1235137/ Br. Naman |
06-30-2011, 21:15 | #6 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Easy instructions on: How to Full Erase a Flash Chip of a MTK as well as a SPD Handset First, most important, why do we need to full erase? Sometimes writting flash files to chinese phones is a big problem. even if u got everything ok, it might give error at some percentage. sometimes stuck at 10%, sometimes stuck at 15%. As per my personal experience, Full erasing has always been usefull before flashing. Either that be chinese phones or be nokia phones Step-by-Step Guide on how to erase full flash of your chinese handset:
Now most important is to put correct size for formatting. Depending on your flash size you need to enter the correct format size, the details are as follows:
----------------------------------------------------------------------------------------- To Prove this, we also made a simple test. We read the flash before formatting a handset. Now when this readed flash file is opened in a hex editing software we see this: But after formatting the handset with size "0x04000000" and reading the flash file again. What we see now in Hex editing software is this: Hence Proved Br. Naman |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
strange 5110 5.28 pls help | Salami1_1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-02-2001 17:57 |
strange contact service | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-12-2001 09:18 |
Strange Solutions... | rompa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-12-2000 17:51 |
Strange unlocking | Dens666 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-14-2000 14:45 |
