12-30-2010, 14:44 | #61 (permalink) |
Registered User Join Date: Nov 2005
Member: 203350 Status: Offline Thanks Meter: 1 | urgent,,,,,,spreadtrum chip not connected Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=7 D+=10 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM33 Connected...sending boot... Failed to RXD help me, how can solve this problem |
12-30-2010, 18:03 | #62 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | If Not able to connect & find pinout for SpreadTurm based handset. There are many SpreadTurm CPU based handsets in the market, however for most of them you can Read Info using the "Auto-USB" option. But if this not works you can try Read Info with Auto-COM or 6600L-NOR. After Read Info is ok, you can check which CPU it has then select that particular CPU from the option list. Then you can Read Flash, Write Flash, Format, Unlock, etc. Br. Naman |
12-30-2010, 18:03 | #63 (permalink) | |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Quote:
About Different Boot Mode: SpreadTrum CPU have different boot mode according to there CPU Type. Which is why it is important to select the correct boot mode for proper connectivity with the software. It might be posible that you can read info and flash with wrong selection, but for write flash need to select correct boot mode. First you need to Read Info of the handset, which will give you the details about your CPU type. After you know what CPU your phone have, just select the same from the option menu and then u can proceed to Read Flash, Write Flash, Unlock, Format, IMEI. | |
12-31-2010, 02:50 | #64 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1326978 Status: Offline Thanks Meter: 1 | Sir help me to solve G'five 6700i flash, when connect the phone it show following msg Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM5 Connected...sending boot... Failed to run bootloader... Please Help me |
12-31-2010, 13:05 | #65 (permalink) |
Major Poster Join Date: Apr 2007
Member: 488772 Status: Offline Thanks Meter: 7 | DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed not giving full info and cant format |
01-01-2011, 11:52 | #67 (permalink) | |
i have said allready inmy earlier posts, please try to change boot mode option and then try again. It is very important in SpreadTrum CPU case that you select the correct CPU Option which you are trying to connect. Try read the manual again and read the full procedure again. Please download manual from here : http://forum.gsmhosting.com/vbb/f596...hindi-1016170/ Br. Naman | |
01-01-2011, 11:55 | #68 (permalink) | |
1. i think is has already given you phone information. 2. if still is some problem then try to use different boot option. Also if your handset is "NAND" memory type, then please select NAND mode in options with different Boot versions & try again. 3. can u please give me your specific error about the formatting problem? Br. Naman | |
01-01-2011, 14:46 | #69 (permalink) |
Major Poster Join Date: Nov 2008 Location: Wayanad
Member: 898192 Status: Offline Thanks Meter: 2 | canot doung any work my UCT read info Initializing... DA_LIB_VER_2.4.4.9 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: B018-2_L130_V106 Changing baudrate to 921600... Done. i try to format Initializing... DA_LIB_VER_2.4.4.9 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: B018-2_L130_V106 Changing baudrate to 921600... Done. i try to tracker Initializing... DA_LIB_VER_2.4.4.9 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the ON/OFF key... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: B018-2_L130_V106 Changing baudrate to 921600... Done. and also i try to read flash but same result i do this work to day morning ok but now lik this i try tow or tree fones but same cant formating pls help me |
01-02-2011, 15:47 | #71 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Yes, it is important to update your box with firmware version 1.51 to use the Setup 1.08 or later.
Br. Naman |
01-07-2011, 08:16 | #73 (permalink) |
Junior Member Join Date: Nov 2007
Member: 624619 Status: Offline Thanks Meter: 2 | pls help me i have a spreadtrum handset showing this error........when try to format Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=9 D+=8 Searching commport...please wait... Spd USB-to-Serial not found Last edited by nonu_don; 01-07-2011 at 19:48. |
01-07-2011, 08:42 | #74 (permalink) |
Member: 624619 Status: Offline Thanks Meter: 2 | help Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... RXD=5 TXD=8 Connecting... Connected...sending boot... Failed to RXD Last edited by nonu_don; 01-07-2011 at 19:48. |
01-07-2011, 12:20 | #75 (permalink) |
Member: 624619 Status: Offline Thanks Meter: 2 | how to solve this prob..... Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC240200000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... ProjectID Not Found. Last edited by nonu_don; 01-07-2011 at 19:36. |
