![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Some Tips, Tricks, Guides, Solutions, Troubleshoot for UCT Box Software Initializing... DA_LIB_VER_3.2.0.7 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 Reason: Bad Flash IC or Bad Cable Solution: 1. Computer power supply not good. Try different PC 2. The USB Cable you are using is not good quality, try use short lenght cables wih pure copper core;s 3. Rehot the flash IC and try again. if still not then need replace flash IC. 4. Can try to change cable, try with slower baudrate and try few times. Last edited by nonu_don; 01-03-2012 at 13:57. |
The Following 4 Users Say Thank You to nonu_don For This Useful Post: |
![]() | #2 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Flashing stops at different percentage everytime. Means first try it stop at 30%, next time it stop at 35%, then 10% and so and so. Reason: This can be due to: 1. Bad Flash Chip 2. Low power to handset 3. Bad data inside Flash Chip Solution: First i suggest to try with slow baudrate, try flash with slow baudrate. if this not success then better erase the complete flash chip and then try again. This should sure help if its not a hardware fault. If it still not helps, means can be hardware problem too, in this case you can reflow the Flash IC or replace if necesarry. |
The Following 3 Users Say Thank You to nonu_don For This Useful Post: |
![]() | #3 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Not able to work correctly on MTK CPU ID 6217. Reason: Unsupported Boot type Solution: You need to use supported boot type for this CPU ID. Just select "Boot 3.848" and it should work ok. |
![]() | #4 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: "SPD USB TO SERIAL NOT FOUND" Reason: The drivers are not installed for SpreadTrum USB communication Solution: You need to install the USB drivers for SpreadTrum. when UCT box has finished finding the pinouts for spreadturm handset, it will ask for SPD drivers, these drivers can be found inside folder: "C:\UCT\UCT\SpreadTrum_USB_Drivers\" just need to install them and then UCT can start working your handset. If in case the computer not asks for any drivers after pinfinding, then you need to un-install the bad drivers from your device manager and then again re-install the supplied drivers. |
![]() | #5 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: "Failed to format Flash" Reason: Cannot format the flash for older type handsets, cause they not support new boot type. Solution: Just try different boot types and it should be ok. Some boot can work for some handsets. This is why it is not important that the latest boot will always work for all handsets. it can be also that only old boot type will work for some particular handsets. Last edited by nonu_don; 03-27-2011 at 15:25. |
![]() | #6 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Error "Project ID not found" while connecting the handset Reason: UCT Software is not able to find the project id inside the handset flash, project id is the version of the firmware. This can be cause of wrong boot selection, wrong memory type selection or can be due to empty flash chip or hardware fault. Solution: to solve this, first try with different boot type and mode type, try all boot and also try with "NAND" memeory type as well. if still not works, then flash the handset with good flash file. if not able to flash, means bad flash chip, try reflow or replace. |
![]() | #7 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Spreadturm handsets show "Failed to RXD" Reason: This error can be cause of many problems. can be cause of wrong connectivily, bad cable, wrong boot type Solution: Select "6600L-USB" or "6600L-USB" in options and try again |
The Following 2 Users Say Thank You to nonu_don For This Useful Post: |
![]() | #8 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. Reason: UCT Software is not able to recognise the flash address inside handset Solution: 1. Try to do "Reset", it should help you 2. If reset not helps then try to format mnaually with the fat address which is displayed in "read info", Means use the fat address shown in the read info of the handset to format it manually. (make sure to take full handset backup before you try this). 3. Even if this not helps, then only way to fix this is by flashing handset with correct flash file, if u dont have a flash file then u need to arrange a similar handset, read the flash from it and then flash it to your faulty handset. Last edited by nonu_don; 09-13-2011 at 13:47. |
![]() | #9 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Read Info, Read Flash working fine for SPD handset, but format anf write flash not working properly. Reason: you are not sellecting the correct option type according to cpu id and flash id. Solution: Make readInfo of the handset, here in information you will see the CPU type and the flash type of the handset, for eg. CPU: 6600xxxxxxxxx Flash: NOR. Now in this case, you need to select the option "6600L-USB" and then proceed. Means it is very important to select the correct options, otherwise format, write flash will not work properly. for details, better read complete guide for SpreadTrum phones. |
![]() | #10 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 Nor Flash not found. Reason: Bad flash IC Solution: You need to replace the flash IC |
![]() | #11 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... BB:6227, HardwareVer:8A05, SoftwareVer:8A00 Set RTC Alarm Mask failed, REG=0x405600780 Reason: Problem is due to low power to handset Solution: Keep and press the power button during complete operation. this might help. Last edited by nonu_don; 03-27-2011 at 15:27. |
![]() | #12 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: M.RK3230436.M28202.V1.1.0.0M1226 Changing baudrate to 921600... Done. Reading full Flash... CRC error: CRC=4C92, CheckSum16=4C8A Reason: Bad CRC checksum inside the flash of handset. this is due to bugs inside handset firmware Solution: You need to format the handset first before any other operation. |
![]() | #13 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Read info is done. CPU: SC6600R Flash: NAND_H8BCS0PG0MBP Set FLASH Parameters... Settings have been completed! Reading FileSystem info... Failed to read FS info. Reason: The File System is not found by software Solution: Only way to solve this is by flashing the handset with correct flash file, or need to read flash from a working handset and then flash it to faulty handset. Last edited by nonu_don; 03-27-2011 at 15:27. |
![]() | #14 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: setting the Flash Parameters... Settings have been completed! Reading FileSystem info... Error: Get Flash die baseaddress Reason: Phone has been tampered with other software or the firmware inside has been corrupted. Solution: You need to look for the Full flash file of this handset and flash to it, If u dont find a flash file in that case you need to look for a working handset and read flash from it, then flash it to your dead handset. |
![]() | #15 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Get error "Invalid IMEI" when trying to repair IMEI for some MTK handsets Reason: Some handsets, mostly of CPU 6235 and 6253 have this problem after format. After format cannot write IMEI and show error Invalid IMEI Solution: To solve this you need to flash the handset. There is no other way to solve this problem for now. But you can avoid this error by taking NV data backup before formatting the handset. Just select NV Editor and take full backup of handset before formatting. After format, write NV data back to handset and then fix IMEI. |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
