03-27-2011, 12:42 | #16 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | How to solve error: FAILED TO RUN BOOTLOADER Reason: Communication is stopped in middle with handset and UCT Box Solution: 1. Try to Press and hold the power button untill all process is completed 2. if even this not help then press and hold * key and keep pressed untill all completed. 3. try to un-install and re-install SpreadTrum USB drivers. 4. change com port for spd-to-com,, should always be below 10 5. can be harware problem also,, many users solve this problem by reballing flash chip Last edited by nonu_don; 04-05-2011 at 05:52. |
The Following 3 Users Say Thank You to nonu_don For This Useful Post: |
03-27-2011, 15:12 | #17 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: How to solve the error: ERROR: MTK_DA_GET_FAT_INFO_NOT_FOUND Reason: UCT Software is not able to read the FAT information from the MTK handset, this is because of un-compatible flash chip or boot type. Solution: Try to select Boot "Ver. 3.952" from the options, if even this not works, then try other options one-by-one. |
05-12-2011, 21:35 | #18 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Error: RXD<>MaxBuffSize, Please close all other program or change baudrate and try again. Reason: Software not able to buffer the data Solution: Select baud 921600 and try again |
The Following 2 Users Say Thank You to nonu_don For This Useful Post: |
05-15-2011, 20:45 | #19 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Changing baudrate... Failed to set baudrate... Reason: Usually driver problem. Communication between phone and pc is poor. Solution: 1. Try with option "6600L-USB" or "6600L-COM" and try again. 2. Try to un-install spreadtrum drivers and install again. 3. Try with smaller baudrate. 4. Try with any other computer. Should work 5. if still not solve and handset is dead, can be 99% hardware problem. |
The Following User Says Thank You to nonu_don For This Useful Post: |
05-28-2011, 09:25 | #20 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Cannot connect SPD handsets with in-built battery Solution: Just press the * and # button on the handset and then press "Start" in UCT Software. All Should be ok now. Thnx to S!DD |
09-01-2011, 14:16 | #21 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=9 D+=14 BOOT set failure, continue to scan... Sense failure Reason: Pinout Finding is correct, but UCT is not able to boot the SpreadTrum handset. Solution: 1. If your handset have a inbuilt battery then press * and # on the phone and keep them pressed and then try to connect the handset 2. Press and hold 0 and power button on the handset and then try to connect the handset. 3. If above not work, then press and hold * button on the handset and then try to connect the handset. 4. If above not work, then press and hold 0 button on the handset and then try to connect the handset. 5. If you still cannot solve this problem, then try to locate Rx and Tx on the handset and connect using them and select "6600L-COM" Last edited by nonu_don; 09-11-2011 at 10:57. |
09-01-2011, 14:37 | #22 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Cannot enter tracker or cannot boot in meta mode Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... BB:6226, HardwareVer:8A02, SoftwareVer:8A01 Read info...ok, Waitting enter meta... Connection time out. Reason: Low power to handset Solution: 1. Take a power supply or the handset battery and connect it to the + and - of the handset. 2. Connect the ground only (-) from the UCT Box Main cable to the handset, dont connect the positive nide (+). 3. Try now to connect and all should be ok. |
09-01-2011, 14:44 | #23 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Problem Description: Not able to connect handset with CPU 6217 Reason: Not supported by old boot versions Solution: Select Boots: Ver3.848 in the Options and then try again |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
