Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UCT (Universal China Tool) by ET
Old 03-27-2011, 12:42   #16 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Problem Description:
How to solve error: FAILED TO RUN BOOTLOADER
Reason:
Communication is stopped in middle with handset and UCT Box
Solution:
1. Try to Press and hold the power button untill all process is completed
2. if even this not help then press and hold * key and keep pressed untill all completed.
3. try to un-install and re-install SpreadTrum USB drivers.
4. change com port for spd-to-com,, should always be below 10
5. can be harware problem also,, many users solve this problem by reballing flash chip
The Following 3 Users Say Thank You to nonu_don For This Useful Post:
Old 03-27-2011, 15:12   #17 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
How to solve the error: ERROR: MTK_DA_GET_FAT_INFO_NOT_FOUND
Reason:
UCT Software is not able to read the FAT information from the MTK handset, this is because of un-compatible flash chip or boot type.
Solution:
Try to select Boot "Ver. 3.952" from the options, if even this not works, then try other options one-by-one.
Old 05-12-2011, 21:35   #18 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Error: RXD<>MaxBuffSize, Please close all other program or change baudrate and try again.
Reason:
Software not able to buffer the data
Solution:
Select baud 921600 and try again
The Following 2 Users Say Thank You to nonu_don For This Useful Post:
Old 05-15-2011, 20:45   #19 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Changing baudrate...
Failed to set baudrate...
Reason:
Usually driver problem. Communication between phone and pc is poor.
Solution:
1. Try with option "6600L-USB" or "6600L-COM" and try again.
2. Try to un-install spreadtrum drivers and install again.
3. Try with smaller baudrate.
4. Try with any other computer. Should work
5. if still not solve and handset is dead, can be 99% hardware problem.
The Following User Says Thank You to nonu_don For This Useful Post:
Old 05-28-2011, 09:25   #20 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Cannot connect SPD handsets with in-built battery
Solution:
Just press the * and # button on the handset and then press "Start" in UCT Software. All Should be ok now.
Thnx to S!DD
Old 09-01-2011, 14:16   #21 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Initializing...
DA_LIB_VER_2.5.1.2
It is sensing the pinout fast...
D-=9 D+=14
BOOT set failure, continue to scan...
Sense failure
Reason:
Pinout Finding is correct, but UCT is not able to boot the SpreadTrum handset.
Solution:
1. If your handset have a inbuilt battery then press * and # on the phone and keep them pressed and then try to connect the handset
2. Press and hold 0 and power button on the handset and then try to connect the handset.
3. If above not work, then press and hold * button on the handset and then try to connect the handset.
4. If above not work, then press and hold 0 button on the handset and then try to connect the handset.
5. If you still cannot solve this problem, then try to locate Rx and Tx on the handset and connect using them and select "6600L-COM"
Old 09-01-2011, 14:37   #22 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Cannot enter tracker or cannot boot in meta mode
Initializing...
DA_LIB_VER_3.2.2.8
It is sensing the pinout fast,please hold on the phone Power key
RXD=8 TXD=4
Connecting...Please hold on the POWER key until the red gauge is going...
BB:6226, HardwareVer:8A02, SoftwareVer:8A01
Read info...ok, Waitting enter meta...
Connection time out.
Reason:
Low power to handset
Solution:
1. Take a power supply or the handset battery and connect it to the + and - of the handset.
2. Connect the ground only (-) from the UCT Box Main cable to the handset, dont connect the positive nide (+).
3. Try now to connect and all should be ok.
Old 09-01-2011, 14:44   #23 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Not able to connect handset with CPU 6217
Reason:
Not supported by old boot versions
Solution:
Select Boots: Ver3.848 in the Options and then try again
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Page generated in 0.47136 seconds with 11 queries
