Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UCT (Universal China Tool) by ET
Old 01-09-2011, 05:50   #1 (permalink)
Crazy Poster
Member: 834924
spreadtrum flesh problem
during read imformation in spreead trum cpu bassed mobile "failed to run boot loader" error .help me.
Old 01-09-2011, 06:54   #2 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Sir, you need to first read the phone information.. try this with selecting boot "Auto-USB", "Auto-COM" or "6600L-NOR" one-by-one.
after you read the information, then select the correct boot according to cpu type and memory type, then you can read and write the flash.
DETAILED : Correct Steps to connect and work on a SpreadTrum CPU based handset:
  1. First u need to read information of the handset. Go to “SpreadTrum” tab, select “ReadInfo”, select option according to CPU type. If you don't know the CPU boot type then you can try “Auto-USB”, “Auto-COM” or “6600LNOR” one-by-one.
  2. Press “Start”.
  3. Now you don't need to power on the phone in SPD handsets. It will automatically start sensing the pinouts. After finding the pinouts the phone will ask for usb drivers. SPD drivers are located under folder “SpreadTrum_USB_Driver”. If you have already installed the drivers then system will not ask for drivers next time.
  4. After installing drivers, software will connect to your SpreadTrum handset and will read information which will be displayed on the bottom.
  5. You can now read in it that which type is the CPU and flash memory of the handset. Example: CPU: SC6600E-xxxx Flash: NAND_xxxx Here the CPU type is 6600E and the memory type in NAND, so in this case you need to select the option “6600M/E/I-NAND” and then proceed further.
  6. After you have selected the correct CPU type in the options, now you can start with Format, Read Flash, Write Flash, Repair IMEI, etc.
If u need more help, then you watch this video for complete tutorial on spreadtrum handsets : Tutorial : How to connect & use UCT Box with SpreadTrum CPU based handsets
Br.
Naman
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.27100 seconds with 11 queries
