03-26-2011, 20:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Tutorial: How to Full Erase a Flash Chip of a MTK as well as a SPD Handset First, most important, why do we need to full erase? Sometimes writting flash files to chinese phones is a big problem. even if u got everything ok, it might give error at some percentage. sometimes stuck at 10%, sometimes stuck at 15%. As per my personal experience, Full erasing has always been usefull before flashing. Either that be chinese phones or be nokia phones Step-by-Step Guide on how to erase full flash of your chinese handset:
Now most important is to put correct size for formatting. Depending on your flash size you need to enter the correct format size, the details are as follows:
----------------------------------------------------------------------------------------- To Prove this, we also made a simple test. We read the flash before formatting a handset. Now when this readed flash file is opened in a hex editing software we see this: But after formatting the handset with size "0x04000000" and reading the flash file again. What we see now in Hex editing software is this: Hence Proved Br. Naman |
The Following 6 Users Say Thank You to nonu_don For This Useful Post: |
11-02-2011, 16:29 | #5 (permalink) | |
Freak Poster Join Date: Feb 2009 Location: heven
Member: 969337 Status: Offline Sonork: 100.1608846 Thanks Meter: 32 | Quote:
The Following User Says Thank You to pocketmar For This Useful Post: |
11-03-2011, 19:23 | #6 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Please login to UCT Box official support area, where you can download all mtk handset flash files. for more details please visit : UCT Box - Support Br. Naman |
11-03-2011, 19:25 | #7 (permalink) | |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Quote:
Br. Naman | |
01-12-2012, 04:24 | #9 (permalink) |
Let me know if still any problem. Br. Naman |
The Following User Says Thank You to nonu_don For This Useful Post: |
03-23-2017, 16:28 | #10 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2696548 Status: Offline Thanks Meter: 1 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A2DC83C10F Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x00 , OEM : 0000 [eMMC] : FLASH_INF : [NOT_IN_BASE] , [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_BRT : 0x00000000 , 0x00000000 , 0x00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 [eMMC] : FLASH_UCP : 0 MiB [eMMC BAD_CONN] DEV RID : 0xF4C7246220FEAE7087E1CA964A130CC0 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : DA_HANDSET_ROM_INFO_NOT_FOUND SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s3511 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3572 mV BL : [WARNING] : BatteryLevel LOW!!! Backup enabled! Backup Failed : Device memory erased / not initialized! Continue flashing without backup! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase Error! Something went wrong! Operation Failed Elapsed: 00:00:29 Reconnect Power/Cable! MTK 6572 flash full erased, how to fix? solution plz??? |
03-23-2017, 16:46 | #11 (permalink) | |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Quote:
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
