12-10-2012, 15:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1766532 Status: Offline Sonork: 100.1625712 Thanks Meter: 31 | 8100 problem unlock IMEI: 354580016 MEP: MEP-04103-001 Factory Lock State: OPEN MXKEY Serial: MEP2(Network): 0328905200340636 MEP3(Network Subset): 5811403948314069 MEP4(Service Provider): 5399125265008431 MEP5(Corporate): 0811535090145558 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level (2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. my problem when i enter the code it will appear code error pls help me the remaining mep is 2 please help Last edited by lakers88; 12-10-2012 at 15:22. |
