04-03-2014, 06:34 | #1 (permalink) |
Insane Poster Join Date: Jan 2003 Location: semarang Age: 46
Member: 20038 Status: Offline Thanks Meter: 19 | BlackBerry Loader version 1.4 build: 2829 BlackBerry Loader version 1.4 build: 2829 The only software you need to repair BlackBerry handheld. Featuring: - Multi Flashing Allows to flash(Rapid,FOS) several devices at one time to saves your time and make more profit. - Rapid Flashing with an easy PRD selection - Modular Flashing as alternative for Desktop Manager - Advance function Erase System Allows all the filesystem and OS regions of flash to be irreversibly erased. This function will delete all memory and you will need to reflash the device. Erase QCFS Allows to erase Modem Efs/Qualcomm file system contains radio calibrations data. This function will delete all radio calibrations, useful to identify whether the device cannot boot because of radio problems or something else. Erase FATFS(Built-In Storage) Allows to erase Built-In Media Storage(FAT partition). This function will erase all data inside built- in storage, no data will be recovered. This is an alternative solution to fix "Loading stuck" problem. Restore Secure Data This function will restore secure data from backup stored on server that was made previously when "Backup secure data" was used on Flashing OS. and soon... - Repair function Rebuild QCFS Allows to rebuild/repair Modem Efs/Qualcomm file system and QC NV(radio calibrations data) Allows to repair network problem(could not start, 3G inactive and soon..) Allows to rebuild/repair IMEI and MEID or ESN Allows to reset MSL to default which will be usefull for CDMA devices - MASTER license features: Rebuild QCFS with Recovery Mode Allows to recover IMEI from device which was previously erased by thirdparty tools. Reset MSL/SPC code directly (without rebuild Qcfs, without FOS) DeBranding Allows to Reset Logo, change Vendor ID, and reset bitflags ReBranding Allows to change Vendor ID, Splash (Logo) as spesified on VSM file. Disable/Enable FATFS(Built-In Media Storage) Clear MEP(mep 0 left)/Direct Unlock Relock to Networks Change keypad setting(QWERTY/QWERTZ/AZERTY) Set Auto LCD Enable CAMERA menu and set Auto Camera Restore OSNV backup Restore QCFS backup QCFS backup was made when you are using Rebuild QCFS in recovery mode. This is usefull to restore back QCFS for the phone with HW failures. ----------------- Note: Internet connection required Operation time approximately 30 seconds Operation cost is vary and will be displayed on each button function Operation is standalone when SUPERMASTER license enabled Currently supported models: BlackBerry Storm 9500 BlackBerry Storm 9520 BlackBerry Storm 9530 BlackBerry Storm 9550 BlackBerry Style 9670 [new]BlackBerry Pearl 8130 [new]BlackBerry Pearl 8230 BlackBerry Pearl 9100/9105 BlackBerry Torch 9810 BlackBerry Torch 9800 BlackBerry Torch 9850 BlackBerry Torch 9860 BlackBerry Tour 9630 [new]BlackBerry Curve 8310 [new]BlackBerry Curve 8320 BlackBerry Curve 8330 BlackBerry Curve 8330m BlackBerry Curve 8900 BlackBerry Curve 8910 BlackBerry Curve 8980 BlackBerry Curve 8520 BlackBerry Curve 8530 BlackBerry Curve 9300 [new]BlackBerry Curve 9220 [new]BlackBerry Curve 9310 [new]BlackBerry Curve 9320 [new]BlackBerry Curve 9350 [new]BlackBerry Curve 9370 [new]BlackBerry Curve 9360 [new]BlackBerry Curve 9380 [new]BlackBerry Curve 9620 BlackBerry Curve 9330 BlackBerry Bold 9000 BlackBerry Bold 9700 BlackBerry Bold 9780 BlackBerry Bold 9788 [new]BlackBerry Bold 9790 BlackBerry Bold 9900 BlackBerry Bold 9930 BlackBerry Bold 9650 [new]PORSCHE DESIGN P`9981 - ZERO license features: Multi-Flashing Refurbish with clean OS, flashing multiple devices at once Reset lifetimer temporary Currently supported models: BlackBerry Storm 9500 BlackBerry Storm 9520 BlackBerry Storm 9530 BlackBerry Storm 9550 BlackBerry Style 9670 BlackBerry Pearl 9100/9105 BlackBerry Torch 9810 BlackBerry Torch 9800 BlackBerry Torch 9850 BlackBerry Torch 9860 BlackBerry Tour 9630 BlackBerry Curve 8330 BlackBerry Curve 8330m BlackBerry Curve 8900 BlackBerry Curve 8910 BlackBerry Curve 8980 BlackBerry Curve 8520 BlackBerry Curve 8530 BlackBerry Curve 9300 BlackBerry Curve 9220 BlackBerry Curve 9310 BlackBerry Curve 9320 BlackBerry Curve 9330 BlackBerry Curve 9350 BlackBerry Curve 9370 BlackBerry Curve 9360 BlackBerry Curve 9380 BlackBerry Curve 9620 BlackBerry Curve 9720 BlackBerry Bold 9000 BlackBerry Bold 9700 BlackBerry Bold 9780 BlackBerry Bold 9788 BlackBerry Bold 9790 BlackBerry Bold 9900 BlackBerry Bold 9930 BlackBerry Bold 9650 PORSCHE DESIGN P`9981 - ZERO1 license features: Reset lifetimer permanent for OS5 (Unlimited) Multi process, processing multiple devices at once Operation time approximately 30 seconds Currently supported models: BlackBerry Curve 8520 BlackBerry Curve 8530 BlackBerry Curve 8900 BlackBerry Curve 8910 BlackBerry Curve 8980 BlackBerry Bold 9650 BlackBerry Bold 9000 BlackBerry Bold 9700(OS5) BlackBerry Storm 9500 BlackBerry Storm 9520 BlackBerry Storm 9530 BlackBerry Storm 9550 - ZERO2 license features: Reset lifetimer permanent for OS7 Multi process, processing multiple devices at once Operation time approximately 30 seconds Currently supported models: PORSCHE DESIGN P`9981 (50 credit) BlackBerry Bold 9900 (1 credit) BlackBerry Bold 9930 (1 credit) BlackBerry Bold 9790 (1 credit) BlackBerry Torch 9810 (1 credit) BlackBerry Torch 9850 (1 credit) BlackBerry Torch 9860 (1 credit) BlackBerry Curve 9360 (1 credit) BlackBerry Curve 9380 (1 credit) BlackBerry Curve 9320 (1 credit) BlackBerry Curve 9220 (1 credit) BlackBerry Curve 9620 (1 credit) ----------- join us: https://groups.google.com/forum/#!fo...ckberry-loader ----------- changes: ----------- version 1.4 build: 2829 ADD: ZERO2 function, reset lifetimer permanent OS7 (for users with ZERO license) ADD: ZERO1 function, reset lifetimer permanent OS5 (for users with ZERO license) BUGFIX: 9620 loader bugfixed BUGFIX: minor bugfixed and improvements ----------- version 1.4 build: 2810 BUGFIX: BBOS 6 devices branding BUGFIX: 9800 "invalid osnv" bug fixed BUGFIX: minor bugfixed and improvements ----------- version 1.4 build: 2798 ADD: Option to set Default(BlackBerry) Logo instead of remove it while Debranding. ADD: Option to set Reset BitFlags while Debranding. ADD: Default support files ( Options->Support files) Usefull for users to download complete list of Rapid,SwParts files. ADD: error_codes.txt for complete list of error codes of device with DEVELOPER mode set. BUGFIX: minor bugfixed and improvements ----------- version 1.4 build: 2754 BUGFIX: Auto close on downloads BUGFIX: QCFS repair, minor bugfixed and improvements ADD: Read MSL, usefull for CDMA devices ADD: New supported models for master task(9620 - Patagonia) ----------- version 1.4 build: 2721 BUGFIX: Repair task bugfix and improvements ADD: Advance Info function, usefull to identify device state/problems before repair ADD: Relock function (multi lock supported) ADD: De-Branding(reset logo,change vendor id, reset bitflags/auto turn-on) function for all supported models ADD: Re-Branding function for all supported models ADD: Restore local OSNV backup (+Advance tab) ADD: Restore local QCFS backup (+Advance tab) ADD: New supported models for master task(9350,9370,9310) ----------- version 1.3 build: 2625 ADD: Revised Repair task, native USB communication implemented. ADD: Reset MSL task ADD: Re-Branding task ADD: Restore QCFS backup task ADD: Remanage QCFS filename format for better user understanding eg: 9900[IMEI][WCDMA_XXX] ADD: Basic device info for "Built-in Media Storage" and "QCFS" state and availability ADD: Backup secure data option on flashing (only for MASTER license user) ADD: Backup secure data option on +Advance tab (only for MASTER license user) ADD: Restore secure data option on +Advance tab (only for MASTER license user) REMOVED: Legacy function as this will not usefull anymore BUGFIX: PRD files download BUGFIX: Read NV on CDMA tab(made an invalid QCNV file format) BUGFIX: Write Default Cal on CDMA tab BUGFIX: Failed to read metrics[x] BUGFIX: No Security Dongle BUGFIX: Modular Flashing causing Error 507 BUGFIX: Erase failure BUGFIX: JavaLoader task bug on WinXP General informations: HIS and HOS mode: flash -> +Advance --------------------- HOS = DEVELOPER mode. in this mode, if the phone is crash the phone will display an error code. HIS = PRODUCTion mode. in this mode, if the phone is crash the phone reboot. See "error_codes.txt" for completed list of error code details. Device state(summary): --------------------- Secured device: yes <- means it is NORMAL phone(will display "no" when you connect a "prototype" device) Built-in Media Storage: enabled <- enabled: NORMAL, disabled: was available but has been DISABLED, not available: No Built-in Storage available on this phone QCFS partition: exist <- exist: means you may use "Rebuild QCFS, Reset MSL, CDMA" functions, not available: No QCFS partition for this device Delete Persistent Store: service -> +Utility --------------------- Delete applications data and cache, this will also delete BBID and email account, device settings. in indonesian loanguage... pls translate it.. if u want to know Penawaran software BlackBerry loader, satu solusi hebat untuk all repair software BlackBerry. Harga: 1.Paket Retail 300rb ( Flasing dan redblink solution) 2.Master 700rb (harus mempunyai retail terlebih dahulu) mendapatkan bonus 40 credit loh... 3.Dari master baru bisa ke dua pilihan, Mau super dbims / unlimited disable Bims (49-40=9cr) atau super master/ unlimited all repair function (149-40=109cr) 4.Zero, syarat telah memiliki super master sebelumnya, harga silakan hubungi reseler catatan Memiliki Kartu + dongel senilai 300rb (kagak perlu beli jika sudah memiliki kartu mxkey/mxbox) Saldo minimum 1cr Bonus master 40cr masih genep Kurs 1cr=10rb Pembelian dapat di lakukan di dealer BlackBerry loader: Yogya ponsel ; pak hafid NN cell; om irawan Total part ; om buntoro Djawir cell; pak djawir MSC Team; Neng Tary Gblues; Pak Ary MC : ko achiang BR MX Lover |
The Following 4 Users Say Thank You to kosuma For This Useful Post: |
04-03-2014, 19:07 | #4 (permalink) |
Junior Member Join Date: Dec 2013 Location: Tangerang - Indonesia
Member: 2077255 Status: Offline Thanks Meter: 15 | Rebuild qcfs BlackBerry Loader Ready. Server version: 1.0 ID: BF01005C balance: 50.0 Connected to USB: 9CF39ED906F368FA2692C8F91C31370FF16C16F7 Driver: [RimUsb] version: 4.2.0.30, NTMP: 4.2.0.30 Connection status: EHCI:HUB:HUB:USB 2.00 High-speed Operating system: 6.1.7601.18229 (WoW64) Service Pack 1 - English (United States) User: Rully [SMART-FLASHER] Software: 1.4.0.2829 Serial: BF01005C Connecting to bootrom... Connected. Bootrom: Version: 5.22.0.15 Hardware ID: 0x1D001404 (9860) RIM BlackBerry Device Build: ec_agent, Apr 26 2011 18:58:44 Security: Enable Drivers: 0x00000010 LDR Blocks: 0x80013F4C Bootrom Size: 0x00020000 Processor: 0x00400001 Flash ID: 0x00000000 HW Version Class: Board Revision: 0017 CPU Version: 0166 SW Compatibility: 0003 POP Revision: 0003 Power Mgt Hardware: 0001 POP Security: 0001 WCDMA Band supported: 0000 BSIS support: 0001 Charger Hardware: 0009 Uploading RAM Loader... Done. Attempting to connect to BootImage... BootImage connection successful Requesting BootImage Handshake Device Info: PIN: 296B5E27 IMEI: 357826044791017 Vendor ID: 600 - Axiom/Etisalat Misr/STC Saudi Arabia/Telenor Pakistan/Mcel/Zain Zambia/Zain Nigeria/Oman Mobile/Batelco/Etisalat Nigeria/GeoCell/GO Mobile/Ufone/Zain Kuwait/Warid Pakistan/MTC Touch/Zain ******/Nawras/Zain Ghana/Wataniya Kuwait/Zain Malawi/EMS/DU GUID: 9CF39ED906F368FA2692C8F91C31370FF16C16F7 Bootrom hash: 6781FF812EF99B3D5A01D1E56512F486F03DB31A HW ID Override: None Flash (eMMC): NAND blocks: 0-52239 ID: 0x4504 (******* (4.41)) Page size: 0x00010000 (64 Kb) Total size: 3.19 GB Mem Config Table (ver 1.27): Flash Chip: blocks 0-65535, Chip 0, Sub 0 Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003 User MMC: blocks 16-65535, total = 65520, flags = 0x0003 Bootrom: blocks 0-15 MCT: block 16 OS NV: blocks 17-80, total 64 Apps EFS: blocks 81-208, total = 128 Modem EFS: blocks 209-336, total = 128 Branding: blocks 337-384 OS Fixed: blocks 385-1160 UMP Fixed: blocks 1161-1419, total = 259 FS Fixed: blocks 1420-8207, total = 6788 MMC Enhanced: blocks 16-8207, total 8192 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15170003 0x00000000 RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432 RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432 RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432 CRC: 0x37FA43B9 Using file: 9860[IMEI][WCDMA_900]-6.2.2.21 New IMEI set: 357826044791017 Rebuild Modem EFS ... Done. Completed in 27.948 s |
04-03-2014, 19:13 | #5 (permalink) |
Member: 2077255 Status: Offline Thanks Meter: 15 | Backup secure data & disabled FATFS Connected to USB: 25CB1146227D70AA94F97E8644F2F31C14D643CF Uploading RAM Loader... Done. Attempting to connect to BootImage... BootImage connection successful Scheduling QCFS backup 9900[,290CED69], crc: 0xF28D50D4 Scheduling OSNV backup 9900[290CED69], crc: 0xA7BD5C62 Server version: 1.0 ID: BF01005C balance: 50.0 Connected to USB: 25CB1146227D70AA94F97E8644F2F31C14D643CF Driver: [RimUsb] version: 4.2.0.30, NTMP: 4.2.0.30 Connection status: EHCI:HUB:HUB:USB 2.00 Full-speed Operating system: 6.1.7601.18229 (WoW64) Service Pack 1 - English (United States) User: Rully [SMART-FLASHER] Software: 1.4.0.2829 Serial: BF01005C Connecting to bootrom... Connected. Bootrom: Version: 5.23.0.19 Hardware ID: 0x07001204 (9900) RIM BlackBerry Device Build: ec_agent, Jul 7 2011 14:26:50 Security: Enable Drivers: 0x00000010 LDR Blocks: 0x80014074 Bootrom Size: 0x00020000 Processor: 0x00400001 Flash ID: 0x00000000 HW Version Class: Board Revision: 0018 CPU Version: 0166 SW Compatibility: 0002 POP Revision: 0008 Power Mgt Hardware: 0001 POP Security: 0001 WCDMA Band supported: 0000 BSIS support: 0001 Device variant: 0001 Charger Hardware: 0006 NFC: 0005 Holster Mag Sensor: 0001 Uploading RAM Loader... Done. Attempting to connect to BootImage... BootImage connection successful Requesting BootImage Handshake Device Info: PIN: 290CED69 IMEI: 359683046423299 Vendor ID: 613 - Brightpoint Indonesia/Axis/3-Indonesia/Telkomsel/Indosat/XL Indonesia GUID: 25CB1146227D70AA94F97E8644F2F31C14D643CF Bootrom hash: 6948B0241EB755803691AC218416EBFBB2F6BC14 HW ID Override: None Flash (eMMC): NAND blocks: 0-113039 ID: 0x4508 (******* (4.41)) Page size: 0x00010000 (64 Kb) Total size: 2.90 GB Mem Config Table (ver 1.27): Flash Chip: blocks 0-131071, Chip 0, Sub 0 Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003 User MMC: blocks 16-131071, total = 131056, flags = 0x0003 Bootrom: blocks 0-15 MCT: block 16 OS NV: blocks 17-80, total 64 Apps EFS: blocks 81-208, total = 128 Modem EFS: blocks 209-336, total = 128 Branding: blocks 337-384 OS Fixed: blocks 385-1252 UMP Fixed: blocks 1253-1520, total = 268 FS Fixed: blocks 1521-8207, total = 6687 FS Nand FAT: blocks 8208-131071, total = 122864 MMC Enhanced: blocks 16-8207, total 8192 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15180003 0x00000000 RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432 RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432 RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432 CRC: 0x6F4087BD Disabling FATFS partition ... Done. Completed in 4.693 s |
The Following User Says Thank You to Rully OnTrus For This Useful Post: |
04-04-2014, 09:22 | #6 (permalink) |
Member: 20038 Status: Offline Thanks Meter: 19 | i'm who i'm like eminem said.. i'm who i'm. nope i'm not mxkey team u think. im marketing team of blackberry loader powered by mxkey. alim him self built it from scratch. perhap anyone wanna buy this product can contact me in bbm: 2b3c0eb3 or contact me in gmail: [email protected] |
The Following User Says Thank You to kosuma For This Useful Post: |
04-05-2014, 12:47 | #8 (permalink) |
Member: 20038 Status: Offline Thanks Meter: 19 | version 1.4 build: 2831 UPDATE version 1.4 build: 2831 ADD: Schematics download via Support Files ADD: Default carrier selection for BB10 firmware downloads ADD: 9310,9350 support for zero2 BUGFIX: minor bugfixed and improvements BR MXLover |
The Following 2 Users Say Thank You to kosuma For This Useful Post: |
05-03-2014, 08:04 | #13 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: Indonesia
Member: 919549 Status: Offline Thanks Meter: 132 | Quote:
Yogyaponsel - Flasher-box.com | |
