02-01-2010, 16:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | [F.A.Q] Frequently Asked Questions A. Below is a list of MEP's supported. Server Updated: active MEP2-MEP6 code added. List of Available 221 MEP in the database server (21/09/2010): 1 MEP-04103-001 2 MEP-04103-002 3 MEP-04103-004 4 MEP-04104-003 5 MEP-04104-004 6 MEP-04104-005 7 MEP-04104-006 8 MEP-04104-007 9 MEP-04546-001 10 MEP-04598-003 11 MEP-04598-004 12 MEP-04598-005 13 MEP-04626-001 14 MEP-04626-002 15 MEP-04938-001 16 MEP-04938-002 17 MEP-05277-001 18 MEP-05277-002 19 MEP-05277-004 20 MEP-05277-005 21 MEP-06041-001 22 MEP-06041-003 23 MEP-06041-004 24 MEP-06041-005 25 MEP-06041-006 26 MEP-06041-007 27 MEP-06041-008 28 MEP-06041-009 29 MEP-06068-001 30 MEP-06068-002 31 MEP-06259-002 32 MEP-06259-003 33 MEP-06423-001 34 MEP-06424-001 35 MEP-06424-002 36 MEP-06529-001 37 MEP-06529-002 38 MEP-06530-001 39 MEP-06530-002 40 MEP-06810-002 41 MEP-06811-003 42 MEP-06812-001 43 MEP-06812-003 44 MEP-06813-001 45 MEP-06813-002 46 MEP-06814-001 47 MEP-06814-002 48 MEP-06814-004 49 MEP-06849-001 50 MEP-06849-002 51 MEP-06893-001 52 MEP-06899-001 53 MEP-06899-002 54 MEP-07321-002 55 MEP-07484-001 56 MEP-07484-002 57 MEP-07484-003 58 MEP-07484-004 59 MEP-07484-005 60 MEP-07484-006 61 MEP-07484-007 62 MEP-07705-002 63 MEP-07705-003 64 MEP-07722-001 65 MEP-07722-002 66 MEP-07722-003 67 MEP-07723-001 68 MEP-07723-003 69 MEP-07723-004 70 MEP-07723-005 71 MEP-07754-001 72 MEP-08209-001 73 MEP-08209-002 74 MEP-08209-003 75 MEP-08318-001 76 MEP-08395-001 77 MEP-08448-001 78 MEP-08448-002 79 MEP-08589-001 80 MEP-08881-001 81 MEP-08882-001 82 MEP-08918-001 83 MEP-09004-001 84 MEP-09070-001 85 MEP-09149-001 86 MEP-09292-001 87 MEP-09292-002 88 MEP-09292-003 89 MEP-09292-004 90 MEP-09293-001 91 MEP-09625-001 92 MEP-09667-001 93 MEP-09690-001 94 MEP-09747-001 95 MEP-09783-002 96 MEP-09783-003 97 MEP-09821-001 98 MEP-09821-002 99 MEP-09917-001 100 MEP-09938-001 101 MEP-10073-001 102 MEP-10129-001 103 MEP-10129-002 104 MEP-10129-003 105 MEP-10129-004 106 MEP-10129-005 107 MEP-11016-001 108 MEP-11139-001 109 MEP-11139-002 110 MEP-11139-003 111 MEP-11139-004 112 MEP-11139-005 113 MEP-11139-006 114 MEP-11246-001 115 MEP-11246-002 116 MEP-11414-001 117 MEP-11414-002 118 MEP-11534-002 119 MEP-11534-004 120 MEP-11534-005 121 MEP-11534-006 122 MEP-11534-007 123 MEP-11534-008 124 MEP-12186-001 125 MEP-12209-003 126 MEP-12209-004 127 MEP-12209-006 128 MEP-12209-007 129 MEP-12209-008 130 MEP-12488-001 131 MEP-12565-001 132 MEP-12579-001 133 MEP-12579-002 134 MEP-12599-003 135 MEP-12622-002 136 MEP-12907-002 137 MEP-12978-001 138 MEP-12980-001 139 MEP-12980-002 140 MEP-13188-001 141 MEP-13188-002 142 MEP-13188-006 143 MEP-13188-007 144 MEP-13188-008 145 MEP-13188-010 146 MEP-13710-001 147 MEP-13928-001 148 MEP-13928-002 149 MEP-13988-001 150 MEP-13990-001 151 MEP-14052-001 152 MEP-14052-002 153 MEP-14074-001 154 MEP-14074-002 155 MEP-14074-003 156 MEP-14150-001 157 MEP-14260-001 158 MEP-14260-002 159 MEP-14896-001 160 MEP-14896-002 161 MEP-14896-003 162 MEP-14896-004 163 MEP-14896-005 164 MEP-15159-001 165 MEP-15159-002 166 MEP-15326-001 167 MEP-15326-002 168 MEP-15343-001 169 MEP-16272-002 170 MEP-16272-003 171 MEP-16272-005 172 MEP-16352-001 173 MEP-16419-001 174 MEP-16472-001 175 MEP-16826-001 176 MEP-17232-001 177 MEP-17490-001 178 MEP-17568-002 179 MEP-18601-001 180 MEP-18637-001 181 MEP-19322-003 182 MEP-19877-001 183 MEP-20099-002 184 MEP-20099-004 185 MEP-20099-009 186 MEP-20166-001 187 MEP-20454-001 188 MEP-20669-001 189 MEP-21545-001 190 MEP-22793-001 191 MEP-23361-001 192 MEP-24124-001 193 MEP-24409-002 194 MEP-24660-001 195 MEP-24667-001 196 MEP-24723-001 197 MEP-24723-002 198 MEP-26594-001 199 MEP-26900-003 200 MEP-27488-001 201 MEP-27501-003 202 MEP-28240-002 203 MEP-28364-001 204 MEP-28555-001 205 MEP-29318-001 8 New BLACKBERRY MEP's added 19 September 2010: 206 MEP-06041-010 207 MEP-06812-004 208 MEP-06814-005 209 MEP-07723-006 210 MEP-07723-007 211 MEP-09292-005 212 MEP-09821-003 213 MEP-21878-001 5 New BLACKBERRY MEP's added 20 September 2010: 214 MEP-24667-002 215 MEP-29080-002 216 MEP-30218-001 217 MEP-30218-002 218 MEP-30638-001 3 new BLACKBERRY MEP's added 21 September 2010: 219 MEP-30669-001 220 MEP-31845-001 221 MEP-33006-002 BR. ALIM Last edited by MANOLE; 09-21-2010 at 14:05. Reason: added new MEPs |
The Following 385 Users Say Thank You to Alim Hape For This Useful Post: |
02-04-2010, 09:44 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | [F.A.Q] Frequently Asked Questions Q. I get the an error message when trying to read the code from my BlackBerry as below: SCAN INFO Code: Bootrom info: Version: 5.2.23.1 Hardware ID: 0x84000D03 (RIM 8100 Series Colour GPRS Handheld) Build: Jul 13 2006 10:27:56 (nparthiban) OS info: Version: 2.3.0.83 Hardware ID: 0x84000D03 (RIM 8100 Series Colour GPRS Handheld) Build: Aug 20 2007 13:57:49 (SCM) Product info: IMEI: MEP: ERROR: something went wrong while receiving packet from server! A. Do SCAN to enable fields. Type Manually IMEI + MEP Be very carefully when doing manual input, MEP format should be: MEP-XXXXX-XXX do Calc CODE u will get Unlock CODE if MEP supported. br, Last edited by Gultek; 03-01-2010 at 18:17. |
The Following 39 Users Say Thank You to Andra For This Useful Post: |
02-09-2010, 01:46 | #3 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1230225 Status: Offline Thanks Meter: 545 | [F.A.Q] Frequently Asked Questions Q. How do I manually calculate unlock codes for BlackBerry with just the IMEI & MEP? A. Below is a step-by-step guide: 1. Open 'mobileEx' software 2. Click on Options tab 3. Click on Connect 4. Double click where it says 'BlackBerry Tool' 5. Click on the 'Scan Device' button and all the fields will become enabled 6. Type in the required IMEI 7. Type in the MEP in 'MEP' field like so; MEP-XXXX-XXX 8. Click on 'Calc Code' 9. Wait a few seconds for your code to appear onscreen Note: internet connection required. Last edited by Gultek; 03-01-2010 at 16:57. Reason: updating post. |
The Following 28 Users Say Thank You to Gultek For This Useful Post: |
02-10-2010, 21:08 | #4 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | [F.A.Q] Frequently Asked Questions Q. How do I enter the MEP unlock code to my BlackBerry phone? A. Below are step-by-step instructions (follow the guide best suited for your model). BlackBerry Curve, 8300, 8310, 8320, 8800, 8820, 8900, Bold 9000 1. Insert a non accepted SIM card into the phone and switch it on 2. Turn off the wireless connections by going to the main Menu -> go to 'Manage Connections' -> select 'Turn all connections off' 3. Go back to the main Menu 4. Go to Options 5. Go to Advanced Options 6. Go to SIM Card 7. Type: mepd (you will not see text appear on screen while typing) 8. Type: mep then press the ALT button and number 2 key (so that you get: mep2) (you will not see the text appear on screen while typing) 9. It will say "Enter Network MEP Code, then type in the unlock code, and press in the trackball to confirm 10. Phone will say "Code accepted" 11. Switch the phone off and back on again 12. Turn the wireless connections back on by going to the main Menu -> go to 'Manage Connections' -> select 'Restore connections' 13. You will see at the top of your screen the message "Searching..." 14. After 5-10 seconds your network signal will appear 15. Press the back button until you get to the main screen 16. Your phone is now unlocked and ready to make and receive calls Here is a video tutorial on how to enter the unlock code to your phone: http://www.youtube.com/watch?v=a8YMf3o6rSk BlackBerry Storm 9500 AS ITS A TOUCH SCREEN PHONE PLEASE TYPE CAREFULLY! 1. Insert a non accepted SIM card into the phone and switch it on 2. Turn off the wireless connections by going to the main Menu -> scroll down to Manage Connections -> click on 'Turn all connections off' 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Press the Menu button and select 'Show Keyboard' 7. Type: meppd (you will not be able to see this on screen while typing it in) 8. A lock menu will show 9. Type: mepp2 -- to get the number 2, press the numbers key and all numbers will show up (you will not be able to see this on screen while typing it in) 10. Now it will say "Enter Network MEP Code" 11. Enter the unlock code, and press the enter key 12. The phone will display "Code accepted." 13. Switch your phone off then back on again 14. Turn the wireless connections back on by going to the main Menu -> go to 'Manage Connections' -> click on 'Restore connections' 15. You will see at the top of your screen the message "Searching..." 16. After 5-10 seconds your network signal will appear 17. Press the back button until you get to the main screen 18. Your phone is now unlocked and ready to make and receive calls Here is a video tutorial on how to enter the unlock code to your phone: http://www.youtube.com/watch?v=l0fWf5UoF6E BlackBerry 8700 Go to the Menu -> Options -> Advanced Options -> Sim card press select, while holding the Shift key (bottom right corner CAPS), type mepd. You should now see the five locking categories listed, while holding the alt key, type mep2. Release the alt key. You are now prompted to enter the Network MEP code. Enter the code, enter Return/Enter, the device should then be unlocked. BlackBerry 8800 ***** You must have a SIM card in your phone to complete these steps (Can be active or inactive) ***** 1 - Go to settings menu => and then Options 2 - Select Advanced options => and then Sim card 3 - Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) 4 - Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) 5 - You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code and press in the track wheel / jog dial to confirm 6 - Your phone is now unlocked BlackBerry 8100 Pearl 1. Go to Menu, then Options then Advanced Options then Sim Card 2. In the SIM Card menu, hold down the shift (it has # on it known as the CAP key) (right of the zero key) and press meppd 3. You will see the unlocking level screen (Network, Network Subset, Service Provider, Corporate). The Network lock will say Active, meaning its locked 4. Now hold the ALT key (key with arrow going up and down) and type mepp2 5. A window will appear on screen showing "Enter Network MEP code (255 left)" 5. Now enter the unlock code and press in the trackball 6. It will say "Code accepted" 7. The unlocking level screen will say "Network Disabled" 8. Now restart your phone, and your ready to go BlackBerry 8100 (Vodafone Australia) PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below 1. Take note of the unlocking code shown above 2. Insert a Non-Vodafone Australia working SIM card. 3. Ensure the phone is charged and then switch the phone on. 4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below) 5. The phone will then display a message. The most common is “Invalid SIM card”. (Different message? See FAQ below) 6. Select “Turn Wireless Off” 7. Select “Settings” Menu , then go to Advanced Options > SIM Card 8. Type alt-MEPT by holding the ALT-key and typing the letters MEPT with multitap i.e. type hold ALT, type {M}{ER}{OP}{OP}{TY} 9. When prompted with “Enter Network MEP code (255 left)” on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter. 10. Reset the phone by pulling the battery 11. Switch the phone on and the handset will be unlocked automatically. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) Please Note: If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10 seconds increments. The number of unlocking attempts is limited to 255 tries only. When 255 attempts is reached the phone will be permanently blocked. To unblock the phone, it must be taken to a RIM service centre. No outgoing calls including emergency call is possible when the phone is blocked. FAQ: Question: My phone asks to enter a PIN number Answer: For SIM cards with PIN ENABLED you will be required to enter a PIN. This is not the unlocking code that has just been provided. For information concerning the PIN, PIN2, PUK and PUK2 codes for a SIM card please read the manual that came with your phone. This is not a handset unlocking difficulty. Question: My handset displays a different message then what is shown in this procedure when I insert a Non Vodafone Australia SIM card. Answer: The most common message the phone will display is “Invalid SIM card”. Because each handset may have a different variation in software there is no common message. If your handset displays a different message it is recommended to move onto the next step. Note: Faulty SIM Cards - The handset may also display messages indicating the SIM you are using to unlock the handset is faulty, it could display “Insert SIM” “Bad Card”, “Card Error” or “Card Rejected”, confirm the SIM card is inserted correctly – Gold area downwards and the cut of the corner matches correctly. You will need a working Non Vodafone SIM card to unlock the handset, Vodafone can not assists with other networks faulty SIMs. All other BlackBerry models 1 - Using the menu go to Settings Menu -> SIM card pressselect. 2 - While holding the SHIFT key, type mepd 3 - You should now see the five locking categories listed. 4 - While holding the SHIFT KEY, type mep2. 5 - Release the shift key. 6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left) 7 - Enter the code 8 - Enter Return/Enter 9 - The device should then be unlocked Br. GsmEasy Last edited by Gultek; 03-01-2010 at 11:42. Reason: updated instructions |
The Following 45 Users Say Thank You to GsmEasy For This Useful Post: |
03-01-2010, 01:02 | #5 (permalink) |
Member: 1230225 Status: Offline Thanks Meter: 545 | [F.A.Q] Frequently Asked Questions Q. MXKEY BlackBerry software is not able to read the MEP from my phone, is there an alternative? OR; Q. I would like to start selling BlackBerry unlock codes, is there a way my customers will be able to read MEP info from their phone? A. Below is a guide on how to read the IMEI & MEP from a BlackBerry phone. For Windows XP / Vista users:
For Macintosh users:
The Following 49 Users Say Thank You to Gultek For This Useful Post: |
03-02-2010, 02:12 | #6 (permalink) |
Member: 1230225 Status: Offline Thanks Meter: 545 | [F.A.Q] Frequently Asked Questions Q. How can I find my phone's MEP without having to physically connect it to a program? A. Follow the step-by-step guide below:
Note: when typing in your phone's info to the calc, for the 'App Version' include spaces and brackets. For 'Uptime', enter the numbers only, not 'secs'. Last edited by Gultek; 03-02-2010 at 03:01. |
The Following 43 Users Say Thank You to Gultek For This Useful Post: |
03-06-2010, 21:24 | #7 (permalink) | |
Member: 1230225 Status: Offline Thanks Meter: 545 | [F.A.Q] Frequently Asked Questions Q. Can I flash BlackBerry phones with MXKEY? A. No. Q. Can I remove the security code/password from BlackBerry phones with MXKEY? A. No. Q. Can MXKEY fix code counter block (0) on BlackBerry phones? A. No. Q. Can MXKEY read/calculate all MEP locks? A. Yes, it reads:
For above example you would enter the mep like this: MEP-07484-004 Last edited by Gultek; 09-25-2010 at 12:28. | |
The Following 35 Users Say Thank You to Gultek For This Useful Post: |
F.A.Q., Contacts, Supported models, Cables/pinouts | InfinitySupport | Infinity-Box | 7 | 08-05-2015 15:57 |
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 4 | 03-23-2011 08:03 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | Mohsin-* | FuriousGold | 0 | 11-10-2008 16:00 |
Frequently Asked Questions | SoftMobile | MT-BOX | 47 | 12-21-2007 10:03 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 0 | 08-02-2007 20:08 |
