Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Blackberry Flasher and Unlocker (by Alim Hape)
Old 03-28-2010, 20:07   #1 (permalink)
AllGsmStore's Avatar
Member: 99509
Sonork: Whatsapp +971508482353
Thanks Meter: 210
how to enter network code blackberry 9630 (Answered)
please help me
how to enter network code (blackberry 9630)
i try MEPPD or MEPD & MEP2 or MEPP2
Old 03-28-2010, 20:16   #2 (permalink)
zolla's Avatar
Member: 175544
Thanks Meter: 198
1. Ensure the SIM Card that came pre-installed in the Blackberry is inserted
2. Go to 'Manage Connections'
3. Click on 'Turn All Connections Off'
4. Go back to 'Options'
5. Click on 'Advanced Options'
6. Click on 'SIM Card'
7. Type 'MEPD' (letters will not appear on-screen but a menu will pop up)
8. Type 'MEP2'
9. You will be prompted to enter the MEP code (Unlock Code)
10. Enter the unlock code (phone will show "code accepted")
11. Reboot the phone
12. Go to Manage connections --> select "restore connections"
The Following User Says Thank You to zolla For This Useful Post:
Old 03-28-2010, 20:20   #3 (permalink)
Member: 99509
Thanks Meter: 210
sir try this no working
please tell me what to do now
Old 03-28-2010, 20:22   #4 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Try this will work fine:-
USE MEPPD INSTEAD OF MEPD AND USE MEPP2 INSTEAD OF MEP2
And be sure to hold alt button while entering digit 2 as if you will not press and hold alt button it will be entering alfa instead of numeric.
Post result.
Old 03-28-2010, 20:25   #5 (permalink)
Member: 99509
Thanks Meter: 210
no work br
i hold (aA button &alt button) no work
Old 03-28-2010, 20:34   #6 (permalink)
zolla's Avatar
Member: 175544
Thanks Meter: 198
try this
1. Using the menu go to Settings Menu -> SIM card press select.
2. While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3. You should now see the five locking categories listed.
4. While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5. Release the shift key.
6. You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7. Enter the code
8. Enter Return/Enter
9. The device should then be unlocked
Old 03-29-2010, 16:10   #7 (permalink)
fflyx's Avatar
Member: 1208833
Sonork: 100.1590402
Thanks Meter: 142
no work br
For this model, First, You have to insert a Sim Card
Old 03-30-2010, 08:52   #8 (permalink)
IAMJASONBOURNE's Avatar
Member: 1162191
Thanks Meter: 281
If it's a Sprint 9630 it's probably already unlocked.
Old 03-31-2010, 18:18   #9 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
please help me
Hello Br....
There two main steps to unlock
All the codes are
1 is the code of MEPPD or MEPD
2 nd is the code of MEP2 or MEPP2
to do this just go to compos sms and type those letters and conform that appear on the screen correctly If not find the way how to enter that code (MEPPD or MEPD & MEP2 or MEPP2) but U must enter the code as motioned in the FAQ....(eg:like press shift & enter MEPD)
Once the way in the FAQ is Right Ur set must unlock...Other way U can easily identify how to enter those code... (in the SMS)
Read my post carefully and try...If can not yhen post the proble clerly.
I tried to explan as much as I can.
Hope will help U
Old 05-10-2011, 02:50   #10 (permalink)
Member: 1573169
I held the shift key down while entering MEPD and was able to get to the first menu, but I am unable to get to where I enter the code, even while holding the shift key or while entering MEP2 or MEPP2. Can someone please advise me what to do next? Thank you
Old 05-17-2011, 11:35   #11 (permalink)
Member: 856869
Sonork: +37744510000
Thanks Meter: 30
the same problem i have right now i unlock more black berry bot for me is first problem to unlock this blackberry
How to Enter Unlock Code in a BlackBerry 7230 ? gsmfactory BlackBerry (RIM) 15 09-22-2012 02:18
myW-7 HOW TO ENTER NETWORK CODE Nasmi Gsmfather The Wholesale Unlocking Database 7 09-03-2009 11:32
myW-7 HOW TO ENTER NETWORK CODE Nasmi ARM9 BASED M62 / M62+ 0 03-31-2008 13:05
--Blackberry 7730,How to enter unlock code? softmaster BlackBerry (RIM) 6 07-25-2005 04:27
Page generated in 0.18419 seconds with 10 queries
