08-29-2011, 09:56 | #1157 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Black Berry 8900 Unlock Done IMEI: 355383031828537 MEP: MEP-06424-002 MXKEY Serial: C0818C85 MEP2(Network,Active,3,10): 4228527814819575 MEP3(Network Subset): 8159037413460053 MEP4(Service Provider): 7826724115258393 MEP5(Corporate): 9523006774169291 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. BlackBerry Smartphone detached. |
The Following 2 Users Say Thank You to Sahil2007 For This Useful Post: |
09-09-2011, 20:05 | #1166 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1651911 Status: Offline Sonork: mapc Thanks Meter: 0 | Unlock Code for blackberry Torch 9530 Could yo help me with the MEP2 code to unluck my phone Blackberry Torch 9530 IMEI: 980003003337498 MEP: MEP-24667-001 Thanks! |
[REPORTS] Post here sucessfully unlocked HTC phones by MXKEY | gsm goa | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 227 | 10-11-2020 00:49 |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3969 | 10-05-2016 05:13 |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
[MXKEY - INFO] Successfully Unlocked/repaired Phones By MXKey | kamranas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-12-2010 10:55 |
