11-15-2011, 19:26 | #1186 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 464 | her another one 9000 unlock done Code: IMEI: 359614024424702 MEP: MEP-04598-005 Factory Lock State: CLOSED MXKEY Serial: C08****** MEP2(Network,Active,6,10): 4725944849135212 MEP3(Network Subset): 6910570596303431 MEP4(Service Provider): 3190288040275315 MEP5(Corporate): 4650886923271169 |
11-15-2011, 20:00 | #1187 (permalink) |
Member: 98928 Status: Offline Thanks Meter: 464 | and another one 9000 unlock done her the log: Code: IMEI: 980041001452307 MEP: MEP-04598-005 Factory Lock State: CLOSED MXKEY Serial: C08****** MEP2(Network,Active,6,10): 7595784461080417 MEP3(Network Subset): 1762955787951912 MEP4(Service Provider): 2109193345573975 MEP5(Corporate): 9215094841624974 |
11-18-2011, 09:31 | #1188 (permalink) |
Freak Poster Join Date: Mar 2011 Location: m + koti hyd 95
Member: 1532828 Status: Offline Thanks Meter: 77 | blackberry 8520 unlocking done IMEI: 355931030743469 MEP: MEP-08209-003 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.8 MEP2(Network,Active,0,10): 4349644786706978 MEP3(Network Subset): 3012384175574269 MEP4(Service Provider): 0158713052295947 MEP5(Corporate): 5507840460687556 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. |
The Following User Says Thank You to mobile+plus For This Useful Post: |
11-20-2011, 16:06 | #1189 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Black Berry 8520 Unlock Done IMEI: 357827048603497 MEP: MEP-06814-005 Factory Lock State: CLOSED MXKEY Serial: C0818C85 MEP2(Network,Active,3,10): 0430255133063228 MEP3(Network Subset): 6883228664696142 MEP4(Service Provider): 6547691243371576 MEP5(Corporate): 1431679583991500 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
The Following 2 Users Say Thank You to Sahil2007 For This Useful Post: |
11-20-2011, 16:07 | #1190 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Black Berry 8220 Unlock Done IMEI: 356587029521586 MEP: MEP-04104-007 Factory Lock State: CLOSED MXKEY Serial: C0818C85 MEP2(Network,Active,19,10): 4982576707076977 MEP3(Network Subset): 2740659758041140 MEP4(Service Provider): 7858209765967536 MEP5(Corporate): 1740851950339914 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. BlackBerry Smartphone detached. |
The Following User Says Thank You to Sahil2007 For This Useful Post: |
11-22-2011, 11:13 | #1191 (permalink) |
Member: 98928 Status: Offline Thanks Meter: 464 | blackberry 9530 unlock done her the log: IMEI: 352110030646252 MEP: MEP-15326-001 Factory Lock State: CLOSED MXKEY Serial: C0****** MEP2(Network,Active,1,10): 3892403036387796 MEP3(Network Subset): 4760706019261599 MEP4(Service Provider): 6806060118324939 MEP5(Corporate): 4243270869493849 |
11-22-2011, 11:26 | #1192 (permalink) |
Member: 98928 Status: Offline Thanks Meter: 464 | another blackberry unlock done her the log: Code: IMEI: 355021036531603 MEP: MEP-13188-010 Factory Lock State: CLOSED MXKEY Serial: C0****** MEP2(Network,Active,23,10): 9265899956289349 MEP3(Network Subset): 8888999855950452 MEP4(Service Provider): 7164102648095602 MEP5(Corporate): 6484526604840161 |
12-12-2011, 08:39 | #1193 (permalink) |
Member: 1532828 Status: Offline Thanks Meter: 77 | blackberry 9700 unlocking done IMEI: 357360039643942 MEP: MEP-04598-005 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.9 MEP2(Network,Active,0,10): 2045904516541290 MEP3(Network Subset): 2495010202877177 MEP4(Service Provider): 2957353758872793 MEP5(Corporate): 1744293575143793 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. |
12-15-2011, 11:22 | #1195 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | unlock done blackberry IMEI: 353872040226107 MEP: MEP-04626-002 Factory Lock State: CLOSED MXKEY Serial: C085DF47 MEP2(Network,Active,1,255): 55180613 MEP3(Network Subset): 1293670195128291 MEP4(Service Provider): 1555282527317432 MEP5(Corporate): 3564643333424529 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
01-02-2012, 18:08 | #1196 (permalink) |
No Life Poster Join Date: Mar 2007 Location: GREENHILLS
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | BB 8520 network unlock. Problem: Network Lock/GLOBE Tools: HTI MXBOX and USB mini cable Procedure: 1)Open latest mobileEX and connect blackberry smartphone. 2)connect device to PC w/ USB and click Scan Device.. 3)Sundan nyo nlng ang picture na nasa baba for Unlocking. Unlock Done. |
The Following User Says Thank You to DEADBOOT For This Useful Post: |
02-28-2012, 05:42 | #1198 (permalink) | |
Junior Member Join Date: Feb 2011 Location: Makati Age: 43
Member: 1514388 Status: Offline Sonork: jamesprogram32 Thanks Meter: 22 | BlackBerry 8900 Problem : Lock to Globe Telecom Action Taken : Unlock by MxBox Tools : MxBox, Micro USB Procedure Turn ON your phone. Open MxBox SW Insert USB Cable thru your phone. see this Logs Quote:
Success code.. james | |
04-15-2012, 13:34 | #1199 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | Blackberry 8520 successful unlock IMEI: 355986045039121 MEP: MEP-04103-001 Factory Lock State: OPEN MXKEY Serial: C085DEC5 MEP2(Network): 6962154841213141 MEP3(Network Subset): 5176413910937428 MEP4(Service Provider): 6124937264241060 MEP5(Corporate): 2841424566870346 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level (2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4 Br: Qasir Ali Khan |
[REPORTS] Post here sucessfully unlocked HTC phones by MXKEY | gsm goa | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 227 | 10-11-2020 00:49 |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3969 | 10-05-2016 05:13 |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
[MXKEY - INFO] Successfully Unlocked/repaired Phones By MXKey | kamranas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-12-2010 10:55 |
