Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1201 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1586890 Thanks: 48
| IMEI: 354910044541581 MEP: MEP-13188-010 SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.3 MEP2(Network,Active,0,10): 1555722363351514 MEP3(Network Subset): 3234771030170984 MEP4(Service Provider): 2826369478385452 MEP5(Corporate): 0200712379977274 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. BlackBerry Smartphone detached. |
| | #1205 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 35
Member: 591325 Status: Offline Thanks: 38
| IMEI: 356028028911437 MEP: MEP-07723-005 Factory Lock State: CLOSED MXKEY Serial: C0856AA0 MEP2(Network,Active,33,10): 4189862148694844 MEP3(Network Subset): 4838230528073249 MEP4(Service Provider): 9940895210843328 MEP5(Corporate): 5583102791748794 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and "2" NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code(4189862148694844) and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
| | #1208 (permalink) |
| Major Poster ![]() ![]() Join Date: Sep 2007
Member: 579725 Status: Offline Thanks: 24
| IMEI: 351515058755580 MEP: MEP-07723-007 SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.4 MEP2(Network,Active,0,10): 5481939531211048 MEP3(Network Subset): 0355967769650575 MEP4(Service Provider): 1377236359411061 MEP5(Corporate): 3907845278612902 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
| | #1211 (permalink) |
| IMEI: 010194005675508 MEP: MEP-06813-001 Factory Lock State: CLOSED MXKEY Serial: C0856AA0 MEP2(Network,Active,1,10): 0396404766197711 MEP3(Network Subset): 9081734395166075 MEP4(Service Provider): 6059937138236189 MEP5(Corporate): 5065062661708061 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and "2" NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code(0396404766197711) and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
| | #1213 (permalink) |
| IMEI: 353487045656602 MEP: MEP-09292-004 Factory Lock State: CLOSED MXKEY Serial: C0856AA0 MEP2(Network,Active,28,10): 7581800330503091 MEP3(Network Subset): 9474006019710909 MEP4(Service Provider): 4407993129389392 MEP5(Corporate): 8716529164860531 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and "2" NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code(7581800330503091) and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. BlackBerry Smartphone detached. |
| | #1215 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 48
Member: 296918 Status: Offline Thanks: 185
| 9380 Telcel unlocked 9380 from Telcel Mèxico unlocked via "No conection" enter imei:xxxxxxxxxxxxxxxx enter MEP: MEP-30669-001 Code generated. Insert a simcard from another company and the phone will ask for code, enter code and enjoy. B.R. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| MXKEY - Successfully Unlocked/repaired/flashed Phones By MXKey | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3844 | 04-22-2013 08:30 |
| [REPORTS] Post here sucessfully unlocked HTC phones by MXKEY | mahadeo | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 222 | 10-31-2012 11:25 |
| Post here successfully unlocked a2 phones | elsheikh | SETool2 | 10 | 03-04-2011 01:48 |
| [MXKEY - INFO] Successfully Unlocked/repaired Phones By MXKey | kamranas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-12-2010 09:55 |
