06-06-2011, 21:12 | #16 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: VENEZUELA
Member: 1462177 Status: Offline Sonork: Skype: arleanjose Add me! Thanks Meter: 333 | Quote:
IMEI: 351768026020161 MEP: MEP-09292-001 SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 83948532 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. PRESS THANKS BUTTON | |
The Following 5 Users Say Thank You to arleanjose For This Useful Post: |
06-07-2011, 11:03 | #22 (permalink) | |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | Quote:
MEP: MEP-04104-007 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 7021163991700583 MEP3(Network Subset): 6396850198384164 MEP4(Service Provider): 9177299499490635 MEP5(Corporate): 1516679904020093 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. | |
The Following 2 Users Say Thank You to GsmEasy For This Useful Post: |
06-07-2011, 11:05 | #23 (permalink) |
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | BB module version: 1.02 IMEI: 353486047155043 MEP: MEP-07723-005 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 7841706534525415 MEP3(Network Subset): 7975594630760357 MEP4(Service Provider): 3662612506628467 MEP5(Corporate): 4331665900958717 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
06-07-2011, 11:08 | #24 (permalink) | |
MEP: MEP-07754-001 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 4260957859229564 MEP3(Network Subset): 6822634971941658 MEP4(Service Provider): 3044764447805673 MEP5(Corporate): 2086890319216319 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. | |
06-07-2011, 11:10 | #25 (permalink) | |
MEP: MEP-07723-005 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 7495222561772394 MEP3(Network Subset): 6098618204869668 MEP4(Service Provider): 0449484985085912 MEP5(Corporate): 5361230551765153 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. | |
06-07-2011, 15:38 | #28 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1517716 Status: Offline Thanks Meter: 0 | I knew that the administrator of this site prevented mep2 codes given away (for some reason). Is this true or can i request in this forum? thanks anyway for all the help that gave this page |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
