06-08-2011, 05:39 | #44 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | IMEI: 359089017279936 MEP: MEP-15326-002 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 06441717 MEP3(Network Subset): 9746132328894582 MEP4(Service Provider): 5638492254759874 MEP5(Corporate): 7724709434116289 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
06-08-2011, 05:41 | #45 (permalink) | |
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | Quote:
MEP: MEP-04104-007 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 7348017296774935 MEP3(Network Subset): 9057755512129636 MEP4(Service Provider): 6709450898904163 MEP5(Corporate): 7355267019527034 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
