Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
01-29-2013, 15:04 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | 2.3 Gingerbread secret Codes :) *#0011# network mode/cell info/power info hidden menu *#*#4636#*#* for battery and other general setttings like GSM/CDMA *#*#8255#*#* for Gtalk service monitor *#*#7780#*#* for factory data reset *#*#34971539#*#* for information about phone camera (be very careful hitting options here) *#*#7594#*#* change the "Power" button action in your phone. *#*#197328640#*#* service mode *#197238640# service mode *#0*# testing mode *#1234# display phones current firmware *#*#1472365#*#* gps test (work on 2.2) *#0011# network mode/cell info/power info *#*#0*#*#* screen test menu *#7465625# engineering mode *#3214789650# gps service menu for JP3 fw *#9900# Sysdump screen.. way to dump ram and other logs to sd card *2767*3855# FACTORY DATA WIPE AND internal SD RESET as soon as you enter # use only if you want wipe your phone *#*#273283*255*663282*#*#* Opens a File copy screen where you can backup your media files *#*#3214789650#*#* - GpsSetup2 *#7284# - UART and USB options *#1234# - Version *#06# - view IMEI number *#*#4636#*#* - usage stats and device info *#9090# - service mode UART and USB /slightly different form the 7284 one/ *#9900# - sysdump /if you dont know what it means, probably you won't need this one / *#03# - NAND flash unique number *2767*3855# - hard reset *#*#7780#*#* - factory data reset *#0*# - testing mode *#*#4636#*#* - Usage stats and device ingo *#0782# - Real Time Clock *#0011# - GSM status *#*#197328640#*#* - Servicemode, Debug, Netz, Audio, Common *#7465625# - Engineering mode *#2263# - Band selection *#232337# - Bluetooth adress *#*#232331#*#* - Bluetooth test *#*#232338#*#* - WLAN-MAC address *#*#2663#*#* - Touchscreen Firmwareversion *#*#2664#*#* - Touchscreen test *#*#0588#*#* - Proximity test *#0842# - Vibrator test *#0228# - Batery stats *#0673# - Audiotestmenu *#*#8255#*#* - Gtalk service monitor *#*#7594#*#* - Powerbutton settings *#07# - Test history *#32489# - Ciphering info *#0589# - Light sensor read *#272886# - Enable/Disable auto answer *#301279# - Switch 3G - HSPA Br |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
