Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Q-Mobile
Old 07-16-2013, 07:53   #46 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
ROM collection for Qmobile Noir A10
[IMG]http://2.bp.********.com/-e_barr10kgk/UTx22F0ZgrI/AAAAAAAAAM4/whD6suOzMn4/s320/Qmobile+Noir+A10+with+Jelly+Bean+2.jpg[/IMG]
Greetings Fellow Pakistanis,
I have put together a collection of stock and custom ROMs for Qmobile Noir A10. Just flash them via CWM recovery and enjoy. The lists of the ROMs are given below.
Qmobile Noir A10 Stock ROM - download
JMP v6.0 Jelly Bean ROM 4.1.1- download
Jelly Bean ROM 4.1.1 - download
JMP "Killer ROM" Ice Cream Sandwich 4.0.4 - download
LeWa OS - courtesy of IncPak.com - download
Google Apps Package (Gapps) - download *if there are not google apps in ROMs (play store, play music, gmail, etc.) flash this with your CWM recovery
Old 07-16-2013, 08:18   #47 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
Originally Posted by IQA_SHAHEEN View Post
bro plz post another link this link not working
regards
iqa_shaheen
Originally Posted by Faheem Anjum View Post
Jelly Bean For Noir A8
[IMG]http://4.bp.********.com/-m6hyLts9JJI/UWUM-_dMJ8I/AAAAAAAAAJg/uaUGttqfj4E/s640/android-jellybean.jpg[/IMG]
Download from here :http://rapidshare.com/files/29375870...BeanNoirA8.zip
Qmobile_NoirA8_update V1.1 Room From SameerA.zip
Old 07-20-2013, 01:07   #48 (permalink)
Member: 1982327
Hey.....Assalam o Alaikum..........
can u plz guide me how to install clockwork recovery mod for my qmobile noir a5 classic........and also a custom rom for it... thanks
Old 07-20-2013, 08:49   #49 (permalink)
BackOFF's Avatar
Member: 583290
Thanks Meter: 107
i have prob with Q mobile a11 noir.
its on recovery mode always.after reboot still hangs on same screen.
need help plz.
how to possible flash on stock rom.
Old 07-27-2013, 11:49   #50 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
QMobile A10 Noir - Jelly Bean Update 4.1.1
New Jelly Bean update for QMobile Noir A10 (14-03-2013)
Guys ! The Auto Rotate Issue Has Been Fixed in Jelly Bean Rom u Can Download it from the following link.
download :https://docs.google.com/file/d/0ByNS...it?usp=sharing
QMobile Noir A10
How To Root QMobile A10 Noir
First of all Lets start with the root process.
1. Download the following file.
MediaFire - Online Space for your documents, photos, videos, and music.
2. Enable USB Debugging on your device to do that goto Settings>Development>USB Debugging
3. Connect your device to any laptop/PC and How to install drivers for any Android device on Windows - Droidiser | Android + Tech
4. Unzip the root tool downloaded above.
5. Change the Mode of your device from USB Storage to Media Device to proceed further.
6. Run the Runme.bat file as shown below.
[IMG]http://2.bp.********.com/-4dfOzH7o-P4/UJJuSjqM-qI/AAAAAAAABxI/75mvrIiWHdU/s1600/Rooting_micromax+a110.JPG[/IMG]
7. A command prompt with green letters will come up on your screen.
8. Follow the onscreen instructions carefully. To start off, you willl need to type in a "1" and press enter.
Note: If you ever want to Unroot your QMobile A10, follow the above steps till you reach this one and then, instead of typing "1", type "x" and hit enter. Follow the instructions that appear on the command prompt after that.
[IMG]http://1.bp.********.com/-HNiBHdukhgU/UJ4ebK64QLI/AAAAAAAACAg/xbzIXHRgyHM/s640/root_bin4ry_command_prompt_micromax_a110.png[/IMG]
9. Your device will reboot during the process after which Bin4ry will copy some files to your device.
10. When the green letters in the command prompt says Have Fun!, then... Have fun.
That means, your device is rooted now and you can enjoy Superuser permissions!
Install CWM Recovery on QMobile Noir A10
[IMG]http://4.bp.********.com/-GySO3j04yDc/UMmzZxKJJ-I/AAAAAAAACnM/V52PEXMey74/s1600/Micromax+A110+stock+and+clockworkmod+recovery.jpg[/IMG]
1. Download cwm recovery from the given link cwm_Recovery_QMobile_Noir_A10
2. Extract it, rename it to recovery.img & transfer it to the root of your SD Card.
3. Download and install MobileUncle MTK Tools from Google Play Store and run it.
4. Select the option recovery update from the application and when it ask for path guide it to the location where u copied the downloaded recovery file.
[IMG]http://4.bp.********.com/-bOOaEGL_gTs/UMmcuXJTUUI/AAAAAAAACmI/669Hs-dExsw/s640/Flash+recovery+using+Mobileuncle+Tools.jpg[/IMG]
5. It will install and upon successfull installation it will ask you to reboot into recovery, select OK to go to newly insalled cwm recovery to confirm the installation.
6. If anything goes wrong you can download and install Stock Recovery For QMobile Noir A10 by using the above mentioned process again to revert back all the changes.
[IMG]http://3.bp.********.com/-DtS252Q7zS4/UKiRZV9hQmI/AAAAAAAACOk/9Ib0ncJOa_Y/s1600/gpstest.jpg[/IMG]
GPS Fix For QMobile Noir A10 for faster Lock
1. First of all you need a rooted QMobile Noir A10.
2. Download the modified gps.conf file from Here.
3. Browse to system/etc using root explorer and mount the system as read / write using the button present on top right of screen.
4. You will find a file gps.conf already present in the folder. Rename that file to gps.conf.bak, it will act as a backup for the original file.
5. Unzip the file you downloaded in Step 2, and copy the extracted gps.conf file to system/etc.
6. Reboot your Qmobile Noir A10.
7. Download GPS Test from Google Play Store and test your GPS now. (activate your gps first)
You will notice the improvement in getting GPS Lock Now.....
Enjoy............
plz check some link dead
Old 07-29-2013, 10:48   #51 (permalink)
Member: 1988677
I think the official firmware is better than the custom.
Old 08-09-2013, 15:14   #52 (permalink)
Member: 1374087
Sonork: waqar0333
Also Need QMOBILE A5 (not Classic) Boot Image!!
QMobile A5 Hang or Recovery mode!! Need Boot Image
Old 08-10-2013, 22:56   #53 (permalink)
Member: 1374087
Sonork: waqar0333
Need Qmobile A5 Boot Img
send me qmobile a5 boot img, i send you whole rom
Old 08-18-2013, 07:39   #54 (permalink)
johnysofts's Avatar
Member: 319956
Thanks Meter: 124
qmobile s10 firmware
i need qmobile s10 hard reset solution or firmware
thanks
Old 08-22-2013, 17:37   #55 (permalink)
Member: 2008321
Thanks Meter: 2
i have rooted my Q mobile A 10 and when i start then MTK Tools and select update recovery it demand reboot after reboot it should go to CWM Recovery but it Blanks out and Turn Off... have to restart again.. Plese Help me out
Old 08-24-2013, 10:44   #56 (permalink)
Member: 1374087
Sonork: waqar0333
Great Work Faheem Bhai
Please Post Qmobiel A5 Rooting Medthod or CWM Recovery Img!! Thanks
Old 08-26-2013, 13:16   #57 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 500
same problem with me
Old 08-26-2013, 16:29   #58 (permalink)
Member: 1374087
Sonork: waqar0333
Make Qmobile A5 Custum Rom, Here is stock and root rom avaliable and other alll sttuf
Wakndroid: Qmobile A5 finally Rooted - stock and root rom avaliable
Old 08-27-2013, 08:43   #59 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
Brother please share Q mobile A2 lite flash file.
Regards
Old 08-27-2013, 08:58   #60 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,087
Regards
flash with micromax a27 your mobile 1000% ok
The Following User Says Thank You to Umesh_Arora For This Useful Post:
Page generated in 0.22997 seconds with 9 queries
