Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 07-17-2012, 20:04   #1 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
ALL Android Hard Reset
Sprint Motorola XPRT Hard Reset Procedure
Here's the the steps and procedure on how to hard reset the Motorola XPRT (Sprint) with Android OS, v2.2 (Froyo) packed with 1 GHz ARM Cortex-A8 processor, PowerVR SGX530 GPU, TI OMAP3620-1000 chipset.
[IMG]http://1.bp.********.com/-i6LUiFmcXQE/TdYBVWebphI/AAAAAAAAAag/CwwmpjO6qro/s1600/Motorola-XPRT-+hard+reset.jpg[/IMG]
This solution may help fix abnormal errors on device such as hang or frozen.
Just make sure to have a back up copy of all important data on the device before proceeding for this process will result to delete and wipe all data installed from the Motorola XPRT .
Motorola XPRT Factory Reset through Menu Settings:
From the main HOME SCREEN
->select MENU
->select SETTINGS
->select PRIVACY
->select FACTORY DATA RESET
->select RESET PHONE
->Enter PASSWORD if prompted
->select ERASE EVERYTHING
Motorola XPRT Hard reset through button combination, this will prompt you into recovery mode.
this may help if the Motorola XPRT is frozen,hang or unresponsive.
1. Turn the power off or remove the battery and reinsert it back again after a couple of seconds.
2. Press and hold the POWER+CAMERA buttons at the same time
3. Release the Camera button when prompted
4. Press and hold the Volume Down key
5. It will show A yellow exclamation
6. Select the Wipe data/factory reset (Alt + W) option
That's it...
Old 07-17-2012, 20:06   #2 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
HTC Sensation 4G (T-Mobile USA) Hard Reset to Factory Default Settings
Here's a step by step instructions on how to hard reset the HTC Sensation 4G.
Precautions: Performing hard reset process will delete or wipe all data from the. We highly recommend to have a back up copy of all your important files stored on the device.[IMG]http://4.bp.********.com/-pU68N6A1kK4/TdYFx19Y2JI/AAAAAAAAAak/WlCpXHQG7n4/s1600/htc-sensation-4g+hard+reset.jpg[/IMG]
HTC Sensation 4G Factory/Soft Reset:
On the main Home Screen,
->select MENU
->select SETTINGS-> PRIVACY
->Enter the password
If the HTC Sensation 4G is frozen: Reboot or restart the phone and do a hard reset through button combination, this will turn the device into recovery mode.
1. Turn the power off. , remove the battery out and reinsert it back again
2. Hold the Volume Down and Power Button together
3. A menu will then show up such as Fastbook, Recovery, Clear Storage, and Simlock
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Select: Volume Up for YES and Volume Down for NO
- Wait 'till the phone reboot.
Once the wipe process completes, the HTC Sensation 4G will return to its original factory fresh state default settings. All data including third-party applications will be deleted from the HTC Sensation 4G.So you may need to re-install it back again
Old 07-17-2012, 20:08   #3 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
Motorola DROID X2 Daytona (VERIZON) Hard Reset Guide
Motorola DROID X2 (also called Motorola Daytona) Hard Reset to Factory Default Settings.
In this guide we show you how to hard reset the Motorola DROID X2 with step by step instructions.
Motorola DROID X2 Factory/Soft Reset:
[IMG]http://4.bp.********.com/-6zWgcpV73eA/TdYNcz33M0I/AAAAAAAAAao/LwzJ8XxGags/s320/Motorola-Droid-X2-Daytona+hard+reset.jpg[/IMG]
->select MENU
If the Motorola DROID X2 is frozen: this may sometimes occurs when running multiple applications and the device become unresponsive, you may fix this by rebooting the device or removing the battery for a while. But if the problem still persist you may need to full factory reset the device.
Motorola DROID X2 Hard Reset through button combination for sever freezing problem., this will prompt you into recovery mode.
5. It will show A yellow exclamation display
Wait 'til the phone completely reboots. That's it...
Old 07-17-2012, 20:10   #4 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
How to Hard Reset Samsung Galaxy Y S5360 reformat to factory default settings
Here's the procedure on how to restore back or hard reset the Samsung Galaxy Y S5360 to it's original factory default settings. This process is useful if you experience some lag, frozen, hang or unresponsive issues. This is not advisable on some part, for it will wipe and delete all data stored from your Samsung Galaxy Y, so just ensure to make a back-up copy of all of the important files you had on your device.
[IMG]http://4.bp.********.com/-1A2nFXhrXBo/TpHAuizkEEI/AAAAAAAAAbM/4Qpq5RsiZHk/s1600/samsung-galaxy-y-+hard+reset.jpg[/IMG]
The most often method when the device hangs or just it frozen, is to remove the battery out after a couple of seconds and then putting it back again. To reset your device just dial this code *2767*3855#, this will reset your phone automatically once rebooted.
But sometimes the code may not always useful specially when your Samsung Galaxy Y is frozen and become unresponsive or in other sever hang problem like it just hangs on welcome screen logo. To fix it, just then again remove the battery out, then put it back again. Don't power it ON yet, just press and hold the Volume Up, Center button and Power button at the same time. A menu will then appear that let choose with an option. Just use the volume button to toggle and select the wipe data/factory reset, that will then reset your Galaxy Y to it's factory default settings.
Old 07-17-2012, 20:12   #5 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
How To Perform a Hard Reset on LG P506 Thrive
Disclaimer : Performing the hard reset will erase / wipe all of your personal data, we highly recommended to backup all data and make sure the SD Card is unmounted.
LG P506 Thrive factory reset from menu procedures
On the main home screen, tap menu
Select Settings, then select Privacy
Select Factory data reset
Select Reset phone
Enter the password if prompted, then select Erase everything.
LG P506 Thrive factory reset by button combinations procedures
Turn the phone power off. , take the battery out and reinsert it back again
Wait untill the phone rebooting.., and your phone should be turn to original factory default state.
The Following User Says Thank You to umesharora For This Useful Post:
Old 07-17-2012, 20:17   #6 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
press thanks
Old 07-17-2012, 20:30   #7 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
Hard Reset LG Optimus M Plus
This is how to perform a hard reset on this phone.
Take the battery out. Put it back in. Press and hold the following keys at the same time for about 1 to 2 seconds until the touch key backlights turn on: Power/Lock Key and Down Volume Key.
As soon as the backlight on the touch keys is turned on, release the keys. Then touch and hold the Home Key until the LG logo is displayed.
Your phone will perform the hard reset.
Old 07-17-2012, 20:41   #8 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
[Samsung Galaxy S2] Performing a hard reset
This are the step by step procedures on how to factory reset or hard reset the Samsung Galaxy S II, to return the phone to its original factory fresh default settings.
This may help and only advisable if experiencing frozen or hang up problems when using or opening some applications you previously installed on it.
Take note this will delete all data from the Samsung l9100 Galaxy S II as a result of this procedure. This process may or may not delete the data stored on the microSD memory card. Ensure to make a back up a copy of all important data before proceeding.
First do try to factory data reset the phone through the main menu settings.
1. On the main home screen, just select MENU
2. Select SETTINGS, then select PRIVACY
3. Select FACTORY DATA RESET
4. Select RESET PHONE
5. If the password is required,enter it. Then confirm by selecting ERASE EVERYTHING
IF the phone is hang up or frozen, Try to turn it off first and do a hard reset through key combinations.
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
Wait 'till the process completes, Once the wipe is completed, the Samsung Galaxy S II l9100 will then reboot. All the data you previously installed already been deleted and then the phone will then return to its original factory fresh default settings.
Old 07-17-2012, 20:54   #9 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
How to Hard Reset Phone when you Forgot Lock Pattern
different lock options. In Lock Pattern you are asked to provide the combination of dots which are arranged in grid to unlock the device. This trend is available in the smartphones which have touchscreen input.
It’s fine if you remember which dots to use to unlock, you can get in but what if you have forgotten the lock pattern on your Android handset? But still you can have a try with the lock pattern until you remember some or atleast a part of it. Try to use the combination possible. If you have entered the wrong pattern five times then you need to wait for another 30 seconds to unlock the device
If you forgot you screen unlock pattern then you need to reset it. The simple procedure is mentioned below –
Continue to enter the unlock pattern five times until you are prompted with forgot password (forgot pattern in some handsets) at the bottom right side of the screen.
Tap on the Forgot Password option and you would be prompted to sign in with the existing Google or Gmail account information. You need to provide the ID when you first register or activated your phone. If you have that, it would be easy to get in for you and then change the unlock pattern (atleast by now you would be remembering your unlock pattern).
If you don’t know the Gmail ID or the password is wrong then there is only one solution to hard reset your handset. The data present on the added SD card will not be wiped out but you would lose your personal data or information or contacts stored on your phone memory.
The procedure for hard reset is mentioned clearly at Reset Android mobile.
Old 07-17-2012, 20:55   #10 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
Some workarounds to try before that:
1. try entering null as password. (together with your google username) 2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock
5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. Try the normal recover password routine from GMail.com and start over from 1.
Old 07-17-2012, 21:04   #11 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
Android Alert: Enjoy Using Google Wallet? A Factory Reset Could Break It Forever
While there aren’t too many merchants that accept NFC payments (that’s soon going to change) there are probably even fewer devices that come with Google Wallet pre-installed. Maybe that’s why there hasn’t been much commotion over a potentially huge issue some Google Wallet users have been facing over in our forums.
One such Google Wallet user is having difficulty getting the app up and running again, after performing a routine factory reset on his HTC EVO 4G LTE. It all started after an app (Sense) began force closing repeatedly. Normally, under a situation like this when things start acting awry, a factory reset has long been the go-to method for fixing up a device’s software issues good as new. Anyone who has ever contacted tech support when dealing with a software issue knows this well. But that’s actually what started this whole mess.
While the factory reset managed to fixed up the little Sense crashing issue, it actually managed to disable all Google Wallet functionality on the device. Keep in mind, this all happened without any kind of warning, prompt or popup that this could potentially kill Google Wallet purchases from his device (a common selling point for NFC enabled devices) forever.
After a quick call to Google to find a solution, their response? Your fault. You need warranty coverage and your device will have to be replaced on your dime. When it comes to NFC enabled devices, there’s a security mechanism inside the NFC portion of the phone called the “secure element” that, if tampered with — or in this case a simple factory reset — will brick it, causing a “secure element error” when attempting to make NFC purchases Google thinks this common method of fixing up issues on the phone and also required before re-selling a device, is some kind of an attempt at someone engaging in some kind of nefarious activities by attempting to gain access to your funds.
And this isn’t unique to the EVO 4G LTE either. A quick Google search will show you this is a common issue for any NFC based device currently using Google Wallet (yes, even the Galaxy Nexus) and has been going on for quite sometime. The problem is Google, as well as the manufacturers with Google Wallet enabled devices (Samsung, HTC, LG), should at the very least warn Wallet users — either with a prompt or upon opening the Google Wallet app — that performing a factory reset will completely kill all Google Wallet functionality in the handset, and the device will need to be replaced (although Android Beam and NFC tags work fine).
However, there is a method for preventing or fixing the issue. For prevention, just make sure that before you perform a factory reset, you go into your Google Wallet’s settings (inside the app itself) and click on the option to “Reset Google Wallet.” This will delete all payment information from the device and you can factory reset to your heart’s desire. Fixing the issue is a little more difficult. This requires someone who is experiencing the bricked secure element (after flashing a custom ROM) to restore a backed up ROM (before everything went down) and reset the Google Wallet app from inside the app’s settings. No backup? No dice.
As someone who often (always) recommends friends and family perform a factory reset when their devices are acting “funny” — as well as a chronic custom ROM flasher — I’m glad I found this information when I did. Lest my friends, family or I be forced with a device crippled with reduced functionality. Spread the word, Phandroids. Oh, and be extra careful when buying previously owned Google Wallet devices.
Old 07-17-2012, 21:09   #12 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
Master reset T-Mobile myTouch 4G
Re-insert the battery.
Press and hold both the Volume Down key and the Power key. Do not release the volume key,
Release the Volume Down key when the three Android images appear on the bottom of the screen. The following options dsplay:
FASTBOOT
RECOVERY
FACTORY RESET
SIMLOCK
IMAGE CRC
Note: If the you are stuck on a screen that says 'HBOOT' and 'FASTBOOT' without any other options to choose from, it means you have pressed the Back button. To get to the regular options, press either the Power key on HBOOT or the Back button.
Press the Volume Down key twice to select FACTORY RESET.
Press the Power key to initiate the master reset.
Wait as the device displays the boot up screen, then shows a picture of arrows above a device with a progress bar. It then restarts.
Old 07-17-2012, 21:14   #13 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
How to Factory Reset your Android device
http://www.youtube.com/watch?v=y4Bi8QI5KyA
Old 07-17-2012, 21:17   #14 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
How to delete Google Account from Android phone without factory reset
http://www.youtube.com/watch?v=m1XjMzmwyP8
Old 07-17-2012, 21:23   #15 (permalink)
umesharora's Avatar
Member: 1687280
Thanks Meter: 647
How to setup Security on your Android smartphone
http://www.youtube.com/watch?v=pHtqFmi91Fg
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-12-2012 12:26
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.49158 seconds with 8 queries
