Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
01-07-2013, 15:00 | #1 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Android-codes-tricks-secrets * # * # 7780 # * # * - Will removing a reset: Data from your Google Account. System configuration and application downloaded applications Not eliminate: The software or applications you have downloaded before The files are in the SD memory. * 2767 * 3855 # - Note: This code deletes everything and reinstall the firmware (wipe all). * # * # 34971539 # * # * - you display the menu: Update the camera firmware (not the use that camera will stop running it) Update camera firmware in SD To determine the firmware version of the camera * # * # 7594 # * # * - Change the menu that appears when you hit the off button, and simply turn off your cell. * # * # 273283 * 255 * 663282 * # * # * - Starts a screen that allows you to copy media files. * # * # 197328640 # * # * - Enter the Service Mode: * # * # 232339 # * # * OR * # * # 526 # * # * or * # * # 528 # * # * - WLAN test * # * # 232338 # * # * - Displays the current MAC address * # * # 1472365 # * # * - GPS test * # * # 1575 # * # * - Another GPS test * # * # 232331 # * # * - Bluetooth test * # * # 232337 # * # - Shows Bluetooth terminal address * # * # 8255 # * # * - Gtalk Opens monitor. Codes to get Firmware data: * # * # 4986 * 2650468 # * # * - PDA, Phone, H / W, RFCallDate * # * # 1234 # * # * - PDA and Phone * # * # 1111 # * # * - FTA SW Version * # * # 2222 # * # * - FTA HW Version * # * # 44336 # * # * - PDA, Phone, CSC, Build Time, Changelist number Codes for factory tests: * # * # 0283 # * # * - Packet Loopback * # * # 0 * # * # * - LCD test * # * # 0673 # * # * or * # * # 0289 # * # * - Melody test * # * # 0842 # * # * - Device test (Vibration test and BackLight test) * # * # 2663 # * # * - Touch screen version * # * # 2664 # * # * - Touch screen test * # * # 0588 # * # * - Proximity sensor test * # * # 3264 # * # * - RAM version |
