Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
08-17-2010, 23:13 | #32 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | Quote:
The Following 2 Users Say Thank You to Celhack For This Useful Post: |
08-18-2010, 14:12 | #33 (permalink) |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | HTC SMART HARD AND SOFT RESET Restarting your phone (soft reset) If your phone is running slower than normal, an application is not performing properly, or your phone becomes unresponsive, try restarting your phone and see if that helps solve the problem. To restart your phone, simply turn it off and back on. If pressing and holding the END CALL/POWER button doesn't work, then please remove the battery, wait for a few seconds, reinsert the battery, and then turn the phone on. Performing a factory reset (hard reset) If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings. Be sure to back up any data (contacts and files) that you want to keep before you do a factory reset. Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings. 1)From the main Home screen, press MENU, and then tap Settings > Security > Factory reset. 2)Enter "1234", and then tap OK. Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone. 1)Press and hold the VOLUME UP, VOLUME DOWN and END CALL/POWER buttons. 2)When you see a warning message on screen, press the VOLUME DOWN button to perform the factory reset, or press any other button to cancel the reset. 3)After factory reset is complete, press the VOLUME DOWN button to restart your phone. |
The Following 2 Users Say Thank You to shahinahmed007 For This Useful Post: |
08-18-2010, 14:23 | #34 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | HTC HD MINI Restarting or factory resetting your phone If your phone becomes unresponsive or sluggish, first try restarting it and see if that helps. In case your phone has a persistent problem that cannot be solved, the last resort is to do a factory reset. Restarting your phone (soft reset) If your phone is running slower than normal, an application is not performing properly, or your phone becomes unresponsive, try restarting it and see if that fixes the problem. To restart your phone, simply turn it off and back on. If pressing and holding the POWER button doesn't work, remove the battery, wait for a few seconds, reinsert the battery, and then turn your phone back on. Performing a factory reset (hard reset) f you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. The most convenient way to do a factory reset is via the phone settings. 1)On the Home screen, slide to the Settings tab and then tap Security > Factory reset. 2)Enter 1234. 3)Tap Yes to perform the reset, or tap No to cancel the reset. Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone 1)With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons. 2)While holding the volume buttons, press the POWER button briefly and then release it. 3)When you see a warning message on the screen, release the VOLUME UP and VOLUME DOWN buttons. 4)Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset THANKS |
08-18-2010, 14:39 | #35 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | HTC WILDFIRE AND HTC ARIA Restarting your phone (soft reset) To restart your phone, simply turn it off and back on. If pressing and holding the POWER button doesn't work, then remove the battery, wait for a few seconds, reinsert the battery, and then turn the phone on Performing a factory reset (hard reset) If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. Note: Factory reset will not remove the data and files that are in your phone’s microSD card Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset. Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings. 1)From the Home screen, press MENU and then tap Settings. 2)Scroll down the screen and then tap Privacy > Factory data reset. 3)On the Factory data reset screen, tap Reset phone, and then tap Erase everything Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone. 1)With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button. Note: If you are not sure whether your phone's power is turned off, remove and then reinsert the battery. 2)Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button. 3)Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER. 4)Press VOLUME UP to start the factory reset ITS COULD BE HELP U..THANKS Last edited by shahinahmed007; 08-18-2010 at 14:46. |
08-20-2010, 13:32 | #40 (permalink) |
Major Poster Join Date: Jun 2008 Location: congo brazzaville
Member: 789830 Status: Offline Thanks Meter: 1 | htc dream 100 EN CHINOIS ,,?????? PLEAZE HELP ME,my phone is in chinese language after reset what can i do to have the french language it's a HTC DREAM 100 |
09-20-2010, 10:19 | #45 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | to all users who can not unblock gw620: on versions up to 10f is not possible to unblock security code nor upgrade main soft (fastboot requires a vol down+menu+camera and doesnt work in this ver) |
All Smart Phones & PDA/PALM Hard Reset Key Total InfoHere with picture | ::.::RAMJAN::.:: | HTC & Smartphones ( WM Without Touch) | 326 | 01-18-2017 19:49 |
how to hard reset o2 xda steatlh phone... | harish35200 | HTC & PDA WM( With Touchscreen) | 12 | 07-31-2013 13:11 |
A to z smart phones hard reset- soft reset updated | ..:::YMG:::.. | HTC & Smartphones ( WM Without Touch) | 1 | 03-05-2013 04:18 |
G1 Google Phone hard reset new | gsmshapon | Universal GSM Software | 0 | 05-20-2009 08:12 |
How do you Hard Reset Audiovox SMT 5600 Phone? | crystalgeyser2 | HTC & PDA WM( With Touchscreen) | 1 | 07-14-2005 02:43 |
