Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
06-13-2014, 09:33 | #34 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Bangladesh
Member: 1497712 Status: Offline Thanks Meter: 83 | get version only show but not showin ime write MauiMETA_3G_exe_v6.1316.1 not showing ime write only show get version Last edited by shafi_136; 06-13-2014 at 09:41. |
09-03-2014, 10:54 | #39 (permalink) |
Junior Member Join Date: Aug 2014 Location: Niger
Member: 2233759 Status: Offline Thanks Meter: 0 | How to write or change your IMEI on Android BY ADMIN · SEPTEMBER 15, 2013 This is a simple guide how you can rewrite you IMEI no after bricking it and repairing it back. After getting Repaired your Android device you may get problem with your Network and that is because of No valid IMEI, for that there can be many reasons. If your phone is Rooted then you can Write your IMEI no. with just a secret code you will not require to Connect your phone with computer with debugging mode and writing IMEI with any tool, that may again brick your phone so try this easy way To, If you are searching for tools to change your IMEI then please note that Changing IMEI is illegal and this place is not for you Write IMEI of your Android phone with secret code in Engineering mode:- Just enter this code in dialler:- *#7465625# or * # * # 3646633 # * # * Now Tap on Call pad or connectivity option or you have to slide the screen. Just Look for CDS information (Common data service information) option. You will see Radio information there and after tapping on it. If you have dual SIM ANDROID then you will see TWO option select any one on which you want to write IMEI with. Now you will have to put your IMEI no in this manner :- “AT +EGMR=1,7,”IMEI_1” and “AT +EGMR=1,10,”IMEI_2” (replace IMEI_1 and IMEI_2 with your IMEI no) and tap on send command button. for Example :- “AT =EGMR=1,7”9100XXXXXXXXXXXX” |
09-22-2014, 14:35 | #40 (permalink) |
Freak Poster Join Date: May 2013
Member: 1935677 Status: Offline Thanks Meter: 22 | android gidget vcom driver thanks for andriod imei soluion micromax a47 invalid imei from this moui tool give this mobile cds driver but after this driver android Gidget vcom driver so, please give me LATEST ANDROID GIDGET VCOM DRIVER i face this problem |
09-24-2014, 07:44 | #41 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 24 | xolo a700 invalied imei use volcano too android tool switch off phone dont connect the phone to computer fill imei start and now connect the phone imei write done |
10-01-2014, 12:13 | #44 (permalink) | |
Member: 1935677 Status: Offline Thanks Meter: 22 | All driver for maui meta Quote:
android gidget vcom driver not found andoriod mobile a47 cpu mt6572 imei no. Invalid problem | |
10-01-2014, 12:21 | #45 (permalink) | |
android gidget vcom driver not found andoriod mobile a47 cpu mt6572 imei no. Invalid problem any sugesstion | |
