11-16-2013, 10:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | Android Tools v1.1 [ Faheem Anjum ] Check device - you can now check device by clicking "search device" in device check icon if device is detected it means device is set to ENABLE USB DEBUGGING - if device is detected you can use WIPE DATA if device is not detected proceed to flashing using LiveSuit and ETC. Scr!tp Tools - ENABLE USB DEBUGGING must be set on device or android tablet - added "search device" to know if tablet is detected before scr!pt editing. FIX TOUCH SCREEN TOOLS - ENABLE USB DEBUGGING must be set on device or android tablet - A13 All winner chips is supported but you can do experimental in other device chips but use at your own risk and always do back up rom or firmware prepared just incase what happen to your device after injecting fixers tools. CAMERA FIXER TOOLS - ENABLE USB DEBUGGING must be set on device or android tablet - A13 All winner chips is supported but you can do experimental in other device chips but use at your own risk and always do back up rom or firmware prepared just incase what happen to your device after injecting fixers tools. COMBO FIXER TOOLS - ENABLE USB DEBUGGING must be set on device or android tablet - this tools can only fix on specific model available in my shell button. - you can do experiment by injecting scr!pt to other device but use at your own risk. Android X-tools by Xeven2nd Version 2 Android X-tools by Xeven2nd Version 2 FEATURES ADDED: Check device - you can now check device by clicking "search device" in device check icon if device is detected it means device is set to ENABLE USB DEBUGGING - if device is detected you can use WIPE DATA if device is not detected proceed to flashing using LiveSuit and ETC. Scr!tp Tools - ENABLE USB DEBUGGING must be set on device or android tablet - added "search device" to know if tablet is detected before scr!pt editing. FIX TOUCH SCREEN TOOLS - ENABLE USB DEBUGGING must be set on device or android tablet - A13 All winner chips is supported but you can do experimental in other device chips but use at your own risk and always do back up rom or firmware prepared just incase what happen to your device after injecting fixers tools. CAMERA FIXER TOOLS - ENABLE USB DEBUGGING must be set on device or android tablet - A13 All winner chips is supported but you can do experimental in other device chips but use at your own risk and always do back up rom or firmware prepared just incase what happen to your device after injecting fixers tools. COMBO FIXER TOOLS - ENABLE USB DEBUGGING must be set on device or android tablet - this tools can only fix on specific model available in my shell button. - you can do experiment by injecting scr!pt to other device but use at your own risk. PLEASE HELP TO THE VICTIMS OF TYPOON HAIYAN Download Here Last edited by THE CLASH; 01-12-2015 at 16:31. |
The Following 108 Users Say Thank You to Faheem Anjum For This Useful Post: |
11-16-2013, 11:16 | #2 (permalink) |
Freak Poster Join Date: Mar 2013 Location: ACCRA GHANA Age: 27
Member: 1908579 Status: Offline Thanks Meter: 21 | Can any one create a software that can detect android without usb debug? is it possible? |
The Following User Says Thank You to maiga73 For This Useful Post: |
11-16-2013, 11:21 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | hi plaese add onething in ur software " temporary enable usb debug" option line in mirracke cocktail thanks in advance br S.M.JUNAID |
The Following 5 Users Say Thank You to r-jcomm For This Useful Post: |
11-16-2013, 11:40 | #6 (permalink) | |
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | Quote:
sorry i write wrong spellings up there in my post "(plaese add onething in ur software " temporary enable usb debug" option like in mirracle cocktail") now its ok | |
The Following 2 Users Say Thank You to r-jcomm For This Useful Post: |
11-16-2013, 11:42 | #7 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | Payment Sent (Unique Transaction ID # 7GW80108SH8497534) M.FAHEEM THIS MY SMALL DONATIONS Mashallah Last edited by ..::Nokian CareŽ::..; 11-16-2013 at 15:06. Reason: QUOTE removed |
The Following 10 Users Say Thank You to gsaara For This Useful Post: |
11-17-2013, 10:34 | #9 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Bangladesh
Member: 1845954 Status: Offline Sonork: 100.1622497 Thanks Meter: 397 | Need solution Hello Faheem sir Pls give solution. When i try to open Faheem Anjum Tools v1.1 then show this I have download ur another tool name Droid Tool by Faheem Anjum but it is pass adjust. Pls give solution |
11-20-2013, 15:16 | #15 (permalink) |
Junior Member Join Date: Jun 2005 Age: 43
Member: 154879 Status: Offline Thanks Meter: 2 | Transaction Details Payment Sent (Unique Transaction ID # 0MM434656T189645K) THIS MY SMALL DONATIONS |
The Following 2 Users Say Thank You to jam_gsm For This Useful Post: |
