Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
01-02-2017, 09:10 | #1 (permalink) |
Banned Join Date: Apr 2013 Location: Dubai
Member: 1925987 Status: Offline Sonork: dearlex Thanks Meter: 130 | Bypass google account on tecno phatom 6 plus i Made this a gift because i find it difficult to bypass frp on this Tecno Phatom 6 Plus, even though i have a system an USB cord of the phone (Lol), an still i try All supported GSM Flashing Box to remove this but All in vain. This tutorial sharing below will allow you to bypass frp lock (Google Verification) on Tecno Phatom 6 Plus. without USB cord an system. HOW TO REMOVE / BYPASS FRP ON TECNO PHANTOM 6 PLUS Requirement: Internet Access QuickShortcutMaker Google Account Manager 6.0 Micro SDcard HOW TO REMOVE / BYPASS FRP Google Verification Lock ON TECNO PHANTOM 6 PLUS. 1st. Create a folder inside sdcard an name it 9jaROM, copy both (Google Accoutn Manager 6.0 & QuickshortcutMaker) You downloaded above inside the folder 9jaROM an insert into the Tecno phatom 6 Plus. Connect the lock phone with wifi. When connected click on Add network , when the keypad pop see screenshot below , click on Emoji. Click on HOT @ this point switchoff your data connection or your wifi immediately you click on HOT ( you can also switch it off before click on HOT ) Now you will Encounter an Error message Try Again in Emoji, that mean you dont have working internet connection, that is the message under try Again, press an hold any TEXT an click on Share. @this point choose Xender an navigate to file / sdcard /9jaROM/ install the two files you have copied to the folder. 1st install GoogleAccountManager.apk and tap on “Settings” when it shows “Installed blocked” window. Scroll down and enable the “Unknown Sources” and tap “OK” to install the apk. Once it installed tap on “OPEN” and search for “Google Account Manager” on the search bar of Quick Shortcut Maker application. And then you will see “Type Email and Password” is available now, Tap on “Type Email and Password” and tap on “/Try” and tap on “:” three points on the top right corner of yourTecno Phantom 6 Plus Screen, Then select “Browsers Sign-In” and “OK”. Now you will see “Google Sign-In” screen with a message “Sign in with your Google Account”.So, now you can enter your own Google Account, Just enter your Gmail ID and Password. If you don’t have Gmail ID or Google Account Password, Tap on “Create Account” to create one and then Sign-In with it. You’ll be redirected to the “Google Account Manager” after Signing-In to your Google Account. Now on this screen Press “Power Button” and Select “RESTART” and wait a few seconds until your Phone Restarted. Now you can do Initial Setup of your Tecno Phatom 6 plus and there will be no Google Account Locked / FRP Lock any more. After all this done, Go to “Settings” of your Phone and go to “Back up and Reset” > “Factory Data Reset” and tap on “ERASE EVERYTHING” and wait until your phone restarts. Congratulation You have successfully bypass Google verification on Tecno Phatom 6 Plus. HOW TO REMOVE / BYPASS FRP ON TECNO PHANTOM 6 PLUS | 9jaROM |
The Following 3 Users Say Thank You to engdearlex For This Useful Post: |
07-28-2017, 02:37 | #4 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2504858 Status: Offline Thanks Meter: 2 | I once did it on my Galaxy S5 with the help of this guide. You can give it a try if OP's method doesn't work for your case. |
