Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
09-22-2013, 06:29 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2015288 Status: Offline Thanks Meter: 3 | Cherry Mobile Flare Dead or Hard Brick Solution After working for 8 hours on my computer finding a solution how to revive or unbrick hard brick Cherry Mobile Flare, FINALLY I have found the solution just using my Computer. Some people say its already impossible to revive hard brick but its not.... |
The Following User Says Thank You to chiwivillacorta For This Useful Post: |
09-22-2013, 06:39 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | hehehhehehehehe.......... with GOOD EMMC, dead flare we be revive in seconds....even w/o BOX did your flared suddenly went dead? try your solution on FLARE that suddenly went DEAD or just charging and it went DEAD...let see if it work.. i have 2pcs here, emmc not dectecting on JTAG.... br. FFC Last edited by rico_deep; 09-22-2013 at 06:45. |
09-22-2013, 07:46 | #3 (permalink) |
Member: 2015288 Status: Offline Thanks Meter: 3 | My Flare wont open anymore, it wont open also in Fastboot Mode or Green Screen Mode (Power + Vol Up) or red screen mode or qpst.... a working cherry mobile should vibrate if you press the power button but mine is totally dead.. the cause of hard brick flare was when i tried upgrading to higher version of rom but it turned out not successfull... i even accidentally formatted all drive in my device so everything was lost... I want to ask you if your computer can detect your flare if not then i cannot help you. There are many reason why your computer cannot detect your device, one is maybe you are using new version of windows... dont try to detect it using windows 8, use windows 7 or lower... i dont know why but thats what i did... let me know |
09-22-2013, 08:55 | #4 (permalink) |
Insane Poster Join Date: Apr 2008 Location: pilipinas /New Zealand
Member: 761560 Status: Offline Thanks Meter: 34 | ehehehe.. What solution do you have? Can you post it in here with some instruction so you can help others with that problem?.... because if you are trying to say because of the operating system that you used , but others try already with different PC and different OS. Thanks atatssss |
09-22-2013, 09:10 | #5 (permalink) |
Member: 2015288 Status: Offline Thanks Meter: 3 | There is no harm in trying ... I'm not expert on this but when I tried detecting my device on when 8 or 7, it was not detected but when I tried detectiing with windows Xp, it was detected. After that you have to install the driver in your PC... The most important thing her is to have access to your device so you can bring your device yo qpst mode...your good to go if you can do that. There is an issue detecting it with higher version of windows coz of driver comparability... |
09-22-2013, 09:16 | #6 (permalink) |
Member: 761560 Status: Offline Thanks Meter: 34 | Ya some knows already about that. Thanks for tips.. but if you have working for a how many years for some mobile repair software and hardware that problem they should know that already. you what i mean a. |
09-22-2013, 09:16 | #7 (permalink) | |||
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
it's just a SOFTBRICK... Quote:
this 2pcs FLARE suddenly DIE w/o any reason.. Quote:
br. FFC Last edited by rico_deep; 09-22-2013 at 09:25. | |||
The Following User Says Thank You to rico_deep For This Useful Post: |
09-22-2013, 09:46 | #8 (permalink) |
Member: 2015288 Status: Offline Thanks Meter: 3 | a) soft Brick - Stuck at Samsung Logo b) Super Brick - Stuck at flashing Factoryfs in ODIN Also called as EMMC Bug.... c) Hard Brick - not booting in recovery, download, no charging battery logo, no power d) Dead Brick - No charging battery sign also - Mostly -Hard Brick Mine is not starting in recovery ( green and red screen is not appearing), no qpst or download mode, no battery sign. I dont know what do you call mine. It doesnt matter if soft, hard or dead, all i wanted is to share it to the people who dont know anything about unbricking. Thank you |
09-22-2013, 09:59 | #9 (permalink) | |
Member: 159757 Status: Offline Thanks Meter: 461 | okay........ Quote:
i don't see any link nor tutorial, or just contact me bla,bla,bla?? br. FFC | |
09-22-2013, 10:13 | #10 (permalink) |
Member: 2015288 Status: Offline Thanks Meter: 3 | I already did, first step is detect your device in your PC then install the appropriate driver for your device.I will post the links on my next post as the forum admin doesn't allow me to post any links as of now. |
09-22-2013, 14:02 | #11 (permalink) |
Member: 159757 Status: Offline Thanks Meter: 461 | then do this : http://forum.gsmhosting.com/vbb/f781...ution-1687316/ or this : http://forum.gsmhosting.com/vbb/f824...ution-1698395/ If not repair then Do this:http://forum.gsmhosting.com/vbb/f672...-done-1698420/ or this: http://forum.gsmhosting.com/vbb/f609...oints-1708622/ If Still not repair? need to replace this:http://forum.gsmhosting.com/vbb/f609...ml#post9721569 not all NO download mode/No recovery/No entry QPST is Hard-Brick... Not all you see on NET is true.. just my cent.. br. FFC |
09-22-2013, 18:11 | #12 (permalink) |
Member: 2015288 Status: Offline Thanks Meter: 3 | There is no harm in trying, Im Assuming your phone is on " entry qpst" h**ttp**:*//forumDOTxda-developersDOTcom/showthreadDOTphp?p=45825598#post45825598**** Just remove asterisk and change DOT by . |
09-22-2013, 18:32 | #13 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | Hi, This very simple! If your devices dead suddenly in flashing/update/root/change imei You can repair your phone in a seconds! W/o box,dongle If your devices dead while charging/games/using wifi/while phone in the table,bag,TOILET BOWL! 99% hardware! Additional: QC 9006 is verry simple to repair, QC 9008 most hard, sometimes verry hard to repair br, Sent from my iPhone 4 using Tapatalk 2 |
09-23-2013, 00:36 | #14 (permalink) | |
hope you'll get hands on FLARE that die w/o any reason and try your solution, for me tried it many times but still FLARE is on QC 9008(com) | |
