Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
07-14-2013, 04:19 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: PHILIPPINES
Member: 1844155 Status: Offline Sonork: NONE Thanks Meter: 45 | Cherry mobile flare deadboot solution Solution For Deadboot Download first this Files bago tayu mag simula QPST 2.7 build 399 - MediaFire - Online Space for your documents, photos, videos, and music. JB drivers - JB_pcdrivers.rar Jelly Bean BP Firmware BP_JB_Firmware.rar WARNING : Supported ito sa mga flare na nadedetect pa ng Pc if hndi ito ma detect sa pc dont do this anymore Install QPTS (alam ko pamilyar kayo jn.. ginagamit yan sa mga broadband stick..) install lahat ng drivers para walang aberya Install drivers 1. Connect deadboot flare to PC / Laptop. 2. Go to device manager, expand PORTS (COM & LPT). Check if there is an item called Qualcomm HSUSB QDLOADER 9008. If the item is there, you are done with driver install. If it does not exist, proceed to step3. 3. If there is no item under PORTS (COM & LPT), check device manager under OTHER DEVICES > Unknown Device 4. Double click UNKNOWN DEVICE > UPDATE DRIVER > BROWSE MY COMPUTER > browse to the folder where you saved extracted the ICS / JB drivers. It will install the driver, if it prompts for unsigned drivers, press INSTALL ANYWAY. 5. It should now be listed under COM PORTS > Qualcomm HSUSB QDLOADER 9008. Run QPST and reprogram EMMC (dito tayu mag sisimula) 1. Run EMMC SOFTWARE DOWNLOAD. 2. Press BROWSE, it will detect your phone. Look for the PHONE TAB that says DOWNLOAD. Press OK. 3. Put check mark on PROGRAM BOOTLOADERS, PROGRAM MMC DEVICE, TRUSTED. 4. Under FLASH PROGRAMMER FILENAME, enter MPRG8X25.hex 5. Under BOOT IMAGE, enter 8X25_msimage.mbn 6. Press LOAD XML DEF > navigate to your extracted JB firmware > select rawprogram0 > press OPEN. 7. Press LOAD PATCH DEF > navigate to your extracted JB firmware > select patch0 > press OPEN 8. PRESS DOWNLOAD 9. An warning message may appear, TIME OUT WAITING etc etc or COOKIE NOT RECEIVED. If the error is TIME OUT WAITING, press OK and then press SWITCH DEVICE TO DLOAD. Check the flare, it will show RESET FOR ENTRY QPST. 10. Exit EMMC SOFTWARE DOWNLOAD. Proceed to flash Jelly Bean BP Firmware and then flash Jelly Bean img dump. 11. IF ERROR IS COOKIE NOT RECEIVED, sorry it is still bricked. JUST HIT THANKS BUTTON IF YOU LIKE MY POST |
The Following 3 Users Say Thank You to Bonaman For This Useful Post: |
07-15-2013, 18:39 | #2 (permalink) |
Junior Member Join Date: Jun 2006
Member: 291418 Status: Offline Thanks Meter: 1 | cookie (if present) not received error receiving cookie not received error. please help? the log file is as follow: 2013/07/03 14:15:55.095 Restart timeout set to 10 seconds 2013/07/03 14:15:55.095 StartSB2Download 2013/07/03 14:15:55.095 Begin SB2.0 Software Download 2013/07/03 14:15:55.095 Skip Reset: 1 2013/07/03 14:15:55.095 Lock phone 2013/07/03 14:15:55.095 Examine phone mode 2013/07/03 14:15:55.111 Get partition file name 2013/07/03 14:15:55.111 User specified flash programmer: 2013/07/03 14:15:55.111 Flash Programmer file: 2013/07/03 14:15:55.126 Examine phone mode 2013/07/03 14:15:55.126 Mobile not in download mode! 2013/07/03 14:15:55.126 SynchronizeConnection starting... 2013/07/03 14:15:55.126 Sending Hello to flash programmer... 2013/07/03 14:15:55.126 Disabling automatic polling. 2013/07/03 14:15:55.189 Try Hello with polling disabled... 2013/07/03 14:15:55.189 Try Hello with polling disabled... 2013/07/03 14:15:55.189 Try Hello with polling disabled... 2013/07/03 14:15:55.189 SynchronizeConnection succeeded. 2013/07/03 14:15:55.189 Sending Hello Packet 2013/07/03 14:15:55.204 Version info = 5 2 2013/07/03 14:15:55.204 Block size = 400 2013/07/03 14:15:55.204 Flash base = 0 2013/07/03 14:15:55.204 Device Name=eMMC: 2013/07/03 14:15:55.204 Flash ID size= 4 2013/07/03 14:15:55.204 Sectors = 128 2013/07/03 14:15:55.204 Feature mask = 0x09 2013/07/03 14:15:55.204 Sending Close 0 2013/07/03 14:15:55.204 Log: Cannot close when not previously opened 2013/07/03 14:15:55.204 ARMPRG error: 15, text: Cannot close when not previously opened 2013/07/03 14:15:55.204 CloseDownloader error 2013/07/03 14:15:55.204 Sending Security Mode 1 2013/07/03 14:15:55.204 eMMC user image present - skipping partition table 2013/07/03 14:15:55.220 eMMC user image: C: \ flare repair files \ 8X25_msimage. mbn 2013/07/03 14:15:55.220 Opening eMMC USER file 2013/07/03 14:15:55.220 Opening eMMC USER mode 2013/07/03 14:15:55.220 Sending MI Open mode 33 size 0 2013/07/03 14:15:55.579 Log: Open multi failed, unknown error 2013/07/03 14:15:55.579 ARMPRG error: 7, text: Open multi failed, unknown error 2013/07/03 14:15:55.579 Download end, status 103, error 852 2013/07/03 14:15:55.579 Exit SB 2.0 download with status 0x00000000 |
The Following User Says Thank You to kornholic For This Useful Post: |
09-10-2013, 22:38 | #4 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1633654 Status: Offline Sonork: p1ck Thanks Meter: 2 | how to flash after (RESET FOR ENTRY QPST DOWNLOAD) show-up. and what tools to use flasing for JB?? Thanks and advance |
The Following User Says Thank You to p1ck_kn0t For This Useful Post: |
10-07-2013, 05:08 | #10 (permalink) | |
Junior Member Join Date: Dec 2012 Location: manila phellephenes Age: 34
Member: 1846781 Status: Offline Sonork: 100.1597405 Thanks Meter: 28 | Quote:
Tools QPST-2.7.399 BP_JB_Firmware JB_pcdrivers EMMC_DownLoad_V1.2.4 Roadkil's Disk Image | |
The Following 3 Users Say Thank You to gsm khen For This Useful Post: |
