Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 05-19-2012, 16:57   #1 (permalink)
Member: 667202
Thanks Meter: 3
Flashing Tablet Android di 20 merek tablet android
Modroid v10 LITE
Modroid is built on the 1.5.1 firmware released by EKEN.
Below is a list of supported devices as verified by uberoid.
This list is still experimental with the 1.5.1 firmware however.
Use at your own risk!!!!!
1=Maylong M-250
1=MID V7 7"
1=InterToys NL Tab 7"
1=MID E18 7"
1=M009S Green LED 7"
1=TomTec Tablet 7"
2=M009S Blue LED 7"
2=Generic Netbook 7"
2=Epad GW-70 7"
2=MIDV7 Blue LED 7"
2=WinPad-C07 7"
3=M003S 8"
3=Innovatek MID 8"
4=PC-802 8"
5=BLY-806 8"
5=VIA WM8650 8"
6=M80003W 8"
7=Apex 7"
7=BLY-706F v1 7"
8=MID703 7"
8=ILC PC Tab701 7"
8=KLD-MID701 7"
8=MID710 7"
9=M010S 7"
10=M012S 8"
11=M70007T 7"
11=ViaPad M7 7"
11=VIA WM8650 7"
11=M768A 7"
11=Leader V70 7"
11=Epad GW-707 7"
12=ATF3416-7 7"
13=BLY-706F v3 7"
14=E16 5cun1603 5"
15=ED99 8cun1603 8"
16=E18 7cun1603 7"
17=ED99 8cun8900 8"
18=Ricatech/RATAB10 10"
18=TomTec 10"
19=Epad M009D (added by ohwzo.nl)
20=M013S (added by me)
To download the file click the link below
download here
To install do the following:
Format a 1,2 or 4 gig SD card to FAT32 (larger cards may not work)
Extract the contents of the zip file to your SD card
Run changer.bat (from the sd card) and select the number of the device you have
Insert SD card into your device and power on
The upgrade will run automatically. When it’s finished wait about 45 seconds before removing your SD card when it tells you to.
The device will reboot into Modroid (first boot after upgrading may take up to 5 minutes)
If you get stuck at the “modroid loading" screen for more than 5 minutes try another number in the changer.bat and flash again, or use
the env_uboot and wmt_scriptcmd files from your devices factory firmware.
Before you get all excited and start playing around you need to do this to get a “fully” working android market.
Connect to wifi/ethernet to get online then do the following.
1. Open the Market and let it fully load. Then press the home button.
2. Go to Settings \ Applications \ Manage \ Running
3. Press "Market"
4. Press "Clear cache" (do not clear data)
5. Press "Force stop"
6. Return to "Settings \ Applications \ Manage \ Running"
7. Press "Google Services Framework"
8. Press "Clear Data"
9. Press "Force Stop"
10. Press home button.
11. Restart Google Market. It should give an error message (this is good)
12. Reboot
You should now have a 100% fully working android market.
sources of: HERE
The Following 3 Users Say Thank You to Wahid84 For This Useful Post:
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
unlocking nokia 5110 version5.12 5.20 tomi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 02-25-2011 10:16
How unlock new nokia5110 version 5.20 ? Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-21-2011 07:45
How unlock Nokia version 5.20 Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-17-1999 17:35
Page generated in 0.15416 seconds with 9 queries
