Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 09-13-2017, 20:09   #16 (permalink)
Member: 2114397
Thanks Meter: 157
Bypass FRP on Google Pixel 8.0 7.1 7.0 6.0 100% working solution
https://www.youtube.com/watch?v=hnoG1Ve4v9U
The Following User Says Thank You to atiqmalik For This Useful Post:
Old 09-18-2017, 23:15   #17 (permalink)
Member: 140474
Thanks Meter: 11
Hello.
Is there a chance to update 7.1.2 to 8.0 while pixel is frp locked and debuging off?
regards
Olo
Old 09-19-2017, 02:06   #18 (permalink)
Member: 808621
Thanks Meter: 2
Download ADB/ fastboot files and put them in a folder. Use sideload should work.
P.S. Granted Administrator on Windows first.
Old 09-22-2017, 13:53   #19 (permalink)
Member: 2619528
Sonork: 100.1675084
Thanks Meter: 4
sir adb sideload update error every time please sir help me
Old 10-06-2017, 15:39   #20 (permalink)
Member: 2347074
Thanks Meter: 30
Originally Posted by simleg View Post
Hello.
regards
Olo
Yes. All you need is Android 8.0.0 running on September 2017 security patch. Download the OTA package and sideload via recovery.
Old 10-06-2017, 21:13   #21 (permalink)
dr.danielman's Avatar
Member: 356508
Thanks Meter: 132
Stop
Please all Stop write bull****
if you have not enabled OEM and adb debug YOU ARE NOT ABLE TO UPDATE VIA SIDELOAD
so if you have frp it's not possible to enable adb debugging
so forget about update via sideload
all connection usb to pc will be unknown device
So if any one have another solution to update or to remove frp in pixel 7.1.2 please let me know
Thank you
ps i use phone via nova lunch
The Following User Says Thank You to dr.danielman For This Useful Post:
Old 10-22-2017, 21:27   #22 (permalink)
Member: 1699417
Sonork: freddy2302
Thanks Meter: 4
100% working solution in a pixel with android 7.1.1 and security Feb 5, 2017 with OEM lock and locked Bootloader. All you have to do is Download the OTA package sailfish-ota-opr6.170623.012-b48a822b.zip from google drive and sideload via recovery. The OTA package has security August 5, 2017 and Android versión 8.0.0.
I Hope this help.
Thank you
Old 11-14-2017, 22:05   #23 (permalink)
Member: 2188956
Thanks Meter: 29
Thank you
to fix this problem, boot it into recovery mode, and choose option "apply update from ADB" that will turn on adb so you can sideload the s/w just did this myself and it worked.
Old 11-14-2017, 22:28   #24 (permalink)
Member: 2188956
Thanks Meter: 29
I tried this but when I open FRP Bypass, i click Google Account Manager APK Install, then i click for version 5.0 then there's a pop up that says.
Google account manager, do you want to install an update to this existing application? your existing data will not be lost. the update application will get access to: New or All, i chose all like your video says, then i try click install, it comes back with App Not Installed. Now when i turn off the USB mass storage it will let me install it, but with USB Mass Storage on it will not let me install. So i turned it off to install it, after that i click ByPass FRP like in your video and click browser sign in, and it says "FRP Bypass has Stopped"
Old 12-16-2017, 13:22   #25 (permalink)
Member: 2501288
Thanks Meter: 328
for me maps not working in feedback !!!
Old 12-22-2017, 19:14   #26 (permalink)
Member: 2526783
Thanks Meter: 22
google pixel / pixel xl
"Maps" is not showing up when I enter a country or state.
7.1.2 august update
Yes i did sideload the 8.0 ota.
Old 12-26-2017, 05:38   #27 (permalink)
Member: 1484663
Thanks Meter: 344
is this working on pixel 2?
Old 12-26-2017, 09:39   #28 (permalink)
Member: 1484663
Thanks Meter: 344
Can someone share the proper OTA update file to complete this??
Old 01-20-2018, 15:41   #29 (permalink)
Member: 1661186
Thanks Meter: 6
if show no maps in the feedback please try this solution..
http://forum.gsmhosting.com/vbb/f606.../#post12915810
Old 02-07-2018, 19:18   #30 (permalink)
Member: 2698861
Thanks Meter: 5
google map isn't showing.. any solution please..?
Page generated in 0.21829 seconds with 8 queries
