Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 11-20-2011, 14:53   #166 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 157
Motrola DROID 3 - Master Reset Pliz halpe me sir
Old 12-06-2011, 01:35   #167 (permalink)
Member: 1701341
Sonork: Tara Woodin
Unhappy samsung galaxy I5500M
my daughter locked me out of my phone and now it asks for my gmail account info, i have entered but still doesnot let me in, i have tried the factory hardlock rest, but the one on here don't seem to work on my phone. Please does any one know what i can do to get back in my phone. thxs.
Old 12-06-2011, 02:09   #168 (permalink)
aleon's Avatar
Member: 194712
Sonork: 100.1580741
Thanks Meter: 212
try this
1. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock
2. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock
if dont work
Go to How To Set Up ADB/USB Drivers for Android Devices | TheUnlockr and install the SDK as instructed. Once installed you can plug in your galaxy i5500 to your computer. Make sure it's in USB mode by pressing the volume down + the big middle button + the power button. You should see an android bot digging in a yellow triangle. Once everything is good go to command prompt (dos terminal) and type: adb reboot recovery and that should reboot your device into recovery mode. Once you see the triangle with the exclamation mark just press the menu button to begin factory reset.
if still cant do a factory reset
first use odin to update it to 2.2
then use one samsung i9000 one-click root
make sure when you connect the usb to phone select kies option, this will turn on usb debugging if you cant get past the security code or email.
select one click root 2.2
wait....
then you will be in recovery boot screen
select wipe\factory reset
then select reboot now phone
phone will restart and go into recovery again, simply select reboot a second time and you will be good.
hope this help
wbr aleon
Old 12-06-2011, 04:38   #169 (permalink)
Member: 1699784
Thanks Meter: 20
i need samsung i5500 user code reset how?
plz help me
Old 12-06-2011, 17:16   #170 (permalink)
Member: 1586214
Thanks Meter: 12
XT860 4G - Master Reset / Factory Reset de Dados
Redefinição de dados de fábrica é uma ferramenta usada para remover tudo o que foi importado, adicionado ou instalado no dispositivo. Tenha em mente, ao usar esse recurso, que tudo é excluído. Não serão afetados o armazenamento no MicroSD ou o armazenamento interno do telefone, a menos que você escolha apagá-los também.
Reposição dados de fábrica
  • A partir da tela do seu telefone, pressione o botão Menu
  • Toque em Configurações .
  • Role para baixo e toque em Privacidade
  • Toque em Redefinir dados de fábrica
  • Verifique, Erase armazenamento interno se você precisar de apagar todos os dados sobre o armazenamento do telefone (interno), tais como aplicativos, música, filmes ou fotos.
  • Toque em Reiniciar telefone
[HR][/HR]Executar um reset de fábrica usando teclas externas
Nota : É altamente recomendável que você use o reset de fábrica com as configurações (acima) .Cometendo um erro usando o método de reset de fábrica com a chave externa poderia ter consequências muito ruins.
Se você não conseguir navegar pelo menu para executar uma reposição de fábrica, você pode seguir os passos descritos abaixo:
  1. Desligar o dispositivo. Pressione o botão Power e selecione Desligar . Se o dispositivo não responder à entrada, remover e/ou substituir a bateria.
  2. Deslize o teclado aberto.
  3. Pressione e segure o botão Power + tecla X simultaneamente até que a tela de recuperação (ponto de exclamação com uma figura android) aparece.
  4. Teclado deslizante fechado, em seguida, pressione o simultaneamente a tecla de volume up + down .
  5. Pressione Volume baixo para selecionar apagar os dados / fábrica redefinir a pressionar o botão Power. Utilize as teclas de volume (para cima / para baixo) para selecionar.
  6. Pressione Volume baixo para selecionar Sim - apagar todos os dados do usuário pressione o botão Power . processo de reset de fábrica pode demorar alguns minutos para ser concluído.
  7. Selecione a reinicialização do sistema agora, em seguida, pressione o botão Power . processo de reinicialização pode demorar alguns minutos para ser concluído.
  8. DONE!
Old 12-06-2011, 19:48   #171 (permalink)
Member: 1701341
Sonork: Tara Woodin
It does not work for my phone.
Old 12-06-2011, 19:50   #172 (permalink)
Member: 1701341
Sonork: Tara Woodin
Originally Posted by aleon View Post
try this
if dont work
go to how to set up adb/usb drivers for android devices | theunlockr and install the sdk as instructed. Once installed you can plug in your galaxy i5500 to your computer. Make sure it's in usb mode by pressing the volume down + the big middle button + the power button. You should see an android bot digging in a yellow triangle. Once everything is good go to command prompt (dos terminal) and type: Adb reboot recovery and that should reboot your device into recovery mode. Once you see the triangle with the exclamation mark just press the menu button to begin factory reset.
If still cant do a factory reset
Select one click root 2.2
wait....
Then you will be in recovery boot screen
Hope this help
wbr aleon
this did not work
Old 12-10-2011, 09:18   #173 (permalink)
Member: 336489
Thanks Meter: 3
Hard reset Sky IM-A600s
Please help locked gmail ?
Old 12-10-2011, 09:37   #174 (permalink)
\/\/imran's Avatar
Member: 1178314
Sonork: 100.1603064
Thanks Meter: 891
its korean phone hope hard reset same procedure try this....
power off the phone, press google switch and power . until you will see triangle on the screen.
press power or search botton you can see reset menu use volume
up or down button, sellect wipe factory reset with search button
choes yes reset all user data all will be done.
more info
http://forum.gsmhosting.com/vbb/f606...0/#post7936882
The Following User Says Thank You to \/\/imran For This Useful Post:
Old 12-10-2011, 23:02   #175 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 36
Wink Ot906 - master reset
Old 12-12-2011, 18:07   #176 (permalink)
Member: 1396436
Thanks Meter: 35
how to solve bypass gmail activation in HTC Magic after unlock help me please
Old 12-12-2011, 19:24   #177 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
Foston FS-D188TW Hard Reset Procedure
English procedure
Brazilian Portuguese Procedure:
Old 12-13-2011, 01:13   #178 (permalink)
Member: 1701341
Sonork: Tara Woodin
Question hard locked rest
my daughter locked me out of my phone and now it asks for my gmail account info, i have entered but still doesnot let me in, i have tried the factory hardlock rest, but the one on here don't seem to work on my phone. Please does any one know what i can do to get back in my phone. thxs, and i have tried all the sujestions, i need help please.
Old 12-18-2011, 17:32   #179 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
zte san francisco p729v
please i want a procedure unlock google code
thx
Old 12-18-2011, 19:07   #180 (permalink)
Member: 732120
Thanks Meter: 28
Originally Posted by MyFone Shop View Post
how to reset samsung i9001
try holding volume down and and center menu and when icon appears release power button and still hold volume down and menu and wait until reset appears....
All Smart Phones & PDA/PALM Hard Reset Key Total InfoHere with picture ::.::RAMJAN::.:: HTC & Smartphones ( WM Without Touch) 326 01-18-2017 19:49
how to hard reset o2 xda steatlh phone... harish35200 HTC & PDA WM( With Touchscreen) 12 07-31-2013 13:11
A to z smart phones hard reset- soft reset updated ..:::YMG:::.. HTC & Smartphones ( WM Without Touch) 1 03-05-2013 04:18
G1 Google Phone hard reset new gsmshapon Universal GSM Software 0 05-20-2009 08:12
How do you Hard Reset Audiovox SMT 5600 Phone? crystalgeyser2 HTC & PDA WM( With Touchscreen) 1 07-14-2005 02:43
Page generated in 0.30519 seconds with 10 queries
