Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
12-06-2011, 01:35 | #167 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1701341 Status: Offline Sonork: Tara Woodin Thanks Meter: 0 | samsung galaxy I5500M my daughter locked me out of my phone and now it asks for my gmail account info, i have entered but still doesnot let me in, i have tried the factory hardlock rest, but the one on here don't seem to work on my phone. Please does any one know what i can do to get back in my phone. thxs. |
12-06-2011, 02:09 | #168 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: mexico
Member: 194712 Status: Offline Sonork: 100.1580741 Thanks Meter: 212 | Quote:
1. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock 2. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock if dont work Go to How To Set Up ADB/USB Drivers for Android Devices | TheUnlockr and install the SDK as instructed. Once installed you can plug in your galaxy i5500 to your computer. Make sure it's in USB mode by pressing the volume down + the big middle button + the power button. You should see an android bot digging in a yellow triangle. Once everything is good go to command prompt (dos terminal) and type: adb reboot recovery and that should reboot your device into recovery mode. Once you see the triangle with the exclamation mark just press the menu button to begin factory reset. if still cant do a factory reset first use odin to update it to 2.2 then use one samsung i9000 one-click root make sure when you connect the usb to phone select kies option, this will turn on usb debugging if you cant get past the security code or email. select one click root 2.2 wait.... then you will be in recovery boot screen select wipe\factory reset then select reboot now phone phone will restart and go into recovery again, simply select reboot a second time and you will be good. hope this help wbr aleon | |
12-06-2011, 17:16 | #170 (permalink) |
Junior Member Join Date: May 2011 Location: Brasil Age: 40
Member: 1586214 Status: Offline Sonork: [email protected] Thanks Meter: 12 | XT860 4G - Master Reset / Factory Reset de Dados Redefinição de dados de fábrica é uma ferramenta usada para remover tudo o que foi importado, adicionado ou instalado no dispositivo. Tenha em mente, ao usar esse recurso, que tudo é excluído. Não serão afetados o armazenamento no MicroSD ou o armazenamento interno do telefone, a menos que você escolha apagá-los também. Reposição dados de fábrica
Nota : É altamente recomendável que você use o reset de fábrica com as configurações (acima) .Cometendo um erro usando o método de reset de fábrica com a chave externa poderia ter consequências muito ruins. Se você não conseguir navegar pelo menu para executar uma reposição de fábrica, você pode seguir os passos descritos abaixo:
12-06-2011, 19:50 | #172 (permalink) | |
Member: 1701341 Status: Offline Sonork: Tara Woodin Thanks Meter: 0 | Quote:
this did not work | |
12-10-2011, 09:37 | #174 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | Quote:
power off the phone, press google switch and power . until you will see triangle on the screen. press power or search botton you can see reset menu use volume up or down button, sellect wipe factory reset with search button choes yes reset all user data all will be done. more info http://forum.gsmhosting.com/vbb/f606...0/#post7936882 | |
The Following User Says Thank You to \/\/imran For This Useful Post: |
12-12-2011, 19:24 | #177 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | Foston FS-D188TW Hard Reset Procedure Foston FS-D188TW Hard Reset Procedure English procedure Brazilian Portuguese Procedure: |
12-13-2011, 01:13 | #178 (permalink) |
Member: 1701341 Status: Offline Sonork: Tara Woodin Thanks Meter: 0 | hard locked rest my daughter locked me out of my phone and now it asks for my gmail account info, i have entered but still doesnot let me in, i have tried the factory hardlock rest, but the one on here don't seem to work on my phone. Please does any one know what i can do to get back in my phone. thxs, and i have tried all the sujestions, i need help please. |
All Smart Phones & PDA/PALM Hard Reset Key Total InfoHere with picture | ::.::RAMJAN::.:: | HTC & Smartphones ( WM Without Touch) | 326 | 01-18-2017 19:49 |
how to hard reset o2 xda steatlh phone... | harish35200 | HTC & PDA WM( With Touchscreen) | 12 | 07-31-2013 13:11 |
A to z smart phones hard reset- soft reset updated | ..:::YMG:::.. | HTC & Smartphones ( WM Without Touch) | 1 | 03-05-2013 04:18 |
G1 Google Phone hard reset new | gsmshapon | Universal GSM Software | 0 | 05-20-2009 08:12 |
How do you Hard Reset Audiovox SMT 5600 Phone? | crystalgeyser2 | HTC & PDA WM( With Touchscreen) | 1 | 07-14-2005 02:43 |
