Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 08-15-2010, 11:18   #31 (permalink)
ami_ridho's Avatar
Member: 396831
Thanks Meter: 19
brother please help me how to root xperia mini pro step by step .......
thanks before ............
Old 08-17-2010, 23:13   #32 (permalink)
Member: 416710
Thanks Meter: 391
Originally Posted by jepetu View Post
Motorola CLIQ XT (MB501) Hard Reset:
1. Turn the power off. If your Motorola CLIQ XT is frozen, pull the battery out and reinsert it
2. Press and hold the Power and Camera buttons
3. Release the Camera button when prompted
4. Press and hold the Volume Down key
5. A yellow exclamation will appear on the display. Wait until a menu with options will appear.
6. Using the touch screen select Factory Reset and press OK.
That's all.
Some time need press HOME+back or MENU+BACK or HOME+camera or menu+camera and option will appear.
The Following 2 Users Say Thank You to Celhack For This Useful Post:
Old 08-18-2010, 14:12   #33 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
HTC SMART HARD AND SOFT RESET
Restarting your phone (soft reset)
If your phone is running slower than normal, an application is not performing properly, or your phone becomes unresponsive, try restarting your phone and see if that helps solve the problem.
To restart your phone, simply turn it off and back on. If pressing and holding the END CALL/POWER button doesn't work, then please remove the battery, wait for a few seconds, reinsert the battery, and then turn the phone on.
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings. Be sure to back up any data (contacts and files) that you want to keep before you do a factory reset.
Performing a factory reset via settings
The most convenient way to do a factory reset is via the phone settings.
1)From the main Home screen, press MENU, and then tap Settings > Security > Factory reset.
2)Enter "1234", and then tap OK.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
1)Press and hold the VOLUME UP, VOLUME DOWN and END CALL/POWER buttons.
2)When you see a warning message on screen, press the VOLUME DOWN button to perform the factory reset, or press any other button to cancel the reset.
3)After factory reset is complete, press the VOLUME DOWN button to restart your phone.
The Following 2 Users Say Thank You to shahinahmed007 For This Useful Post:
Old 08-18-2010, 14:23   #34 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
HTC HD MINI
Restarting or factory resetting your phone
If your phone becomes unresponsive or sluggish, first try restarting it and see if that helps. In case your phone has a persistent problem that cannot be solved, the last resort is to do a factory reset.
If your phone is running slower than normal, an application is not performing properly, or your phone becomes unresponsive, try restarting it and see if that fixes the problem.
To restart your phone, simply turn it off and back on. If pressing and holding the POWER button doesn't work, remove the battery, wait for a few seconds, reinsert the battery, and then turn your phone back on.
1)On the Home screen, slide to the Settings tab and then tap Security > Factory reset.
2)Enter 1234.
3)Tap Yes to perform the reset, or tap No to cancel the reset.
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone
1)With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
2)While holding the volume buttons, press the POWER button briefly and then release it.
3)When you see a warning message on the screen, release the VOLUME UP and VOLUME DOWN buttons.
4)Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset
THANKS
Old 08-18-2010, 14:39   #35 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
HTC WILDFIRE AND HTC ARIA
To restart your phone, simply turn it off and back on. If pressing and holding the POWER button doesn't work, then remove the battery, wait for a few seconds, reinsert the battery, and then turn the phone on
Note: Factory reset will not remove the data and files that are in your phone’s microSD card
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
1)From the Home screen, press MENU and then tap Settings.
2)Scroll down the screen and then tap Privacy > Factory data reset.
3)On the Factory data reset screen, tap Reset phone, and then tap Erase everything
1)With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Note: If you are not sure whether your phone's power is turned off, remove and then reinsert the battery.
2)Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
3)Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
4)Press VOLUME UP to start the factory reset
ITS COULD BE HELP U..THANKS
Old 08-18-2010, 14:51   #36 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
htc legend hard reset is same as wildfire and aria
The Following User Says Thank You to shahinahmed007 For This Useful Post:
Old 08-19-2010, 07:11   #37 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
@ shahinahmed007
Photon n rome are not based on Android :|
Wrong selection.
Old 08-19-2010, 08:20   #38 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
Originally Posted by .:SUBRATA:. View Post
@ shahinahmed007
Wrong selection.
any section for this???
Old 08-19-2010, 08:33   #39 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
sorry have----------hd mini is windows phone
Old 08-20-2010, 13:32   #40 (permalink)
Member: 789830
Red face htc dream 100 EN CHINOIS ,,??????
PLEAZE HELP ME,my phone is in chinese language after reset
what can i do to have the french language
it's a HTC DREAM 100
Old 09-08-2010, 15:42   #41 (permalink)
Member: 1022300
Thanks Meter: 3
do u have to do the whole process everytime for different way to hard reset?
Old 09-14-2010, 21:57   #42 (permalink)
Member: 503921
Thanks Meter: 2
hello,
how to do hard reset on ACER E400?
thanks.
Old 09-14-2010, 23:05   #43 (permalink)
Member: 244832
Thanks Meter: 4
What about Samsung I9000 Android .How to hard rest this model ? any halp ......thanks for all
Old 09-17-2010, 14:22   #44 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
no solution for blocked gw620????????????????
Old 09-20-2010, 10:19   #45 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
to all users who can not unblock gw620:
on versions up to 10f is not possible to unblock security code nor upgrade main soft (fastboot requires a vol down+menu+camera and doesnt work in this ver)
All Smart Phones & PDA/PALM Hard Reset Key Total InfoHere with picture ::.::RAMJAN::.:: HTC & Smartphones ( WM Without Touch) 326 01-18-2017 19:49
how to hard reset o2 xda steatlh phone... harish35200 HTC & PDA WM( With Touchscreen) 12 07-31-2013 13:11
A to z smart phones hard reset- soft reset updated ..:::YMG:::.. HTC & Smartphones ( WM Without Touch) 1 03-05-2013 04:18
G1 Google Phone hard reset new gsmshapon Universal GSM Software 0 05-20-2009 08:12
How do you Hard Reset Audiovox SMT 5600 Phone? crystalgeyser2 HTC & PDA WM( With Touchscreen) 1 07-14-2005 02:43
Page generated in 0.22738 seconds with 10 queries
