Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 05-12-2011, 12:00   #46 (permalink)
ameerali19's Avatar
Member: 884639
Sonork: 100.1597105
Thanks Meter: 266
How To: Root the HTC Hero
or
check in
http://www.xda-developers.com/tag/htc-hero/
Old 06-09-2011, 00:28   #47 (permalink)
Member: 1591532
I need help. I did the rooting but I can'nt update it and most of all a lost all my files and can'nt go back. Can some one help me go back with my HTC T-Mobil G1?
Old 06-12-2011, 19:18   #48 (permalink)
Anil Sharma 123's Avatar
Member: 1124357
Thanks Meter: 70
Arrow Help Me About Samsung I5510 Rooting
Brother Anyone Help Me In Rooting Of Samsung I5510, Pls Tell Me Step By Step And Give Me All Of Required Software About It
Regards: ANIL SHARMA
Thx In Advance Brother
Old 06-25-2011, 13:27   #49 (permalink)
Member: 1602342
I have HTC smart can it work with that Mobile.
Old 06-25-2011, 13:33   #50 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
hello mates why asking working in this mob or that mobile BLA BLA BLA .... ., just try and post if work or not :P
Old 06-25-2011, 17:33   #51 (permalink)
Member: 1591532
Thank you for all the information on this page.
Originally Posted by .:SUBRATA:. View Post
Rooting HTC Dream/G1/T-Mobile G1
Downgrading from RC30/RC9 and up
  1. Format your phone's SD card to FAT32 mode:
    • Hook your phone up to your computer using a USB cable and then wait for the notification to show up in your title bar of your phone.
    • Click the notification, and then click "Mount".
    • A new removable disk should show up on your computer. Right click it and select Format, and select FAT32 as the file system type.
  2. Download and unzip the RC29 or RC7 image file. Copy the DREAIMG.nbh file to the SD card. (RC29 for US, RC7 is for UK)
  3. Turn the device power off.
  4. Hold Camera button, and press Power button to entry bootloader mode. You should see a gray/white screen with instructions to flash your phone with the update on your SD card. If you don't see that, make sure you followed the instructions properly.
  5. As per the on-screen instructions, press the Power button to start upgrade procedure. DO NOT DO ANYTHING TO INTERRUPT THIS PROCESS.
  6. After it is finished, restart your phone by pressing the trackball button ("action button") and then press Call, Menu and End simultaneously.
At the end of this process, you'll now be running a build old enough to have the exploit we need to get root. Continue on with the next section.
Rooting RC29 and Lower
On RC29 phones and lower, a huge exploit existed where anything you typed into your keyboard was also being run in a hidden console with root permissions.
  1. Download recovery.img and copy it to your SD card (see the previous section on how to copy from your computer to your Phone's SD card).
  2. Download the Hard SPL and copy the zip file to the SD card.
  3. All files must be on the root of your SD card.
  4. Restart your phone. Wait for your phone to start up fully and show the home screen.
  5. After your phone starts up, type "telnetd" and press enter. (Yes, it will start up a contact search, don't worry. Just type it.)
  6. Download an Android "Telnet" application from the Market and connect to localhost.
  7. If you connect successfully, you will have a root prompt "#".
  8. Type the following into Telnet (these commands will give you root access easier in the future):
    • mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system
    • cd sdcard
    • flash_image recovery recovery.img
    • cat recovery.img > /system/recovery.img
Now you have root!
Next steps
Whether you gained root using RC29 or the downgrade method, the next steps are highly recommended. You will want to apply "Hard SPL" to your phone. HardSPL is what will allow you to apply flash images from other regions (like UK on US phones, and vice versa), create full backups of your phone, install the latest build from the Android source, and usually resurrect your phone if it is "bricked". You have already downloaded the file to your SD card, so now you can apply it.
  1. Power off your phone.
  2. Start up in recovery mode by holding home and pressing power.
  3. You will now enter recovery mode. You should see an exclamation.
  4. If you do not see a menu on screen, press Alt-L to show the menu.
  5. Press Alt-S to apply the update from the SD card.
  6. After the update is complete, hold Home and press Back to restart.
****A Big Thanks to Kaushik Dutta for all this****
B.R.
Subrata
Old 06-27-2011, 10:34   #52 (permalink)
Redknight07's Avatar
Member: 1478277
Thanks Meter: 41
-----SuperOneClick v1.9.5 (Root, Unroot, Enable Non-Market App)-------
Here's a one-click root with almost all phones and all android versions. (including the i9000, Droid, Nexus One, etc)
YOU CAN ROOT ALMOST ALL ANDROID PHONES!
The program requires Microsoft .NET Framework 2.0+ or Mono v1.2.6+
Operations systems with native support:
  • Windows Vista
  • Windows 7
  • Ubuntu Hardy (8.04 LTS)
  • Ubuntu Jaunty (9.04)
  • Ubuntu Karmic (9.10)
  • Ubuntu Lucid (10.04 LTS)
  • Ubuntu Maverick (10.10)
  • Debian Lenny (5.0)
  • Debian Squeeze (testing)
  • Debian Sid (unstable)
  • Debian Experimental
If you run Microsoft Windows XP, install .NET Framework v2.0 or above
If you run Mac or another Linux flavor, make sure you install Mono:
Download - Mono
For more information about making it work in linux:
See here
You NEED to put your phone on USB Debugging mode
You NEED to install make sure the Android drivers for your phone are installed
Make sure you DO NOT mount your SD card.
If you still can't get something to run, try doing it in recovery mode.
Read me: (READ BEFORE POSTING)
2/24/2011:
I registered my website shortfuse.org so you can grab SuperOneClick from there now.
2/22/2011:
Great news. -1Day roots AT&T Motorola Atrix4G!!! YAY!
11/29/2010:
I'm sorry I haven't been updating lately!!! The problem is, I no longer have an Android phone and I can't play around or test anymore. I'm going to see if I can find one on craiglist or ebay.
11/10/2010:
I finally figured out how to root without looping. After rooting 13 phones, this is how I did it on the first try.
Turn USB Debugging OFF
Click Root
When it says: Waiting for Device, Turn USB Debugging ON
It'll now run RATC
When it says: Starting ADB Server...
All BEFORE it says "Waiting for device..." again
If you're having issues with "wait for device" or if RATC is looping, try this
Unplug your USB Cable
Go to Settings > Applications > Development
Uncheck USB Debugging
Plug in your USB Cable
Check USB Debugging
Here is download link
http://forum.xda-developers.com/atta...5&d=1307984755
http://forum.xda-developers.com/atta...7&d=1307984774
Enjoy it ......
Redknight07
Old 08-15-2011, 21:10   #53 (permalink)
Member: 1534619
I have HTC Desire HD with Vodafone UK brand, unlocked.
How to root HTC Desire HD :
Android version 2.3.3;
HTC Sense 2.1
Software number 2.36.161.12;
Kernel 2.6.35.10-g0956377;
Baseband version 12.54.60.25U_26.09.04.11_M2;
Build number 2.36.161.12 CL52372 release-keys.
Old 09-19-2011, 22:53   #54 (permalink)
Member: 1658045
Hello ,
i recently updated my apex to froyo 2.2 and i set up my screen lock with a secret pin and i feel very stupid now that i dont remember my pin to unlock my phone.. Its been almost a week and i cant get into my phone at all.. Once it power on it go to the lock screen and after i atempt 5 times and tells me to wait 30 seconds and try again..... I cant get in to my phone ... Someone plz help me ... I was thinking of maybe i can reset my phone somehow by usb connection or combos of button pressing to get pass the code or just some way to bypass it so i can getinto my phone ......idk ....what should i do ..... Plz help .. Begging
Old 10-16-2011, 11:45   #55 (permalink)
Member: 442126
Thanks Meter: 24
Dear mates HTC HD2 running os android 2.2 i want to update gengerbread 2.3 is posible?how can i update plz explain am new bai in htc plz help thnx in aduance
Old 10-16-2011, 19:17   #56 (permalink)
Yong Vannak's Avatar
Member: 770210
Sonork: No
Thanks Meter: 46
i need HD7 file update to android thank for your answer
Old 11-14-2011, 02:23   #57 (permalink)
taleb_amine8's Avatar
Member: 223552
Thanks Meter: 63
I want to bypass google account in my htc my touch 3g "this phone is lock" so i cant activate this phone with google account????
Old 11-14-2011, 16:21   #58 (permalink)
Registered User
Member: 77443
Thanks Meter: 24
Thumbs up Htc wildfire
Android Root - All Questions answered here
|All Info's are collected From all over the Internet |
I ll post here all info about Rooting Android phones. how to upgrade rooted rom. overall everything about Android Phones rooting.
You never know
The good thing about having root is you can go back if you want. The same is not true of not having root. We do not know what steps Google/Tmobile will take to rid the end users of root in the future. For all we know the next OTA will remove the keys that allows the RC29 downgrade method to work and you could be stuck on a non rooted G1 forever. If you have root and for some reason it does not work for you there is always the option of going back.
What Does Root Give Me?
  1. Full control over your system
  2. Ability to alter system files. You can replace many parts of the "Android Core" with this including:
    • Themes
    • Core apps (maps, calendar, clock etc)
    • Recovery image
    • Bootloader
    • Toolbox (linux binary that lets you execute simple linux commands like "ls") can be replaced with Busybox (slightly better option)
    • Boot images
    • Add linux binaries
  3. Run special apps that need more control over the system
    • SuperUser (lets you approve or deny the use of root access to any program)
    • Task Manager For Root (Lets you kill apps that you otherwise could not kill)
    • Tether apps (like the one found at [android-wifi-tether.googlecode.com])
    • <there are more but I cannot think of any right now>
  4. Backup your system
    • You can make a folder on your sdcard and backup all of your .apk files to your sdcard (helps if an author decides to "upgrade" you to a version that requires you to pay to use the version you just had)
  5. Relocate your (browser/maps/market) cache to your /sdcard
  6. Relocate your installed applications to your /sdcard
  7. Reboot your phone from the terminal app easily (su <enter> reboot <enter>)
What Do I Lose Having Root
  1. The ability to accept OTA updates (well, you can but you would lose root, so its been made so they get denied)
  2. The sense that someone else controls your phone
  3. The need to sit in an Android chat channel asking how to get root
  4. The need for a stupid useless "File Manager" that lets you see filenames but almost nothing else.
  5. The ability to have a knowledgeable conversation with a T-Mobile rep about your phone. (Ask one of them to spell root for you)
More!!
I know there is a ton more, but others will have to fill them in for me.
* Please keep this thread clean. do not post any question until i fulfill this thread. your co-operation is appreciated.
B.R
Subrata
please help me how to flash htc wildfire please here is the detail
when power on pressed only stuck htc logo
H-BOOT is 0.80.0003
radio is 3.35
please tell me how to do what to do first
Old 11-18-2011, 08:13   #59 (permalink)
Registered User
Member: 77443
Thanks Meter: 24
Thumbs up Waiting
H-BOOT is 0.80.0003
radio is 3.35
still waiting for reply please help me what to do
Old 12-07-2011, 17:51   #60 (permalink)
Member: 306106
guys, have you tried to root HTC Aria?
[Guide] Android Phones: Hard Reset .:SUBRATA:. Android based Phones / Tablets 355 02-09-2016 14:58
[FAQ] How to work with Android Phones - Wiki [2010-08-18] .:SUBRATA:. Android based Phones / Tablets 96 04-14-2014 14:40
Can anyone unlock the android phone liguangnan Wanted Products 16 05-26-2011 17:41
Compatible USB Battery Cradle for T mobile HTC Dream G1 Google Android Phone IPMART ipmart WebShop 0 05-08-2009 01:50
Looking for a (google) Android phone Salami1_1 Android based Phones / Tablets 0 11-21-2007 14:18
Page generated in 0.24467 seconds with 9 queries
