Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
10-21-2018, 19:06 | #1 (permalink) |
Freak Poster Join Date: Jun 2018 Location: Internetz Age: 40
Member: 2843734 Status: Offline Thanks Meter: 148 | [GUIDE] Repairing IMEI with QPST (Qualcomm Snapdragon SoC's) Hello guys. First a little history.. Coolpad Defiant 3632A - The pain in the 4ssphone I worked on this phone for a client and used Uni Android Tools to attempt repairing the lost IMEI. This was unable to work any magic so I tried a handful of other tools / hardware of mine with no luck.. Possibility my phone has some security issues so that is why I was unable to repair. So I ended up repairing my IMEI on this Coolpad Defiant 3632A using QPST, Hex editor and simple IMEI conversion using DIAG Mode to backup/restore QCN and also adb shell root to dd the modem partitions etc. Interesting as well because I might have found a temp root during this process. Root should be required to carry out the commands i did and zero out the partitions i did but as far as I know the temp root method I tried earlier didnt work so still trying to figure out what all else i found / enabled and modified that allowed it. This handset is odd however, have had issues with it since past while since the start of modifying it. Handset is out to a client now here in a few days though so I think I will be done with it. Aside of this I would like to see someone flash that firmware I uploaded and posted to XDA here with UAT or QFIL for example and let me know if it worked out for them. This method works on most Chinese Qualcomm based phones and HTC, LG and others. Just different system layouts and locations of blocks. Credits for all the help goto snapdragon unbricking I learned this from. Very simple, quick and easy. I would recommend it to those who have issues repairing qualcomm IMEI's with UAT/Other apps meanwhile until they fix the issues. This is of course also good to know just in case. Now for the Steps to repair your Qualcomm phone. First you will need to download all of the files required for these steps [link]here[link]. Now onto the process. **Warning** This can potentially screw up your phone rendering it the equivalent of a paper weight IF not done correctly. So pay attention to each step. I am not responsible for lost baseband's, lost IMEI's, bricked phones and nuclear war. Proceed with caution and via your own will. *Phone I am using for this Guide is a [Coolpad Defiant 3632A]* Step 1: Make sure your phone is a Qualcomm phone not mediatek, you have the files downloaded and you have root with the ability to get into Diag Mode on your phone. Some phones might not need Root. I didn't for mine.. Step 2: WRITE DOWN YOUR IMEI SOMEWHERE SAFE! IF you don't have it don't worry as your IMEI most likely is false / null. Whole reason we're here right? Ok. Now you want to connect your phone to your PC, enable diag mode on your phone, Install QPST Tools then open QPST Configuration. Goto Ports tab and make sure your phone / com port are showing up and then enable it. Next open QPST Software Download and navigate to the Backup tab. Step 3: Make sure your com port is still showing and you are connected. Next click to the right of where it says xQCN file the "Browse" button and set a location and name your backup file something like coolpad_original_qcn.qcn . Save it as .qcn format not xQCN. Now click start and once it has finished we will get to zero'ing out the proper partition blocks on your phone. Step 4: With diag enabled and your phone rooted (if needed) drop a root priveleged ADB shell in cmd prompt. What we are going to be doing is zero'ing out the partitions dealing with the baseband and IMEI. They are modemst1, modemst2 and fsg. Type in these commands (WARNING GETTING THE WRONG PARTITION COULD BRICK YOUR PHONE. SO MAKE SURE YOU ARE 100%) Code: cd /dev/block/platform/soc/ ls Code: ls -al 7824900.sdhci/by-name Should look similar to this Code: cp3632a:/dev/block/platform/soc # ls -al 7824900.sdhci/by-name ls -al 7824900.sdhci/by-name total 0 drwxr-xr-x 2 root root 960 1969-12-31 18:00 . drwxr-xr-x 4 root root 1040 1969-12-31 18:00 .. lrwxrwxrwx 1 root root 21 1969-12-31 18:00 DDR -> /dev/block/mmcblk0p15 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 aboot -> /dev/block/mmcblk0p19 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 abootbak -> /dev/block/mmcblk0p20 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 apdp -> /dev/block/mmcblk0p41 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 boot -> /dev/block/mmcblk0p21 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 cache -> /dev/block/mmcblk0p24 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 cmnlib -> /dev/block/mmcblk0p35 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 cmnlib64 -> /dev/block/mmcblk0p37 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 cmnlib64bak -> /dev/block/mmcblk0p38 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 cmnlibbak -> /dev/block/mmcblk0p36 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 config -> /dev/block/mmcblk0p28 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 devcfg -> /dev/block/mmcblk0p10 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 devcfgbak -> /dev/block/mmcblk0p11 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 devinfo -> /dev/block/mmcblk0p23 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 dip -> /dev/block/mmcblk0p31 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 dpo -> /dev/block/mmcblk0p43 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 dsp -> /dev/block/mmcblk0p12 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 fsc -> /dev/block/mmcblk0p2 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 fsg -> /dev/block/mmcblk0p16 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 keymaster -> /dev/block/mmcblk0p39 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 keymasterbak -> /dev/block/mmcblk0p40 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 keystore -> /dev/block/mmcblk0p27 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 limits -> /dev/block/mmcblk0p29 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 mcfg -> /dev/block/mmcblk0p34 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 mdtp -> /dev/block/mmcblk0p32 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 misc -> /dev/block/mmcblk0p26 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 modem -> /dev/block/mmcblk0p1 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 modemst1 -> /dev/block/mmcblk0p13 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 modemst2 -> /dev/block/mmcblk0p14 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 mota -> /dev/block/mmcblk0p30 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 msadp -> /dev/block/mmcblk0p42 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 oem -> /dev/block/mmcblk0p44 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 params -> /dev/block/mmcblk0p18 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 persist -> /dev/block/mmcblk0p25 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 recovery -> /dev/block/mmcblk0p22 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 rpm -> /dev/block/mmcblk0p6 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 rpmbak -> /dev/block/mmcblk0p7 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 sbl1 -> /dev/block/mmcblk0p4 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 sbl1bak -> /dev/block/mmcblk0p5 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 sec -> /dev/block/mmcblk0p17 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 ssd -> /dev/block/mmcblk0p3 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 syscfg -> /dev/block/mmcblk0p33 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 system -> /dev/block/mmcblk0p45 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 tz -> /dev/block/mmcblk0p8 lrwxrwxrwx 1 root root 20 1969-12-31 18:00 tzbak -> /dev/block/mmcblk0p9 lrwxrwxrwx 1 root root 21 1969-12-31 18:00 userdata -> /dev/block/mmcblk0p46 Code: dd if=/dev/zero of=/dev/block/mmcblk0p13 dd if=/dev/zero of=/dev/block/mmcblk0p14 dd if=/dev/zero of=/dev/block/mmcblk0p16 Step 6: You should have located the string now that shows 087a then following will be the rest of your IMEI just reversed. Should look like this which is from our example IMEI in step 3, "087A 2624 0953 2673 1400". This translates out to 7 skip the first 08 and the A then 62429035623741 so 762429035623741. Step 7: Open the last tool in the zip called IMEI Converter. Input your phones new (factory original) IMEI in the first box and take the output and replace "087A 2624 0953 2673 1400" with this string you just created. Save your file and MAKE SURE you do not overwrite your original QCN backup. Step 8: Open up QPST Software Downloader and goto Restore tab. Select your file we saved in the last step and write it. Now reboot your phone. Check to see that your new imei is showing. In my case I had to run Net Tools > RF Tools > then "clean" the MBN in order for my IMEI to show. Well that's it! You're done. noidodroid |
The Following 11 Users Say Thank You to noidodroid For This Useful Post: |
10-21-2018, 19:32 | #2 (permalink) |
Member: 2843734 Status: Offline Thanks Meter: 148 | Here are the files needed for the operation. https://www.androidfilehost.com/?fid...32744536985122 |
The Following 3 Users Say Thank You to noidodroid For This Useful Post: |
03-18-2020, 12:13 | #9 (permalink) | |
Member: 2843734 Status: Offline Thanks Meter: 148 | Quote:
