Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 07-21-2013, 16:55   #1 (permalink)
alishams123's Avatar
Member: 811264
Sonork: 100.1638656
Thanks Meter: 231
how to flash china tablet (Rockchip rk2928 CPU)?
Model : PC7558
MADE IN : P.R.C !
CPU : Rockchip rk2928
OS : Android
I need to unlock Pattern lock.
The Following User Says Thank You to alishams123 For This Useful Post:
Old 07-21-2013, 17:58   #2 (permalink)
Member: 336834
Thanks Meter: 4
1- hold vol+ and vol- +power
2- and show android adamc logo 10 press power +vol -vol show recavery menu and wipe
done
The Following 4 Users Say Thank You to omidbest110 For This Useful Post:
Old 07-21-2013, 18:35   #3 (permalink)
Member: 1754005
Sonork: 100.1646916
Thanks Meter: 53
Use Multi Tool For Restore...
And Remove Pattern lock....
NCK
Old 07-22-2013, 04:35   #4 (permalink)
sharjamobile121's Avatar
Member: 1672117
Thanks Meter: 73
NCK
link pls ........................
Old 07-22-2013, 05:26   #5 (permalink)
Member: 1844155
Sonork: NONE
Thanks Meter: 45
rkbatchtool.exe - Download - 4shared
Old 07-22-2013, 07:57   #6 (permalink)
Member: 811264
Sonork: 100.1638656
Thanks Meter: 231
i cannot Remove Pattern lock whit this tool.
The Following 2 Users Say Thank You to alishams123 For This Useful Post:
Old 07-22-2013, 08:00   #7 (permalink)
Member: 1730593
Thanks Meter: 3
how too flash this tablet? ( not hard reset)
The Following User Says Thank You to namakdooon For This Useful Post:
Old 07-22-2013, 08:01   #8 (permalink)
Member: 811264
Sonork: 100.1638656
Thanks Meter: 231
done
This method works properly.
thanks Mr. omidbest110
Old 07-27-2013, 22:12   #9 (permalink)
Member: 1986525
اینجا یه ایرانی پیدا میشه به من کمک کنه؟
Old 07-29-2013, 11:45   #10 (permalink)
Member: 1987458
any one has firmware for ampe a73 tabalet because it has no volume buuton
The Following User Says Thank You to Ahsan_1 For This Useful Post:
Old 08-01-2013, 19:28   #11 (permalink)
Member: 1491213
سلام فایل موجود در پست شماره 6 رو دانلود کن
از اون استفاده کن
ولی باید یو اس بی دیباگینگ داخل تبلت از قبل روشن باشه
Old 08-16-2013, 05:10   #12 (permalink)
Member: 720440
Thanks Meter: 9
Tablet Maxis T25 Rockchip RK2928-g Fiamware flash file
plz....................help me
Old 08-17-2013, 15:07   #13 (permalink)
Member: 1955214
Thanks Meter: 23
adres firmware ?????????????????????????????????????????????
Old 09-15-2013, 21:32   #14 (permalink)
Member: 1342044
Thanks Meter: 51
maxsis maxpro hard reset solution ...............
Old 09-16-2013, 03:09   #15 (permalink)
Member: 1894915
Sonork: mr1919
try to use this one...goodlock!.)
just run the rkbatchtool,put a check in "misc"..uncheck parameters,on the right side of "misc"..click browse,then find it in the folder of rkbatchtool.."image"open it and click "misc" after all done!..click run below!..thanks!
i am sorry,links is not available because i need atleast ten post!..
Page generated in 0.21237 seconds with 9 queries
