Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
10-30-2018, 04:55 | #1 (permalink) |
Junior Member Join Date: Jul 2018 Location: Los Angeles
Member: 2849208 Status: Offline Thanks Meter: 6 | How To Flash Stock Firmware Using QPST Flash Tool Flashing smartphones is one of the most heard and popular technique among Android smartphone users. There are more and more flash tools available for different brands and devices. if your device is powered by Qualcomm chipset, so it is better to use a Qualcomm supported flash tool in situations where you want to flash it. QPST flash tool is one o the flash tool among the other available as Qualcomm product support tool. What is the QPST Flash Tool? It is a Qualcomm product support tool, a tiny little app which facilitates you to flash stock firmware Qualcomm smartphones and tablets devices. Simply you can download the most recent firmware package into your own device. Thing is that the tool is compatible with a range of devices due to Qualcomm is more is used for many smartphones and tablet devices. Download Requirements The toll needs to be executed via a windows PC. So you have to download and install it into PC. The tool is compatible with Windows XP, Windows 7, Windows 8/ 8.1 as well as Windows 10. Install necessary USB drivers in your PC. need a proper and compatible USB cable to connect both devices. Available latest QPST flash tool version: QPST 2.7.474 QPST Major Features Easy and detailed user interface. backup and restore ability. No need for manual backup and restore. Download Firmware. The tool consists of an inbuilt functionality which let you download the available latest firmware. save service programming data QPST Configuration How to Flash Using QPST Flash Tool Pre-requirements: Download and install necessary USB drivers in your Windows PC. Download a firmware file suitable to your device. Step 1: Install QPST flash tool in your PC. Step 2: Navigate to the installed location. There you will see several files under that folder. Step 3: Connect your Qualcomm powered smartphone to the PC. Step 4: Under that folder, you will see a file named as Qpst config. Open it. Step 5: Then the QPST configuration will be launched and there you will several tabs on that window. Click on the port tab available there. And then click on the start client tab and there you will see a menu. Under that menu select the software download option. Step 6: A dialog box will appear and there you will see several options named as Browse. Navigate to the option in front of the Phone and browse the firmware you already downloaded. Step 7. There is another browse option available in front of the Boot image. Click on it and locate the Bootloader file comes with that downloaded firmware file. Step 8: That is all and now you have to do is to click on that start button to begin the flashing process. Once it completed disconnecting the device and restart it before making it to regular Uses. That is all So wish you all Good luck. |
