11-16-2012, 05:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | How to hard reset Identity Tab (Tomorrow Connected) how to unlock it i couldnt find info about on forum and internet if there is no hard reset how to solve or have to flash if have to flash how to flash please help thanks |
01-05-2013, 13:40 | #11 (permalink) |
Junior Member Join Date: May 2009 Location: inside city jail
Member: 1027621 Status: Offline Thanks Meter: 5 | here is the solution for identity korean tab hang in logo..pattern lock.. all you need is SD card..512 and up.. format SD card in FAT 32 here is the flash files e201firmware_2 - Download - 4shared extract this file and put in sd card inset the SD card and power on your tablet PUSH the reset button beside the usb you will not see it flashing.. wait till astro boy or android boy pop up... then erase the file at put this file again in SD card e201firmware - Download - 4shared PUSH the reset button beside the usb you will see Korean character do not touch anything..just wait for 5 minutes done.........your tab is working again..... |
The Following User Says Thank You to cyclades_03 For This Useful Post: |
04-18-2013, 05:46 | #12 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1919473 Status: Offline Thanks Meter: 0 | Sir Cyclades_03 patulong po about sa Enspert Identity E201V kasi after I put the e201firmware into my SD card it goes like you said then kailangan po bang e-delete ko yun unang inilagay ko at ilagay ang pangalawa na firmware? after that nag hang po yung logo na android boy as i put the 2nd e201firmware to my tab,please help me sir.. |
08-01-2013, 08:15 | #15 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1991001 Status: Offline Thanks Meter: 0 | Sir Cyclades_03 patulong po about sa Enspert Identity E201V kasi after I put the e201firmware into my SD card it goes like you said then kailangan po bang e-delete ko yun unang inilagay ko at ilagay ang pangalawa na firmware? after that nag hang po yung logo na android boy as i put the 2nd e201firmware to my tab,please help me sir.. |
