Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
08-03-2014, 11:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | How to remove Patteren Lock Rockchip Tablet Usb debugging is not active and tablet does not go to recovery. Recovery is dead.... Is there any solution to remove this patteren lock. Or any flasher to flash this tablet ...... |
08-04-2014, 09:35 | #3 (permalink) |
No Life Poster Join Date: Mar 2013 Location: NewYork Age: 32
Member: 1900437 Status: Offline Thanks Meter: 113 | Why don't you try resetting the device pattern lock by using the gmail account you have used over the device, I am sure you can use that even if the Wi-FI or data connection is not switched on just put the sim card back in place, switch the device on and once the device switches on try pressing and holding the power button until a popup appears asking you about switching your device off, restart etc, it will have an option to enable the mobile data. Use it to enable the data connection, once the data connection gets enabled use log yourself up to the gmail account over the PC or Laptop. Once logged in search for the Android device manager over the Google, wait for a while until it shows device online. Once the device is online use the unlock option to unlock your device as well as set a new pattern. once done you will be able to use your device back to normal again ! |
08-06-2014, 00:40 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
