Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
07-31-2015, 06:39 | #286 (permalink) |
Junior Member Join Date: Dec 2009 Location: mumbai
Member: 1173958 Status: Offline Thanks Meter: 0 | Sent from my Aqua Y2 1GB using Tapatalk |
08-11-2015, 06:32 | #296 (permalink) |
Junior Member Join Date: Aug 2015 Location: chowk sarwar shaheed
Member: 2441537 Status: Offline Sonork: www.sonork.com Thanks Meter: 1 | factory setting xpria Z2 mazhar.ali934 skype To force your device to restart Press and hold down the power key . In the menu that opens, tap Restart. The device restarts automatically. To force the device to shut down Detach the micro SIM card slot cover. Using the tip of a pen or a similar object, press the OFF button. Do not use overly sharp objects that could damage the OFF button. To perform a factory data reset To avoid permanent damage to your device, do not restart your device while a reset procedure is underway. Before you start, make sure to back up any important data that is saved on the internal memory of your device to a memory card or other non-internal memory. From your Home screen, tap Application screen icon in Sony Smartphones. Find and tap Settings > Backup & reset > Factory data reset. To delete information such as music and pictures from your internal storage, mark the relevant checkbox. Tap Reset phone. If required, draw your screen unlock pattern or enter your screen unlock password or PIN to continue. To confirm, tap Erase everything. Your device does not revert to an earlier software version of Android™ even if you perform a factory data reset. If you forget your screen unlock password, PIN or pattern in step 6, you can use the device repair feature in PC Companion or Sony Bridge for Mac to erase the security layer. By running the repair feature, you are reinstalling software for your device and you may lose some personal data in the process. |
