HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
01-21-2012, 07:54 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: GREENHILLS
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | HTC HD2 WindowsPhone/Successfully Changed OS into Android Gingerbread 2.3.7 DONE. Please read carefully before installing! 1) To install this HSPL there must be any SPL version from this list on your device: SPL 1.42.0000 SPL 1.62.0000 SPL 1.66.0000 SPL 2.07.0000 SPL 2.08.0000 SPL 2.10.0000 Otherwise the installation will fail! You can select which SPL version to install in "Choose SPL" screen. To check your SPL version, hold the Volume Down button and do a reset. It is possible to downgrade to this SPL, by just flashing to an Official ROM with this SPL version. After you installed the HSPL3, then continue. Mga kailangan i download: HD2 ToolKit, which can be downloaded Here. Cyanogen MOD 7 Gingerbread 2.3.7, which can be downloaded Here. *** RUN EVERYTHING AS ADMINISTRATOR! *** 1)Reformat your memory card to a FAT32 file system. 2)Copy the Gingerbread Zip file to your memory card. DO NOT EXTRACT THE FILES! 3)Extract the HD2 Toolkit to your desktop like how I have it in the video. 4)Open The HD2 Toolkit AS ADMINISTRATOR! (For Windows Vista and 7 only) Flash the Magloader. Turn the phone off and put the phone in bootloader by holding the Volume Down button and the Power button together. In the HD2 toolkit, press the Install Magldr and follow the steps. 5)Flash the Radio. Put the phone in bootloader again and where it says “Install Custom NBH/NB RUU File”, click browse. Browse to the HD2 toolkit folder and you will see a folder called “Radio”. Select the 2.12.50.02.nbh and press Install RUU. 6)After the phone restarts Mag Loader, press the Volume Down button until you get to #5 (USB Flasher) and press the Call button (Green button) and it will be in USB Flasher Mode. It will say Wait for USB…USB. 7)In the HD2 toolkit, select MagLdr repartition and choose the 150MB File size. Leave the Cache size the same (45). Then press Repartition. 8)After it is done, the phone will restart into Magldr. Go to AD Recovery. Go to “Install Zip From SD Card. Then “Choose Zip from SD Card”. Select the ROM and Press Yes. After it is done, press the back button and then press Reboot System. 9)Let the phone load up and enjoy your new Android phone! |
The Following 25 Users Say Thank You to DEADBOOT For This Useful Post: |
02-12-2012, 06:29 | #8 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
Only SPL Flashing will not solve SPL issues bro. full flashing is needed. | |
02-12-2012, 12:47 | #10 (permalink) |
No Life Poster Join Date: Aug 2010 Location: PAKISTAN
Member: 1383464 Status: Offline Sonork: 100.1669490 Thanks Meter: 100 | dnt try this solution on Tmobile US my HD2 bricked after using this person post who just copy paste from any other forum he even dnt know that TMobile US & simple HD2 are different with different radio u will bricked your phone if its TMOBILE US so dnt try this method on TMobile US |
02-12-2012, 13:17 | #11 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Quote:
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
02-12-2012, 13:52 | #13 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | write this radio after hspl,if you have problem Radio_Leo_2.15.50.14.rar |
02-12-2012, 14:11 | #14 (permalink) | |
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | Quote:
if you don't know how to use it,don't try to experiment your phone and don't blame me if your phone bricked after your wrong step... don't try this if you don't know the consequence.. Do it with your own risk.. | |
02-13-2012, 12:32 | #15 (permalink) |
Freak Poster Join Date: May 2009
Member: 1023256 Status: Offline Thanks Meter: 48 | i flash Magloader and then write radio, flash ok the phone restart but as you said i press the Volume Down button long time its not coming Mag Loader and i press both Volume Down button the Call button (Green button) together also its not coming Mag Loader. can you please tell me why ? Thanks for nice sharing |
