Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
03-02-2011, 08:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | HTC Nexus One How To Unlock Bootloder And Write Rom. The bootloader of Nexus One supports a command, which when given via fastboot, lets you to unlock it. After unlocking, you can flash any custom ROM on your device. Here are the steps: 1. Download fastboot (includes Windows, Mac, Linux versions) and extract it. 2. Run command prompt, go to the directory where you extracted the zip file. 3. On Windows type ‘fastboot-windows oem unlock’. On a Mac, type ‘./fastboot-mac oem unlock’. If your machine is Linux, type ‘./fastboot-linux oem unlock’. That’s it. Your device’s bootloader is now unlocked. Now you can go ahead and root Nexus One on Android 2.1. Note: Unlocking the bootloader on your phone using fastboot gives you the freedom to install any custom cooked ROM. However fastboot deletes all your personal data (similar to a factory ‘data reset’) in order to prevent any unauthorized access to it. 2nd Root You HTC Nexus. 1. Download Superboot.zip file for your version of Nexus One ( check the device ‘About’ screen to find which superboot version you need to download). Or you could download an insecure boot file if you want to manually deploy su and superuser.apk). Download links for Superboot Superboot for EPF21B Superboot for EPE54B Superboot for EPE76 Superboot for ERE36B Superboot for ERE27 Superboot for ERD79 Download links for himem enabled Superboot images (The himem superboot includes an updated wifi driver, so in case you want to revert back your Nexus One, you need to reflash your ROM) Superboot for EPF21B with himem enabled Superboot for EPE76 with himem enabled Superboot for EPE54B with himem enabled Superboot for ERE36B with himem enabled Superboot for ERE27 with himem enabled Download links for insecure Superboot images Insecure boot for EPE76 Insecure boot for EPE54B Insecure boot for ERE36B Insecure boot for ERE27 Insecure boot for ERD79 2. Extract the file to a directory. 3. Put your Nexus One in bootloader mode, which means you should first turn it off, remove it’s battery, plug in USB cable. When battery icon appears on screen, replace the battery. Now tap the Power button while holding the Camera key. 4. Next, follow the instructions as per your OS: Windows Double click on ‘install-superboot-windows.bat’ file. Mac OS X Open a terminal window to the directory containing the files, and type ‘chmod +x install-superboot-mac.sh’ followed by ‘./install-superboot-mac.sh’ Linux Open a terminal window to the directory containing the files, and type ‘chmod +x install-superboot-linux.sh’ followed by ‘./install-superboot-linux.sh’ That’s it. You will now have full root access to your phone so you can go ahead and install any themes or custom ROMs you wish to. 3rd Custom Rom. 1.Download Custom Rom. 3. Download the custom ROM from the source link and copy it to over to the SD card on the phone. 4. Enter the recovery image (if you’re not in it already) by powering on while pressing ‘Home’. 5. Select ‘Nandroid backup’ from the menu to do a backup. 6. If you copied the custom ROM as update.zip, select ‘apply sdcard:update.zip’, else select the option below. If you Like My Post Don't Forget Push Thanks. |
The Following 3 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
