Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
07-25-2017, 08:42 | #18 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2689387 Status: Offline Thanks Meter: 1 | Look for the working file at romvilla website........that where i got mine own itel 1508 touch pad issues solved, Last edited by ...:::::NP™:::::...; 07-25-2017 at 11:06. Reason: remove personal contact no |
01-26-2019, 12:41 | #29 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, There Is Two Type Of PCBA Available. The First One Is "C160I" And 2nd One Is "C160M". (1) If You Can Power On The Phone Normally, You Can Check The SW Information By The Settings, You Can See The VERSION Is IT1508-C160I Or IT1508-C160M. (2) If You Can’t Power On Normally, You Need To Disassemble The Battery Cover And Remove The Battery, You Can Distinguish From The N Version In The SN Number On IMEI Label. Example S/N:F8N6 It's N6, Need To See Only Last Two Digits. (This May Have Some Mistake If The N Version Is Mistake Printed Or You/Someone Have Changed The Main Board But Didn't Modify The IMEI Label. If The N Version Is N6/N8/N10, It Means The Main Board Is C160I. If The N Version Is N9/N12, It Means The Main Board Is C160M. (3)A You Can Distinguish Print Code (Near Audio Jack) In The Main Board (3)B You Can Distinguish The Lable (Below SIM Tray) In The Main Board (You Can See C160I Or C160M). Last edited by MyGSM World; 01-26-2019 at 12:50. |
The Following 3 Users Say Thank You to MyGSM World For This Useful Post: |
01-26-2019, 13:45 | #30 (permalink) | |
Freak Poster Join Date: Sep 2013 Location: INDIA
Member: 2015791 Status: Offline Sonork: 100.1649676 Thanks Meter: 21 | Quote:
my mobile s/n gxn17 .. | |
