Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 05-15-2012, 15:14   #1 (permalink)
Member: 1580957
install android HTC T3333 (toutch 2)
I wonder if someone already installed android in this model
and if I could help .....
thank you
Old 05-15-2012, 15:17   #2 (permalink)
Crazy Poster
Member: 1746221
Thumbs down
thank you
HTC Touch 2 Soft reset
Resetting Your Phone
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and  shut down all active programs. This is useful when your phone is running  slower than normal, or a program is not performing properly. If a soft  reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Remove the back cover.
2. Remove the stylus to reveal the RESET button that is located at the bottom of the stylus compartment.
3. Use the stylus tip to press the RESET button.
Your phone restarts and displays the Home screen.
4. Replace the back cover and insert the stylus back into its compartment.
http://www.hardreset.eu/images/htc_touch2_hard_reset.jpg
  HTC Touch 2 hard reset
How to hard reset HTC Touch2
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a  hard (full) reset. After a hard reset, the phone is restored to its  default settings—the way it was when you first purchased it and turned  it on. You will lose any programs you installed, data you entered, and  settings you customized on your phone, and only Windows Mobile® software  and other pre-installed programs will remain.
Warning! Your phone will be set back to factory default settings. Make  sure that any additional installed programs and important data on your  phone have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled,  back up all files from the storage card before using Clear Storage, hard  reset, or updating the operating system. Otherwise, you will no longer  be able to access the encrypted files on the storage card. Use  ActiveSync or Windows Mobile Device Center to transfer files between  your storage card and computer. After the procedure, copy your files  back to the storage card.
To perform a hard reset
1. With the phone turned off, press and hold the VOLUME UP and VOLUME  DOWN buttons, then press the END/POWER button shortly and release it.  You will then see this message  on the screen.
 http://www.hardreset.eu/images/htc_touch2_hard_reset_1.jpg
2. Release the VOLUME UP and VOLUME DOWN buttons.
3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
10000000% working
Old 05-15-2012, 17:07   #3 (permalink)
Member: 1580957
I know how to do hard reset on htc
want help installing the operating system android htc T3333
Page generated in 2.30596 seconds with 11 queries
