Lenovo General Lenovo phones discussion, firmwares, solution, help |
04-14-2014, 15:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: andhra pradesh, india
Member: 1212786 Status: Offline Sonork: 100.1626896 Thanks Meter: 24 | lenovo A269i Hard Reset Procedure 1. Turn off Lenovo a269i. Make sure it`s battery above 50%. 2. Now press and hold Power and Volume Up(+) together. 3. It will display Recovery Mode, Fastboot Mode and Normal Mode options. 4. Now select Recovery Mode option using volume keys android logo will appear. 5. Now press power button one time it will display the options. 6. Select wipe user data option using volume up button. after wipe done select reboot mobile. |
The Following 6 Users Say Thank You to sunil002 For This Useful Post: |
06-01-2014, 11:07 | #2 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2156850 Status: Offline Thanks Meter: 2 | lenovo A269i Hard Reset Procedure Here is the Procedure. 1. Turn off Lenovo a269i. Make sure it`s battery above 50%. 2. Now press and hold Power and Volume Up(+) together. 3. It will display Recovery Mode, Fastboot Mode and Normal Mode options. 4. Now select Recovery Mode option using volume keys android logo will appear. 5. Now press power button one time it will display the options. 6. Select wipe user data option using volume up button. after wipe done select reboot mobile. yes working |
The Following User Says Thank You to raj_hit For This Useful Post: |
07-25-2014, 12:48 | #3 (permalink) |
Crazy Poster Join Date: Jul 2012 Location: india Age: 40
Member: 1780708 Status: Offline Sonork: 62645 Thanks Meter: 7 | lenovo a269i hard reset keys 1. Turn off Lenovo a269i 2. Now press and hold Power and Volume Up(+) together. 3. It will display Recovery Mode, Fastboot Mode and Normal Mode options. 4. Now select Recovery Mode option using volume keys android logo will appear. 5. Now press power button one time it will display the options. 6. Select wipe user data option using volume up button. after wipe done select reboot mobile..... 100% tested |
08-10-2016, 07:01 | #6 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 361529 Status: Offline Thanks Meter: 8 | hold Power and Volume Up(+) together. not responing any other soltuion lenova a269i pattern lock hold Power and Volume Up(+) together. not responing any other soltuion or any other method |
